PCBs for Thomas Henry's X-4046 VCO
Page 7 of 12 [296 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12 Next
tehskull
PostPosted: Wed Jul 13, 2011 4:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finished mine last night. Working on calibrating it now. I have only been doing DIY synths for about 3 months. This is my 4th completed module. Calibrating is going OK so far. When the VCO gets into higher octaves, it cuts off. Powering it off then on brings it back once the frequency is turned back down. Not sure if this is a characteristic of my 4046 or not (which is a motorola). The HF trimpot is set to maximum resistance per Thomas's calibration instructions. I am going to continue calibrating with tools now. However if anyone has any input it would be gratetfully appreciated. So far I am very happy with it. A very big thanks to Matthias and Thomas for this great project.
Andrew
Completed X-4046 VCO
 Filesize:  2.94 MB
 Viewed:  479 Time(s)
Completed X-4046 VCO & MFOS 1v\oct calibrator
 Filesize:  2.6 MB
 Viewed:  472 Time(s)
PostPosted: Wed Jul 13, 2011 11:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bogus Noise wrote:
I'd be up for buying a couple of these PCBs as well if you do another run. Smile
i still have spares! so how many sets do you need?
Bogus Noise
PostPosted: Thu Jul 14, 2011 12:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, nice one! Sending a reply to your PM now. Smile
PostPosted: Thu Jul 14, 2011 1:40 am    Post subject: Reply with quote  Mark this post and the followings unread
mmmh. maybe you could post this in the thomas henry sub-forum? someone might have experienced this earlier, if it is related to the 4046...
loopcycle
PostPosted: Thu Jul 14, 2011 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
ive built one now and am finding myself here because i could not tune 1v/O whatsoever.
i now see that the ON semiconductor 4046 was a fail and that's what ive got in it now.
i also have the nxp 4046 and will be installing it tonight to see if my results improve.
other than the tracking problems (about a semitone per two octaves), im enjoying the sound of this oscillator.
the "pips" in the triangle wave make it buzzier than others in my system,
but the osc FMs wonderfully and has a very wide range, well down into lfo territory.
edit:
problem #1: 100k in R2...changed that to 390R
i then swapped out the ON PLL for the NXP PLL--wow, what a difference.
it was remarkable how much my waveform improved. i can barely see the pips in the triangle now
its calibrated very well now and it sounds fantastic. cant wait to build the next one
too much coffee too much coffee too much coffee
PostPosted: Fri Jul 15, 2011 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
sorry about the trouble due to the error in the BOM.
all the more i am happy that you are happy now! tried the hardsync? it blew me away...
loopcycle
PostPosted: Fri Jul 15, 2011 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
no problem, was an easy fix =)
and yes, that hardsync is about the hardest ive heard.
its sound competes well with my 5pulser!
thanks again matthias for making these pcbs available, and many thanks to thomas henry for the badass vco
tehskull
PostPosted: Fri Jul 15, 2011 6:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
After swapping my 4046 for an NXP and a few hours of messing about with the trim pots, it is working beautifully! Sounds fantastic with my MFOS 10 step sequencer. The only thing that I do not understand is how to use the hard sync. Everyone says it sounds great so I am dying to hear it myself. Do you need 2 VCO's connected with this? Or does the CV connect to it? Or am i completely wrong lol?
emdot_ambient
PostPosted: Fri Jul 15, 2011 7:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
You have to run an audio input (usually a wave from another VCO) into the Sync In jack. Basically you're turning this VCO into a slave and the external VCO into a master (as far as pitch goes). The master VCO restarts the period of the slave VCO, forcing it to have the same base frequency of the master.
Detuning the slave will create different timbres while maintaining technical pitch unity.
PostPosted: Sat Jul 16, 2011 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
geat to hear it's working now.
so this certain motorola had an issue, or would you have had this issue with any motorola from the same batch? would be an interesting information for scott. the NXP is what i am using...
kupfer_m
PostPosted: Sat Jul 16, 2011 3:01 am    Post subject: Reply with quote  Mark this post and the followings unread
What's the reason for the DC/AC switch for the LinFM input?
When would one use AC and when DC?
Thanks,
Jim
PostPosted: Sat Jul 16, 2011 3:33 am    Post subject: Reply with quote  Mark this post and the followings unread
kupfer_m wrote:
Thanks,
Jim
i think this queston is related to modular synthesis i general, not to this VCO only.
how i understand it (however, my knowledge on these things is not THAT profound):
AC coupled input would remove DC offset, thus not influencing the root frequency of the 4046 VCO that much.
just try it.
emdot_ambient
PostPosted: Sat Jul 16, 2011 3:51 am    Post subject: Reply with quote  Mark this post and the followings unread
just try it.
