zaphod betamax
Posted: Sun Nov 12, 2023 3:05 pm Post subject:
Experimental Noise Oscillator - First Run |
https://youtu.be/Nbxs4SlwJyE
This uses a CV controlled CD4093BE for audible oscillator (clock)
and a Ring Oscillator made with the CD4093BE for data.
Also uses a CD4089 Binary Rate Multiplier that is modulated
by a CD4517BE SR.
The output of the CD4517BE is converted to analogue via a voltage follower (the only non-CMOS device) and ported to my home made AD envelope (off camera -based on the Thomas Henry Easy AD envelope) controlling a LPG consisting of a 12db/octave LPG with photo FETS.
Too soon for schematics are this was born on the breadboard and I have
to transcribe to paper at a later date.
Please note the scope: This is set to 1ms/div Horiz and 1V/div Vertical.
A very weird circuit which flies the 5V flag! |
Top Top
Posted: Wed Nov 22, 2023 11:11 am Post subject:
Sounds cool. Would love to see a schematic.  _________________ ∆ A.M.P. ESOTERIC ELECTRONICS ∆ |
zaphod betamax
Posted: Wed Nov 22, 2023 2:38 pm Post subject:
Will have to rebuild this on breadboard as I am short of breadboard space.
Before I disassembled it had 8 choices of noise.
| Top Top wrote: | Sounds cool. Would love to see a schematic.  |
zaphod betamax
Posted: Tue Nov 28, 2023 7:38 pm Post subject:
I never recorded the schematic before dissemble so I was never able to
get it to the video sound ever again when I rebuilt.
However I am working on a new version...stat tuned.
I made it simpler and removed the CD4089, now it is just a
CD4093 and a CD4517. |
zaphod betamax
Ruebezahl
Posted: Mon Dec 18, 2023 9:26 am Post subject:
Cool, i like it! Noisy sounds that are rather uncommon in Lunettas! and the rythmic changes make it more interesting too. _________________ https://soundcloud.com/ruebezahl |
zaphod betamax
Posted: Mon Dec 18, 2023 5:30 pm Post subject:
Lots of stuff.
The frequency of the "VCO" requires an external source,
so it is connected to a three stage ASR. (using one stage)
At the time I left unused gates floating and this added to the wrecking.
Like a dumbass I never recorded the breadboard schematic
(because I thought I knew if off by heart ((I did not))
So this circuit for the first video is lost to time.
I do know I used a CD4093BE as the "VCO", a CD4522BE and a CD4517BE.
But how I wired it up to get the first video sound I was never able to replicate!
However, I am working on a new noise make called the LMNO or
Lunetta Mutated Noise Oscillator, so all is not lost!
| PHOBoS wrote: | funky
Are those rhythmic changes between all that fuzzyness caused by the VCO being sequenced ? |
Last edited by zaphod betamax on Mon Dec 18, 2023 5:40 pm; edited 3 times in total |
zaphod betamax
Posted: Mon Dec 18, 2023 5:31 pm Post subject:
The newest version of the LMNO...
I will not forget the schematic this time!
https://youtu.be/eFxaBwoOToQ
File under Obsolete Electronics.....
Getting closer to getting off the breadboard and becoming a module.
-Added an encoder and LEDS to switch through Mode 1 to 4.
CMOS used: CD4093BE, CD4522BE and CD4517BE
No programming code required to operate.
Bass Drum by Korg Monotribe. |
