PCBs for Thomas Henry's X-4046 VCO
Page 6 of 12 [296 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12 Next
PostPosted: Tue May 24, 2011 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
the wattage is a max value that the trimmer will survive. it is about the heat they can dissipate without burning Wink
so with 1/2W you are double good Very Happy
raoulblues
PostPosted: Thu May 26, 2011 4:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Mattias!
The PCBs arrived in the mail
merci beaucoup
marvkaye
PostPosted: Fri May 27, 2011 4:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got my PCBs today, they look great!! Can't wait to get started on them. Thanks for making this happen, Matthias and Scott.
wmonk
Audio files: 15
PostPosted: Fri May 27, 2011 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got the PCBs today! Thanks a lot Matthias.
And big applause for Thomas and Scott too! salut
Weblog!
Danno Gee Ray
PostPosted: Fri May 27, 2011 5:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got my boards the other day as well.
SubG (deactivated)
PostPosted: Sat May 28, 2011 1:17 am    Post subject: Reply with quote  Mark this post and the followings unread
GUYS DO NOT BUY ANY PARTS FROM utsource
I did buy plenty of ssm 2210s for this vco from them .none work they are all FAKE.
 Filesize:  19.12 KB
 Viewed:  17363 Time(s)
 Filesize:  71.15 KB
 Viewed:  469 Time(s)
rosch
PostPosted: Sat May 28, 2011 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
have you contacted them about it? i mean, do they refuse to refund you?
loydb
PostPosted: Sat May 28, 2011 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I got 50 2210s from utsource a year or so ago and they're fine (so far!).
SubG (deactivated)
PostPosted: Sat May 28, 2011 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Am buzzy,i wait on reply,atm they don't believe they are fake.
rosch
PostPosted: Sat May 28, 2011 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
i believe it was in the Jürgen Haible section, i read about fake MN3005 from utsource, which they refunded in the end (i haven't looked it up again in detail now)
let's hope you get that sorted.
PostPosted: Mon May 30, 2011 3:30 am    Post subject: Reply with quote  Mark this post and the followings unread
there is an error in the BOM of my documentation. R2 has to be 390R of course!
i corrected building docs for the fonitronik PCBs can now be found here:
TH X-4046 VCO doc 5/30/2011 (rev2)
tehskull
PostPosted: Tue May 31, 2011 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Received 4 nice red shiny PCBs today Smile
Thank you!
TheAncientOne
PostPosted: Thu Jun 02, 2011 5:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got mine today too - thanks Fonik, they look really nice.
I spotted the R2 error, and was about to post, but as usual, you are way ahead of me!
Mike
PostPosted: Fri Jun 03, 2011 1:00 am    Post subject: Reply with quote  Mark this post and the followings unread
errors in the BOM is kind of tradition, isn't it? i think i inherited from ele4music - this is where i come from... Laughing
sompost
PostPosted: Tue Jun 07, 2011 9:00 am    Post subject: Whoaa!! Reply with quote  Mark this post and the followings unread
These PCBs look awesome! You really don't expect me to spoil these works of art by soldering stuff on them, do you. Do you?? Oh, well...
Luckily, I have other projects to complete, so there's still ample time to admire them.
Danke, Matthias, für prompte Lieferung!
SubG (deactivated)
PostPosted: Wed Jun 08, 2011 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Use the real component value on the silkscreen and not the 'R' number,no errors and much easier for those that have to built it.
PostPosted: Wed Jun 08, 2011 2:30 am    Post subject: Reply with quote  Mark this post and the followings unread
i get you point. however, there are pro's and con's.
using just the designators instead of real values makes it easier to change the value afterwards (just change the documentation).
in this special case i don't publish redrawn schematics. i am just providing a PCB for Thomas Henry's circuit, and i wanted the people to use his original schematic. using unique labels instead of values help a lot...
SubG (deactivated)
PostPosted: Wed Jun 08, 2011 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Something else,is it correct that the use of those expensive multi-turn trimmers is a waste of money?
(there is still shifts in the waves when you change frequency after trimming?)
PostPosted: Wed Jun 08, 2011 10:04 am    Post subject: Reply with quote  Mark this post and the followings unread
there won't be shift actually, but a pike. with the trimmers you will be able to remove the shift and offset.
anyways, i myself like multiturn trimmers, since they make it so much easier IMHO. and for the scale and HF trim you definately want multiturn.
anybody built this with single turn? (anybody built this at all yet?)
bubzy
Audio files: 64
PostPosted: Fri Jun 10, 2011 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
i've built mine, but im getting some odd behaviour. it only oscillates when the coarse pot is turned up real high, and as soon as it is turned back down again afterwards the vco stops oscillating. not sure what i've done wrong here, probably best to sleep on it (the idea not the pcb) and try again tomorrow Very Happy
hop.sing
PostPosted: Sat Jun 11, 2011 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
This is my first post on that forum, hello!
I bought those boards at the muffwiggler forum and built them already.
I did the dual version and both units worked alright from the start.
I got two different x-4046 versions from different suppliers (just in case).
One is a motorola, on the other one I could not read the print.
One motorola could not be tuned right, but the others of the same batch worked. Strange.
The unreadable ones where ok.
Both are tunable over at least 6 octaves, thats more than I will ever need.
The sound of the units is great, I have a planB model 15 and a doepfer a-110 to compare and the x-4046 is my favorit already.
The sync sounds incredible, and the pure osc sound (without any modulation) is not as bland as the PlanB and more precise than the a-110.
Thanks for that great project.
Tobias
SubG (deactivated)
PostPosted: Mon Jun 13, 2011 12:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I did send back the 50 ic's,they refunded the total costs incl. the shipping Smile
PostPosted: Mon Jun 13, 2011 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
that's what we wantd to hear!
and thanks go to thomas henry!
hop.sing wrote:
Hi
Tobias
crashlander42
PostPosted: Fri Jun 24, 2011 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do you still have any of these PCB's for sale?
When they plug me in the lights go down in Hong Kong.
My DIY stuff Flickr
Bogus Noise
PostPosted: Wed Jul 13, 2011 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd be up for buying a couple of these PCBs as well if you do another run. Smile