Or, in another example, if you ran a bi-polar LFO wave (say, a -5V to +5V triangle wave) into a mixer and added +5V DC offset, the resulting wave would go from 0 to +10V, but +5V of that is a DC offset.
If you jacked that into the Lin FM of this VCO and set the switch to AC, the AC coupling (if I understand this correctly) would strip out the +5V DC and leave you once again with a bi-polar modulation source. If that's the case, then you probably don't want that because the negative going part of the modulation source would have no effect on the FM (since this is not a Through Zero VCO).
Flip the switch to DC and the entire signal would go through, making the full spectrum of the modulation source available.
Again...if my understanding is correct!
tokyomatik
Audio files: 6
PostPosted: Thu Jul 21, 2011 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
hi mattias
i have a question about the skew function
i don't understand if it's possible to make it cv controllable
on the pcbs i was checking the in and outs
so i have
triangle
rampoid with his skew control
saw
sine
and pulse
but i don't see in wich way i could modulate the skew
just adding a connection from the tip of a jack to the middle pin (pin2) of the potentiometer could work?
PostPosted: Thu Jul 21, 2011 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
tokyomatik wrote:
hi mattias
so i have
triangle
saw
sine
and pulse
if you take a look at the schematic you will see how it works:
from the VCO core we have the saw and the saw outputs. they are simply mixed manually with a potentiometer (saw and tri on the CW/CCW, mix on the wiper), and buffered with an opamp (voltage follower). actually not mixed, but faded into each other.
therefor the waveshaper PCB provides the saw and a tri input.
to have voltage control you would need at least two VCA circuits, however, you could do it with two vactrols.
tokyomatik
Audio files: 6
PostPosted: Thu Jul 21, 2011 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
vactrols?...it sounds interesting....
but really i don't know where to start..... Sad
why 2 vactrols?
1 for the triangle input & the other for the saw input? i'm already lost... Confused
let me try....(i did something similar to my voice of saturn....)
so, if i connect the positve of the vactrol to the tip of the jack, and the negative to the ground
and then i go to the potentiometer?...mhhh Rolling Eyes
somebody can give some tips....
so sad that an interesting function like modulating the skew is not already on board like for example the xr2206 vco....
peace
rosch
PostPosted: Thu Jul 21, 2011 5:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
the vactrol is a vc resistor. so the ldr part would do the job of the pot, while it's controlled by a cv applied to the led side of the vactrol.
i've seen an example of a voltage divider somewhere around here in a thread not so long ago. that explained quite well how to use a vactrol.
hop.sing
PostPosted: Fri Jul 22, 2011 2:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is an example for a vactrol panner, should work for skew also.
 Filesize:  62.98 KB
 Viewed:  305 Time(s)
PostPosted: Fri Jul 22, 2011 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
that's what i was thinking of (buchla/mark verbos?). i recently ordered some H11F3 optocouplers, which are much cheaper than vactrol. i hopefully will be able to adapt the above ciruit easily...
rosch
PostPosted: Fri Jul 22, 2011 3:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy looking forward for that!!
hop.sing
PostPosted: Fri Jul 22, 2011 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, one could build a little standalone module with the above circuit and use it to crossfade the triangle and saw outputs of the x-4046.
It would be usefulf for many different tasks anyway.
And is probably very easy to build, even on veroboard.
Tobias
tokyomatik
Audio files: 6
PostPosted: Sat Jul 23, 2011 5:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
keep us updated
that could be a really nice addition to the x-4046
Cool
tokyomatik
Audio files: 6
PostPosted: Mon Jul 25, 2011 9:34 pm    Post subject:   Reply with quote  Mark this post and the followings unread
ok forget about modulate the skew...for now
i have more basic problems with the modules
i almost finished the first one, all the pots connected and just 1v/oct + the triangle output.... for a first test should be enough....(??) usually when i have at least sound coming out then i feel more motivated to mount all the rest Wink
but i don't have a 2k tempco right now
so i did maybe something strange, replacing it with a 2 metallic resistors
1k each 1%
and connected the triangle output to hear a sound to see if it works but
nothing....not even a beep!
Rolling Eyes
for the ics i have a nxp HEF4046, i also tried a fairchild but nothing changed
q1 q2 is a LM394....
uffff
ok...where should i start to see what is wrong?
PostPosted: Mon Jul 25, 2011 11:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
check to see if you have any signal on pins 4, 6, and 7 of the 4046.
check power on all ICs
check wiring
tokyomatik
Audio files: 6
PostPosted: Tue Jul 26, 2011 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
hhmmm
so i checked the power at pin 8 & 9 of the 4046
i have 9.47v..... i'm powering my system with +/-12v
if i remove the 2 metallic resistors that i used to replace the 2k tempco
the value change to 9.27v...
