Build Pictures 2025
Page 3 of 3 [56 Posts]
Goto page: Previous 1, 2, 3
analogmonster
PostPosted: Sun Aug 24, 2025 3:05 am    Post subject: 8 CV to MIDI converters
Subject description: CV Option / expander module
Hello everyone,
I developed a module to expand my 8 channel CV2MIDI - Converter in direction towards a kind of real fun "Modular Sequencer":
It consists of 8 independent channels controlled by 8 "control cells" on the right side.
The module is pure analog with 4 PCBs hosting 2 channels each:
(Above: Please note my "sustainable" (to abuse the bad word of this decade) PCB approach by using very old and used vintage resistors with clear-text resistor values coming from the pre-color-code and pre-pcb times (in fact they propably served in Adolf's table-top radios during the "Third Reich" ๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚) and found their way to me when I bought an electronic convolute from the heritage of a dead electronic nerd on ebay...)
Anyway, this module offers a variety of new sequencer modes when used in conjunction with my 8 channel CV2MIDI Converter:
The module provides 8 CV sources and 8 clock sources (CLK), which are adjusted by corresponding control pots.
The clock behavior is controlled by cells on the right module side.
Witch each controller cell you set the clock operation for the corresponding channel / step.
Switching it to "ON" means a permanent 5V output at the clock output jack.
Switching to "CLK" means a normal clock operation.
Both are indicated with corresponding LEDs.
For working with the CVOption module a new program was developed for the CV2MIDI converter (Program 5).
This program interprets a 5V input at a clock jack as "lock", where the sequence executed by the CV2MIDI converter changes the sequence direction, so you can define a new sequence length.
But if you define the lock as CLOCK based the sequence cursor sometimes returns at the lock position, and sometimes not. The sequence gets a randomized length.
The situation becomes really weird if you define 2 CLK locks at different positions in the sequence with different speed rates.
Then the sequence cursor is caught in different parts of the sequence at different times like a lost ping-pong ball jumping to random segments.
Above: PCBurger and Pasta ๐Ÿ”๐Ÿ
Above: As purely analog, channel CV adjustments on the back side
The Circuit
Above: Schema of a single channel
Each PCB (2 channels) has its own PSU adaptor, as the LEDs consume a lot of current.
Both front panel pots are 1k.
The CV unit (U2) operates from exactly 0V to 5V adjusted with the OFFSET and AMPLITUDE trims.
The LFO (A5) operates from 1Hz to the lower audio range.
The clock operation selection logic (Q1, Q4) is controlled by the front panel switch (J5). The clock output modes are set to 0V and 5V and provided at the output via the discrete "OR" logic of Q2 and Q3.
Offer
Spare PCBs, Gerber and LtSpice files can be obtained directly from me, just send me an email (No PM!).
electrotech
PostPosted: Wed Aug 27, 2025 2:28 am    Post subject: Reply with quote  Mark this post and the followings unread
That's a very impressive (& professional) build you've done there.
I also like the use of the old resistors with the value printed on them rather than those modern five-band ones with indecipherable colours !
Andy
analogmonster
PostPosted: Thu Aug 28, 2025 10:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Andy
Thanks ๐Ÿ˜Š
I must admit that I've never seen such resistors before ๐Ÿ˜ฎ๐Ÿค”
Here the next level: I added ratcheting as new program to the CV2MIDI converter:
The Peasant
PostPosted: Fri Aug 29, 2025 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi everyone!
I finally finished the videos for my tube synth:
https://youtu.be/FPosNWLeFhI
https://youtu.be/f6_HdbAmGvQ
Take care,
Doug
The Electronic Peasant
www.electronicpeasant.com
PostPosted: Sun Aug 31, 2025 5:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Very Cool, thanks for sharing!
my synth
PostPosted: Sun Aug 31, 2025 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
It sounds great! Good job Smile
JacobWatters.com
