R_Gol
Posted: Thu Apr 23, 2020 5:25 am Post subject:
Cacophonator question |
Hi all
I'm about to build this lovely synthbox called Cacophonator: https://theremin.us/Circuit_Library/cacophonator.html
I have few questions regarding the components:
1. Can I replace cr1 diode (MUR210G) ? if so with what other diode ?
2. is the 2200uf polarized capacitor ( c7) can be 16v or should be 50v? is that true for all polarised capacitors? 16v is enough ?
3. all the frequency potentiometers should be A type or B type ?
Thanks for helping! |
Steveg
Joined: Apr 23, 2015 Posts: 184 Location: Perth, Australia
Posted: Thu Apr 23, 2020 5:47 am Post subject:
Hi R_Gol,
Welcome to the Lunetta forum.
The MUR210G is a fast recovery diode with a 2A rating ... check for fast recovery diodes in your preferred suppliers catalogue. the purpose of the diode is to short the power supply if the battery is inserted backwards. R10 limits the current to .4 A so a 1A diode would probably be happy. Whether it actually needs a Fast recovery diode here is another matter which I am not qualified to judge. If you were constructing the kit connected to a power supply the I would just leave it out.
16V should be fine for a 9V supply.
Linear pots would be usual but putting a log pot in there would not be a huge problem. It isn't like you have precision control.
Enjoy,
Steve |
Posted: Thu Apr 23, 2020 6:37 am Post subject:
note that A/B labels for potentiometers can differ per manufacturer. The pots I used to use had A for linear and B for logarithmic.
Now that I use alpha pots most of the time it is the other way around. For this circuit (and other circuits with the same oscillators)
I would actually recommend using antilog pots. Except for maybe RV5. _________________ "My perf, it's full of holes!"
R_Gol
Posted: Thu Apr 23, 2020 6:58 am Post subject:
| Steveg wrote: | Hi R_Gol,
Enjoy,
Steve |
Thanks for your replay!
I've got 1n4148 that is fast recovery diode but with 0.3a rating. should it be fine as-well? |
Steveg
Posted: Thu Apr 23, 2020 5:42 pm Post subject:
Well, 0.3A is less than 0.4A so no. The rule of thumb is that you would want it to exceed the predicted current by at least 50%.
But if you doubled the value of R10 then the current would be safe for your 1N4148.
Now if you have a cheap stock of 40106 chips and you are using a socket so the chip can easily be replaced then you may not need that diode at all unless you think you are prone to inserting batteries backwards. The circuit will function identically without it. |
Steveg
Posted: Thu Apr 23, 2020 9:43 pm Post subject:
| D'Oh! Thanks Phobos, I totally forgot to calculate power dissapation. |
R_Gol
Posted: Fri Apr 24, 2020 1:18 am Post subject:
got another question on another circuit and I didn't want to open another topic for that -
I created this cmos cowbell circuit https://hackaday.com/2015/04/10/logic-noise-more-cmos-cowbell/
instead of using two 40106 osc I changed it for two 4046 osc - the rest is the same.
My problem is that the envelop seems to sound good in its attack but as you can hear there is addition quieter sound accompany the cowbell sound that should not be there.
here is the sound example: https://www.dropbox.com/s/gcvwegxzxtn1jlf/example%20cmos%20cowbell%20issue.mp3?dl=0
I wondering if its because the circuit still on two breadboard and the moment I will solder it the problem will be gone or its something in the circuit ?
Thanks! |
Joined: Apr 03, 2004 Posts: 24538 Location: The Netherlands, Enschede
Audio files: 299
Posted: Sat Apr 25, 2020 1:31 am Post subject:
| R_Gol wrote: | | My problem is that the envelop seems to sound good in its attack but as you can hear there is addition quieter sound accompany the cowbell sound that should not be there. |
Yeah, something is bleeding trough somewhere ... there could be a couple of reasons for that ..
as you suggested it might be breadboard layout, you could test that with trying different layouts.
or it could be that a bit of load (say 10k or so) to ground after the audio VCA helps - I would expect a bit of natural bleed trough from this particular VCA type (without having ever built it like this ).
it may als be a power supply thing, when your supply happens to be a battery you could try to put a capacitor of ... like 470 µF / 16V over it .. or maybe use shorter supply wires.
then it might be a local issue like not having decoupling caps over the CMOS IC(s) supply pins (try something like 100 nF asclose to the chip as possible) .. or having some inputs floating on CMOS chips.
or something else ... that I could not think of the youtube demos sounded cleaner ... _________________ Jan
R_Gol
Posted: Sat Apr 25, 2020 2:24 am Post subject:
| Blue Hell wrote: | | R_Gol wrote: | | My problem is that the envelop seems to sound good in its attack but as you can hear there is addition quieter sound accompany the cowbell sound that should not be there. |
or something else ... that I could not think of the youtube demos sounded cleaner ... |
I added a 10nf capacitor between the marked placed in the image and gnd. it seems to help. those it make any sense ?
https://imgur.com/a/GfjBYJD |
Audio files: 299
Posted: Sat Apr 25, 2020 2:35 am Post subject:
That would filter off some highs .. so yes that would help .. does it not become too dull overall now? _________________ Jan
R_Gol
Posted: Sat Apr 25, 2020 3:05 am Post subject:
| Blue Hell wrote: | | That would filter off some highs .. so yes that would help .. does it not become too dull overall now? |
It took some charcter from the sound but it solves some 'ticks' sound from the lfo that triggered the vca |
