pch2csd: call to arms
Page 3 of 3 [58 Posts]
Goto page: Previous 1, 2, 3
SoulState
PostPosted: Mon Jul 20, 2020 5:04 am    Post subject:   Reply with quote  Mark this post and the followings unread
Does anyone have compiled vsti-s from these patches to check them out?
gleb812
PostPosted: Mon Jul 20, 2020 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, SoulState!
I usually compile main part of the code for new models to compare them with Nord. Otherwise, pch2csd gives you csound code, ready for realtime or offline...
Visit PCH2CSD site
https://github.com/gleb812/pch2csd
SoulState
PostPosted: Mon Jul 20, 2020 6:16 am    Post subject:   Reply with quote  Mark this post and the followings unread
I have a G2 Demo. If i convert patch from it, can i make it polyphonic?
And do you have some audio demos or comparisons of converted patch sound to the real G2 somewhere on souncloud or youtube maybe?
gleb812
PostPosted: Mon Jul 20, 2020 7:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure. You can build Nord patches using demo, and then they can be as much voices as possible for offline render. In RT sure it depends on your PC power.
Thanks for the idea about YouTube/SoundCloud demo. We should definetely do this. Right now we are close to finish of OSC section, so it will be the first demo.
We can connect in Telegram, and I can provide the use cases and several basic how-to's.
Visit PCH2CSD site
SoulState
PostPosted: Tue Jul 21, 2020 1:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok i write my tg in PM then
gleb812
PostPosted: Mon Aug 09, 2021 9:30 am    Post subject: Sequencers Reply with quote  Mark this post and the followings unread
Hi folks! Long time no see. I am finally on my vacation after all.
So here we have a new update - some bug fixes and all 5 units from Sequencer group are done.
We continue to reverse some units from FX group, and also I plan to advance on Envelopes.
As always - any questions, suggestions etc are very welcome! see you soon!
G
PS the picture with Nord's units is not related to the its right side. It is just to show that we did a lot of test prior to posting it here)
 Filesize:  44.58 KB
 Viewed:  3965 Time(s)
.JPG
 Filesize:  131.05 KB
 Viewed:  196 Time(s)
.JPG
Visit PCH2CSD site
gleb812
PostPosted: Thu Aug 19, 2021 2:30 am    Post subject: digitizer Reply with quote  Mark this post and the followings unread
Hi people!
Meanwhile the digitizer is online. I've personally never used it, but anyway let it be. As you may see, bit reduction works fine (see for bottom LFO waveforms). Rate reduction gives slightly different results (e.g. the parasite amp modulation is different for upper waveforms). My theory is that the Nord sine wave has some higher (in)harmonics, which in turn leads to more harsh outcome under sampling rate reduction. Maybe later I will try to research more.
Until next time!
BTW modules table on github is not sane for now. We will fix that soon. Also, installation procedure changed. See for more details on github.
 Filesize:  52.1 KB
 Viewed:  209 Time(s)
Visit PCH2CSD site
cube666999
PostPosted: Wed Feb 12, 2025 7:40 am    Post subject: At what stage is this project currently on a scale of 1-10? Reply with quote  Mark this post and the followings unread
Hello everyone, especially the people who created the pch2csd project.
I am extremely impressed with this project.
When will it end?
