 Forum index » How-tos » Surround and Sound Reinforcement
What is wrong with X.1 systems
Post new topic   Reply to topic Moderators: diatonis, mosc
Page 2 of 2 [32 Posts]
Goto page: Previous 1, 2
Audio files: 227
PostPosted: Mon Apr 03, 2006 12:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey, Diatonis, what a nice batch of gear... Smile
diatonis
PostPosted: Mon Apr 03, 2006 1:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've heard the TC 6000 (I don't own one) and was very impressed to say the least Cool
There's also a version of the GigaPulse included in the Tascam GigaStudio 3 and it sound very good. You can place things anywhere in the sound arena - it doesn't pan as its an impulse type of reverb. maybe dynamically morphing between positions may work. NOTE: This version of GigaPulse only works from within GigaStudio. It's not a vst plugin etc... You'll need to get the VST plugin to use it for anysounds outside of gigastudio.
I've also used 3 stereo reverbs along with 3 stereo delays to create a simplified yet somewhat connected 5 channel reverb. Insert a stereo delay followed by a stereo reverb into 3 different tracks (Front, Surrounds, Center/MuteLFE. The reverbs would be set to the same parameters with no delay or early reflections. You are using the 3 delays to simulate early reflections. You can then send the same signal to all 3 stereo effect tracks. Vary the delays to position the sound, simple haas effect. Its not perfect but does work.
diatonis
neilwilkes
PostPosted: Wed Apr 05, 2006 1:06 pm    Post subject: Re: What is wrong with X.1 systems Reply with quote  Mark this post and the followings unread
Kassen wrote:
neilwilkes wrote:
Laughing Laughing Laughing Laughing Laughing
Ok, theb tell me what you use to generate 5.1 sound, how you mix it and what reverb you use.
Then we'll talk.
No Problem.
I will start a new post though, as it's not right in this one.
And I assume we are talking a true, diuscrete 5.1 mix from a multitrack and not a stereo upmix?
www.opusproductions.com
Multichannel Audio Specialists
Kassen
PostPosted: Sun Apr 09, 2006 8:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
No. in the case of 5.1 I mean generating, processing and mixing sounds in true 5.1. Doing "fake" stereo or "upmixing" mono or stereo channels is trivial.
What would you use for example to make the sound of rain falling on small resonant bodies covering a area of three by three meters to the left and front of the listener, then move the area where "rain" falls to the right-front while shrinking it to two by two and while keeping the resonant bodies in their place? How would you go about it if the resonant bodies were to be placed on a imaginary conveyor belt and so move towards the listener while keeping the rain's location static?
I imagine you couldn't get exactly this effect like wave-field synthesis could but how close could you get? What tools would you use?
Kassen
neilwilkes
PostPosted: Mon Apr 10, 2006 2:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I've never even tried to achieve something like that effect - I don't work in FX and SFX. However, I will have a think about it, and think that with a little effort I could come very close to this.
What I was trying to discuss is obviously different - and you keep moving the goalposts too, which doesn't help matters too much.
In one breath you state outright that you don't like x.1 systems as they cannot localise, then start trying to tell me stereo does a better job???
3phase
G2 patch files: 141
PostPosted: Thu Apr 27, 2006 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
neilwilkes wrote:
http://www.verber.com/mark/ce/cables.html
http://www.theaudiocritic.com/downloads/article_1.pdf
(this one has the 10 biggest lies about audio - well worth reading)
Enjoy the comedy!
I stopped reading after the "vacuum tube lie " because the author imideatly prooved to be an idiot there...
So i ask myself now if there is something about the monster cables Wink
3phase
G2 patch files: 141
PostPosted: Thu Apr 27, 2006 4:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
And regarding the topic..
I agree with Mosc here...Its a publishable creativ possibility electronic musicans was waiting for a long time for...
I installed numerous big 5.1 and 7.1 studio facilitys a couple of years ago...
And had to the testdrive of the regie rooms...
I allways was currious what sense a center speaker can have in musical terms... I mainly was interested myself in the quatro...
But... this has changed... i would give up the rear channels
3 way... LCR...this is just great... 3 dimensional... a real middle...
all mushiness gone, precission...the impact of the roomacoustics minimized...
