Joined: Jan 31, 2003 Posts: 18256 Location: Durham, NC
Audio files: 227
Posted: Fri Jun 10, 2005 12:46 pm Post subject:
Wacky internet - wizards please help |
There is a wacky problem with electro-music.com. I don't get it. It's complicated. It showed up first at the Cheltenham Art Center (CAC), and now it's happening at my house. The symtom is you can't get to electro-music.com, but you can get to other hosts.
There is a common configuration between what we were running at the CAC, both use a DLink DI-624 router connected to a cable modem. The cable companies are different though.
The setup in my house has been working flawlessly for well over a year, but this morning, suddenly electro-music.com stopped responding. Global Servers, our provider, assured me the site was up and responding. When I do a traceroute, I go for 11 hops and then get stuck on this router
63.214.153.106 ge2-0.core1.lax.netzero.net
I called my cable company and after 1/2 on hold, they had me take the DLink out of the line and low and behold, I could connect. With the DLink out of the circuit, that router passes my signal along to the server.
They can't explain this. I'm at a loss. I wonder, if anyone else is getting routed through this ge2-0.core1.lax.netzero.net box
Does anyone have any ideas? What the heck could this be? Why would the DLink in the middle matter? It doesn't matter for any other site I've tried.
I'm at a loss. I'm worried that other people can't get to the site. HELP!!! _________________ --Howard
my music and other stuff |
Audio files: 227
Posted: Fri Jun 10, 2005 1:03 pm Post subject:
Here is the trace route from my PC, FYI..
Trace electro-music.com (64.136.60.76) ...
10.229.208.1 RTT: 15ms TTL:170 (No rDNS)
24.229.84.41 RTT: 156ms TTL:170 (gateway-fas0-0-0-2.all.ptd.net ok)
207.44.126.169 RTT: 24ms TTL:170 (gateway2-atm3-1-323-str22all.str.ptd.net ok)
12.119.12.69 RTT: 50ms TTL:170 (nw2nj31ck4-pos2-0.att.net probable bogus rDNS: No DNS)
12.123.219.129 RTT: 32ms TTL:170 (tbr1-p013902.n54ny.ip.att.net probable bogus rDNS: No DNS)
12.123.3.58 RTT: 21ms TTL:170 (ggr2-p300.n54ny.ip.att.net probable bogus rDNS: No DNS)
4.68.111.5 RTT: 30ms TTL:170 (so-0-1-0.gar4.NewYork1.Level3.net ok)
4.68.97.97 RTT: 28ms TTL:170 (ae-1-54.bbr2.NewYork1.Level3.net ok)
64.159.1.126 RTT: 87ms TTL:170 (ae-0-0.bbr2.LosAngeles1.Level3.net ok)
4.68.102.34 RTT: 91ms TTL:170 (ge-1-2-52.car1.LosAngeles1.Level3.net ok)
63.214.153.106 RTT: 98ms TTL:170 (ge2-0.core1.lax.netzero.net probable bogus rDNS: No DNS)
* * * failed
* * * failed
* * * failed
64.136.60.76 RTT: 92ms TTL: 47 (gladsome.com ok)
(Gladsome.com is the host where electro-music.com resides.) _________________ --Howard
Axiom
G2 patch files: 28
Posted: Fri Jun 10, 2005 1:06 pm Post subject:
I've experienced issues trying to reach EM today, in the first afternoon. About the router issue... mmm seems like if this DLink goes in loop and doesn't let the signal to pass through. Dunno... too few details to have a logic idea of what cause this problem
Luca _________________
Posted: Fri Jun 10, 2005 1:09 pm Post subject:
I restarted the httpd today. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Audio files: 227
Posted: Fri Jun 10, 2005 1:30 pm Post subject:
I don't think the Dlink is the problem because it doesn't block other sites. Why it won't connect is something I can't fathom. Almost like that router doesn't like double stuffed NAT packets.
I'm looking at getting another host provider service anyhow. I hate problems like this. _________________ --Howard
seraph
Editor
Audio files: 33
Posted: Fri Jun 10, 2005 3:24 pm Post subject:
I am no wizard but your last three posts, Howard, reminds me of Jack Torrance in the movie The Shining do you have an ax here's Howard  _________________ homepage - blog - forum - youtube
| Quote: | | Don't die with your music still in you - Wayne Dyer |
