Appendage Ribbon Controller PC Board Orders for 2020
Page 3 of 3 [57 Posts]
Goto page: Previous 1, 2, 3
Benjamin AM
PostPosted: Thu Jun 14, 2018 10:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Just curious if anyone has done a eurorack Appendage yet.
PostPosted: Thu Jun 14, 2018 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm pretty sure the build thread shows some examples of what people came up with for Euro....
PostPosted: Thu Jun 14, 2018 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
While recovering from my surgery I decided to finally adapt the original Appendage PCB to a 54 HP Euro Module. The adapter PCB is completed, has been loaded with the FP components and mated to a populated Appendage PCB, calibrated, and 95% electrically tested.
Here are images of the original PCB, the new Euro adapter PCB, and the front panel which should be arriving on June 20, 2018. At that time I shall be testing the form, fit, and function of the module in my euro case.
My next post will be some pictures of the completed module and PCB's.
The build manual will modified to accommodate the original non-specific format or the new Euro Rack format.
See the images below. Please CLICK on each to bring up a much greater resolution image.
 Filesize:  271.57 KB
 Viewed:  722 Time(s)
 Filesize:  353.91 KB
 Viewed:  702 Time(s)
 Filesize:  167.02 KB
 Viewed:  703 Time(s)
PostPosted: Thu Jun 14, 2018 5:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bill, I'll put my hand up for a front panel/pcb to go with the blue pcb I already have from you Smile
PostPosted: Thu Jun 14, 2018 6:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
The project is moving quickly and when all the testing is completed, most likely by early July, you will be contacted. I want to make sure everything is perfect. Well, close to perfect as I can get it. Wink I am hoping to get a cheaper source for front panels to. Kits will be sourced through Synthcube.
PostPosted: Thu Jun 14, 2018 8:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
If it fits my budget at the time (it's been an "interesting" year of medical bills) I am definitely interested as well. I've got the blue board populated, and a gigantic softpot (they didn't have 500mm so I said WTH let's go with 750!) ready to go, just needing a mount for the softpot and all the jacks/controls. A panel PCB would make life SO much easier even if I don't mount it in my main Euro case.
PostPosted: Thu Jun 28, 2018 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
More progress for Euro Adaption for the Appendage
https://www.muffwiggler.com/forum/topic-92638-25.html
