G2 Display bug
Page 1 of 1 [4 Posts]
mother misty
G2 patch files: 130
PostPosted: Tue Apr 11, 2006 5:05 am    Post subject: G2 Display bug Reply with quote  Mark this post and the followings unread
Hi all,
I've discovered another minor bug in the G2 display.
When you take an ADH env and assign the 'hold' parameter to a knob the display says "release".
(I've emailed this to clavia aswell)
Audio files: 232
PostPosted: Tue Apr 11, 2006 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
You mean the AHD module, I guess.
The module seems to be incorrectly named because the D is really the R.
This is from the online help file:
    EnvAHD
    The Attack-Hold-Decay envelope is an envelope with three stages: Attack, Hold and Release. The AHD Envelope is well suited for audio gating applications, for example. See also Common Envelope Generator parameters
Anyway, when I assign the H to a knob it says "Hold" and if I assign the D to a knob it says "Release". Maybe the module should be renamed AHR.
mother misty
G2 patch files: 130
PostPosted: Tue Apr 11, 2006 6:50 am    Post subject: Reply with quote  Mark this post and the followings unread
ahh, you're right, I mean the decay parameter, not the hold parameter.
It's confusing if you assign a decay parameter and the displays says release
Audio files: 232
PostPosted: Tue Apr 11, 2006 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, it's also confusing to adjust the release when it says decay. Very Happy
Well, maybe Clavia will send out a bug-fix release for the G2 one of these days - with a fixed filter bank thrown in. Wink
