gabbagabi
Joined: Apr 03, 2004 Posts: 24538 Location: The Netherlands, Enschede
Audio files: 299
Posted: Sun Jan 29, 2017 11:49 am Post subject:
Yes ring modulation is four quadrant multiplication.
The output of your simulation looks like it does that (except for the glitches that seem to happen when both signals are zero). _________________ Jan
gabbagabi
Posted: Tue Jan 31, 2017 1:28 am Post subject:
good, now it seems that the circuit worth further investigation,
thx Blue Hell,
cheers bb |
gabbagabi
Audio files: 299
Posted: Sun Aug 13, 2017 10:31 am Post subject:
To me that looks like a balanced modulator alright - which is yet another name for the same thing.
See the 1496 internals - for instance.
gabbagabi
Posted: Mon Aug 28, 2017 7:47 am Post subject:
my posted schemo above is only looking nice and works fine in the simulation, may if u match the tranis u get better results in reality.
my new attemp sounds much nicer, i used the single Transistor VCA i posted here, i happent that there was a deafzone, i had to add an offset to get rid of her. but when i see offset-cancelation - i see atomaticly a modulation opportunity, so i added a deafzone modulation pot.
i did not included input attentuators in the schemo nor on breadboard
soundsample1: bell-like sound where i crank the deafzone-pot from min to max, no EFX used
soundsample2: small bellsound with just a tiny amount of reverb and delay
cheers, bb
96.63 KB |
| Viewed: |
911 Time(s) |
 Download (listen) |
| Filename: |
Ringmod_test.mp3 |
328.57 KB |
| Downloaded: |
1087 Time(s) |
 Download (listen) |
| Filename: |
some small bell tones.mp3 |
2.1 MB |
| Downloaded: |
1139 Time(s) |
gabbagabi
Posted: Mon Aug 28, 2017 9:18 am Post subject:
alanwilder has asked me what a vca has to do with a rinmod. I thought i will post an explanation of the circuit here, cos for me it was hard to find a good one when i was going to be interrested in ringmods.
Ringmodulation is also called 4quadrant multiplikation, so far so good.
A normal VCA does 2 Quadrant multipikation. Means if there is a CV and a signal present to output swings up and down, the cv paints the shape. BUT the cv is only positive. If apply a negative cv to the vca it will be mute to output. see pic1
If we put a second vca that can react on negative CV (eg by inverting the cv) AND mix those 2 signals together we have a maschine that makes , i guess, 2 Quadrant Multiplikation. that means the output will swing up and down, even there where before silence, like a copy of the active part pasted into the muted part. see pic2
now the only thing we have to do for have ringmodulation is to invert the phase of the second part we hav created, which can be easily done by an inverter. see pic 3. between the shape in pic2 and 3 is only a little difference when the cv is going thru zero and a important that in the "second" part the phase is shifted - like the wave is going backwards.
pic 4 shows the concept in blocks
any corrections and additions welcome.
16.34 KB |
| Viewed: |
19711 Time(s) |
6.59 KB |
| Viewed: |
718 Time(s) |
7.73 KB |
| Viewed: |
783 Time(s) |
7.5 KB |
| Viewed: |
726 Time(s) |
gabbagabi
Joined: Jan 31, 2003 Posts: 18267 Location: Durham, NC
Audio files: 229
Posted: Mon Aug 28, 2017 2:53 pm Post subject:
I verified your ringmod with 2 vcas t and it is indeed a balanced modulator. I have never seen this configuration before. Congrats. Something new, to me at least.
Now if you can come up with a linear frequency shifter without a phase shift network you would be my hero.
A frequency shifter just gives the sum and difference frequencies separately, whereas the balanced modulator gives both together. Every analog circuit I have seen uses 90 degree phase shift networks, and digital implementations use a complicated Hilbert transform. (Don't try too hard because this may not be possible).  _________________ --Howard
my music and other stuff |
gabbagabi
Posted: Tue Aug 29, 2017 5:30 am Post subject:
thank you.
A new thing to think about constantly comes in the very right moment.
I will deliver this frequenzy shifting mobile, or die wihle trying
You already explaint it , but i could not get it.
Do you have a prefered source where i can learn what it is, best works for me is a optical reference - input waveform - output waveform.
Or what is the most "simple" one u know?
cheers, bb |
gabbagabi
Posted: Tue Oct 03, 2017 5:21 am Post subject:
hi guys,
i dont know what went wrong in my post below from Mon Aug 28, 2017
i have played around on the breadboard with the same circuit again, but gave it a little bit more time and found out that it works not bad.
while playing it came to my mind that the signal attentuator which i normally put in front of the signal-in is kind of useless because with the cv attentuator and the offset u can archieve the same results, so i left it out and have more space on the PCB later. Iam not entirely shure here - any thoughts?
the RM/VCA goes above unity gain and i added a distortion option
the spikes on the top end of the saw in the example scope are coming from the vco and not from the RM
128.51 KB |
| Viewed: |
710 Time(s) |
118.44 KB |
| Viewed: |
642 Time(s) |
Audio files: 229
Posted: Sat Oct 14, 2017 3:50 pm Post subject:
Excellent work. BTW, function is misspelled on your schematic. _________________ --Howard
gabbagabi
gabbagabi
Posted: Wed Mar 07, 2018 8:41 am Post subject:
another RM
after gasboss broad this VCA back in my field of view
http://electro-music.com/forum/topic-33190-75.html
103.38 KB |
| Viewed: |
544 Time(s) |
2.61 MB |
| Viewed: |
485 Time(s) |
gabbagabi
gabbagabi
Posted: Sat Oct 27, 2018 3:21 am Post subject:
i guess i posted it already somewhere else, but ....
one very simple Ringmod, a switching one, which will give u of course a diiferent sound as a classical one
and two mods for this, a ringmod with PWM and a double-switch to swop the inputs
this could also be used as a VCA for rectangular waves
68.78 KB |
| Viewed: |
377 Time(s) |
89.19 KB |
| Viewed: |
376 Time(s) |
71.85 KB |
| Viewed: |
387 Time(s) |
gabbagabi
Posted: Sat Oct 27, 2018 3:30 am Post subject:
and again something about: "how i can use VCA as RM"
single VCA:
u could rectify the CV/carrier and always when the carrier is negative u turn the phase of the vca-output
double VCA: same idea as some post above but maybe better to read
49.6 KB |
| Viewed: |
362 Time(s) |
36.71 KB |
| Viewed: |
347 Time(s) |
MapacheRaper
Posted: Sat Oct 27, 2018 6:15 am Post subject:
So, now that you understand it, maybe you can explain it to us?
Edit: Ok, I see you have done it... The synchronicities are strong in this one.... |
