 Forum index » Instruments and Equipment » MIDI Controllers and Interfaces
Looking for Midi merger recommendations
Page 1 of 1 [11 Posts]
cappy2112
PostPosted: Fri Dec 02, 2005 6:32 pm    Post subject: Looking for Midi merger recommendations
Subject description: Midi processing tools
Can anyone recommend some small, portable (not studio or rack mounted) (pocket or almost hand-held sized) Midi mergers?
I know Anatek used to make one, but I don't think they are around any more.
Who else makes these?
I need a 4 inputs minimum, and would prefer some filtering or midi procesing capabilites, if any of these samll ones have this kind of power.
Can these be powered just from the 5V Midi line ?
Audio files: 308
PostPosted: Fri Dec 02, 2005 7:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe something like this : http://www.midi-classics.com/h/h6679.htm
Typing "midi merger" into google gives a lot of hits, but not many usefull ones I believe.
jksuperstar
G2 patch files: 18
PostPosted: Fri Dec 02, 2005 11:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
An Emagic AMT4 would have everything your looking for. I have the AMT8 (8 ins & outs), but I know they make a small 4in/out version. USB interface, but can operate in stand-alone mode merging/routing/filtering. It can store 16 or so of these maps selectable while in stand-alone mode. It also automatically detects which device is sending clock, and broadcasts it to the other ports.
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Dec 03, 2005 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
arrow http://www.m-audio.com/products/en_gb/Merge2x2-main.html
go get one (or two) Very Happy
egw
G2 patch files: 8
PostPosted: Sat Dec 03, 2005 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like the Midi Solutions quadra merge is the way to go for you.
I have a couple of these and never had any problems.
cappy2112
PostPosted: Sat Dec 03, 2005 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
cappy2112
PostPosted: Sat Dec 03, 2005 12:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks. I will take a look.
K
PostPosted: Sat Dec 03, 2005 2:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know how smart it is to merge four midi data flows.
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Dec 03, 2005 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have never tried that but it doesn't sound like a great idea Cool
egw
G2 patch files: 8
PostPosted: Sat Dec 03, 2005 5:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sometimes it's not only smart but may be necessary.
Suppose you have multiple midi controllers, such as a keyboard, a fader box, a sequencer, and a drum pad. And you have a couple of sound modules you would like to control from any or all of the controllers. Then you need to merge the streams.
In my studio I have 16 things that can be midi sources, and 20 things that can be destinations. Any of the sources can control any of the destinations, without reconfiguring hardware or cables. The network is based on midi merges and switches, no computer. Maybe one of these days I'll post a diagram up here.
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun Dec 04, 2005 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I guess many are both sources and destinations.
