 Forum index » Clavia Nord Modular » G2 Patches - Completed » Sequencer - interactive
AliasSeq
Page 1 of 1 [7 Posts]
dorremifasol
G2 patch files: 49
PostPosted: Tue Apr 29, 2008 12:07 pm    Post subject: AliasSeq Reply with quote  Mark this post and the followings unread
You know when you design a simple patch, and then you start adding modules and it ends being a totally different thing? Of course you do!
It's nothing special since I'm far from being a G2 guru, but I'm pretty proud of this one, so let me share this patch evolution with you.
The filter (I love this one) is cannibalized from a filter test of other user, which I don't remember now, that was HIS great work.
By the way, I kept it using only one DSP so it can be played in the G2 demo. Enjoy!
AliasLead.pch2
the patch that started it all, provoking low quality oscillators to add imperfection to the sound before the filter
 Filename:  AliasLead.pch2
 Filesize:  2.15 KB
 Downloaded:  1945 Time(s)
AliasLead2.pch2
the same with a "living" oscillator
 Filename:  AliasLead2.pch2
 Filesize:  2.19 KB
 Downloaded:  2072 Time(s)
AliasLead4.pch2
and now with a little sequence
 Filename:  AliasLead4.pch2
 Filesize:  2.95 KB
 Downloaded:  1955 Time(s)
AliasSeq1.pch2
using the rest of DSP to bring drums and other details
 Filename:  AliasSeq1.pch2
 Filesize:  5.46 KB
 Downloaded:  1903 Time(s)
AliasSeq2b2.pch2
and the final patch
 Filename:  AliasSeq2b2.pch2
 Filesize:  5.9 KB
 Downloaded:  2028 Time(s)
Albert
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Apr 29, 2008 8:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for posting. Sounds very analog Smile
dorremifasol
G2 patch files: 49
PostPosted: Tue Apr 29, 2008 11:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you G2ian! I'm glad you mention the analog sound. I'm a bit obsessed abut obtaining the most analog sound out of the G2. Perhaps because I can't spend money on buying a real analog synth.
By the way, have you noticed that the main waveform I use for the sequence (TriSaw) has only positive cycle? Seems a bug to me. In order to achieve the maximum dynamic range I must eliminate the DC offset by hand. Sad
The DualSaw in the Osc B model also has double the amplitude than the other waveforms. (?)
Albert
iPassenger
G2 patch files: 78
PostPosted: Thu May 15, 2008 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Probably my fave basic synth sound yet out of my Nord.. i can't believe how nice the distorted filter sounds on the bit reduced waveform.. Brilliant. Smile
Thanks
iP (Ross)
dorremifasol
G2 patch files: 49
PostPosted: Thu May 15, 2008 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's quite a compliment, thank you very much! Very Happy
Albert
varice
Audio files: 29
G2 patch files: 54
PostPosted: Fri May 16, 2008 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I like the final result of the evolution of these patches!
Yes, this is a bug in the Demo Software. It was mentioned here:
http://electro-music.com/forum/topic-13420.html
varice
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Mon Oct 06, 2008 7:19 am    Post subject: Reply with quote  Mark this post and the followings unread
ye sounds like a arcade game Cool great
