Nord modular G2 zipped patch archive
Page 1 of 6 [138 Posts]
PostPosted: Sun Nov 20, 2005 8:41 pm    Post subject:  Nord modular G2 zipped patch archive
Subject description: Updated: 2016-08-04
UPDATE :: see http://electro-music.com/forum/post-410618.html#410618 please before downloading from here.
and also http://electro-music.com/forum/post-421139.html#421139
All Nord Modular G2 patches posted on this forum, zipped up in an archive with some HTML documents to allow for easy off line browsing. The first official electro-music.com off line Nord Modular G2 patch archive.
Unzip to any folder you see fit, then browse the archive through index.html.
From time to time a fresh archive will be posted here, although I'm not sure yet in what form or in what time frame we are going to do this.
Suggestions for improvement are welcome.
archive_2014_03_13.zip
Patch archive info as comma separated ASCII
 Filename:  archive_2014_03_13.zip
 Filesize:  213 KB
 Downloaded:  3882 Time(s)
electro_music_patch_archive_2014_03_13.zip
The patch archive
 Filename:  electro_music_patch_archive_2014_03_13.zip
 Filesize:  20.22 MB
 Downloaded:  3637 Time(s)
seraph
Editor
Editor
Audio files: 33
PostPosted: Mon Nov 21, 2005 12:34 am    Post subject: Reply with quote  Mark this post and the followings unread
excellent job Jan Exclamation this is a great addition to an already impressively cool site Very Happy
Hyde
PostPosted: Mon Nov 21, 2005 1:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I can't seem to unarchive. I have tried Stuffit Expander and BOMArchiveHelper and I get errors at the end. But man - I am GLAD to see that this finally happened. Hopefully it will get updated every so often as well. Smile
*update* - Tried another way and got it to open. You might want to recompress using another program or a different setting because it might have problems unarchiving on a Mac.
monobass
G2 patch files: 12
PostPosted: Mon Nov 21, 2005 2:06 am    Post subject: Reply with quote  Mark this post and the followings unread
I also cannot unarchive on my Mac... never had this problem before.
Looking forward to cracking it open Wink
PostPosted: Mon Nov 21, 2005 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
The file seems OK. ( OS X 10.4.3 )
Flickr
monobass
G2 patch files: 12
PostPosted: Mon Nov 21, 2005 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm using OSX 10.3.5
Steve
Audio files: 228
PostPosted: Mon Nov 21, 2005 5:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks to Blue Hell, Jan, for doing such a great job at creating this stand-alone archive. This is more than just a zip file of the patches, it comes with a full HTML index which maintains the context of the patches with links back to the origianl discussion, and acknowledges the author/creators. Great job... thumb up
props
PostPosted: Mon Nov 21, 2005 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks,
Re. the unzip problems :
I used WinZip (8.1 probably) in maximum compression mode. I'll later try to rezip using the default settings instead.
When that still doesn't work there are some other options to try, or maybe we could make a Mac native file as well, sit I guess ?
monobass
G2 patch files: 12
PostPosted: Mon Nov 21, 2005 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
A zip should be fine, I've never come across one that wouldn't open in OSX before. It's not like Winzip 8.1 is brand new or anything.. weird.
BobTheDog
PostPosted: Mon Nov 21, 2005 6:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for this.
Andy
PostPosted: Mon Nov 21, 2005 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I made a new zip with WinZp 8.1 making sure to use the standard compression setings, does this help ?
monobass
G2 patch files: 12
PostPosted: Mon Nov 21, 2005 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan, this one opens fine with Stuffit Expander, but not with OSXs internal unzip programme, I guess they updated that in 10.4.*
Cheers for redoing it.
Steve
PostPosted: Mon Nov 21, 2005 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
What I had also done before, too lazy to retype the file name, was to empty an old zip and drag new files into it renaming just the last one or two digits of the file name. I'll not do that again either :-)
And I'll not update WinZip .. unless someone sends me one of these fab. new "secure zips", then I'll have to ... unless it's the PkZip vision on safety, which is not compatible ... of course.
Zip is not Zip no more I guess.
cebec
G2 patch files: 31
PostPosted: Mon Nov 21, 2005 7:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Jan !
Nodular
G2 patch files: 7
PostPosted: Tue Nov 22, 2005 2:36 am    Post subject: Reply with quote  Mark this post and the followings unread
THANKSTHANKSTHANKS Very Happy
Hyde
PostPosted: Tue Nov 22, 2005 5:32 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah - 'thanks Jan!' Wink
PostPosted: Tue Nov 22, 2005 5:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, actually Hyde, you know, you started this a while ago by posting a ref. to your zip file. So: thank you :-)
Hyde
PostPosted: Tue Nov 22, 2005 5:47 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah but without YOU taking up the cause, writing the script, getting it all approved, and pushing it through we'd still have nothing...
I think alot of people here are going to appreciate it in the months to come - it will end up being quite handy. I appreciate all your hard work and enthusiasm for this particular facet of this board and community. I really do.
PostPosted: Tue Nov 22, 2005 6:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm watching the download counter ;-)
(actually it 32 higher than it says, I erased it with the re-upload).
cappy2112
PostPosted: Thu Nov 24, 2005 8:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm watching the download counter Wink
Thanks a lot for doing this!
cappy2112
PostPosted: Thu Nov 24, 2005 8:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks,
Winzip 9.0 (and previous, I think) has two levels of "Maximum compression", one which "winzip" considers portable, the other level Warns you that the archive may not work on other systems.
I don't remember it warning the user about the compatibility issue, on versions of Winzip prior to 9.0.
See attached screenshots
Max compression- may not be portable
 Filesize:  45.46 KB
 Viewed:  85426 Time(s)
 Filesize:  69.56 KB
PostPosted: Fri Nov 25, 2005 4:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Thx Cap.
I deleted your 1st post, as it was included in the 2nd as far as I could tell.
ps
PostPosted: Mon Nov 28, 2005 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I love you all!!!
sebber
G2 patch files: 33
PostPosted: Tue Nov 29, 2005 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great, thankyouspankyou.
While we're at it ():
would it be a good idea to include Robs 298 collected newslist patches to the 1379 patches from the forum?
BTW, this server has become fast! Thanks for that, too. May the be with you.
Audio files: 228
PostPosted: Tue Nov 29, 2005 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, we moved to a new server. We are still working out the bugs. Posted Image, might have been reduced in size. Click Image to view fullscreen.
