3phase
G2 patch files: 141
Posted: Fri Jan 12, 2007 7:24 am Post subject:
Fixed Filter Bank |
I start really to agree that such a module must return in the G2 just because its so impossible and over expensiv to patch such a thing on the G2..
I also dont see the NM1 Filterbank as so bad sounding anymore...its really not too bad in relation to the amount of bands...
However..here is a minimal version that just needs around 20% ! oh oh... :-/
It still nowhere as steep as the Nm1 version and has less bands...but..
duo some phase changes in the circuit it gives a quite nice exciter fx...
I tried to tweek it for reasonable sound quality..and being related to the Nm1 filterbank to become a module in the patch converter...
However..if anybody has better tweaks for such a thing bring it up..just..
It should stay below 25 %...
100.65 KB |
| Viewed: |
20856 Time(s) |
 Download (listen) |
| Filename: |
FixedFilterBank.pch2 |
2.34 KB |
| Downloaded: |
2083 Time(s) |
Fozzie
Joined: Jun 04, 2004 Posts: 875 Location: Near Wageningen, the Netherlands
G2 patch files: 49
Posted: Fri Jan 12, 2007 12:15 pm Post subject:
Wouldn't the approach described by Rob on his tutorial pages be cheaper? He describes a simple method for cascading filters. Or would this differ too much sonically?
This is a pic from his site showing the idea:
 _________________ Spinning at ~0.0000115740740741 Hz |
3phase
G2 patch files: 141
Posted: Fri Jan 12, 2007 1:59 pm Post subject:
looks intersting... when tere is time i ve a look into that ..one day i patch something where no rob has been before  |
ian-s
Audio files: 42
G2 patch files: 626
Fozzie
G2 patch files: 49
Posted: Fri Jan 12, 2007 2:52 pm Post subject:
Thanks for trying it out G2Ian, I was typing with one hand and juggling my 3-months old in the other, so I couldn't do it myself  _________________ Spinning at ~0.0000115740740741 Hz |
Funky40
G2 patch files: 5
Posted: Thu Jan 25, 2007 5:26 am Post subject:
Has anyone of the Experts tryed to build a Filterbank with 16 bands and steep angles ?
VA load is NO point. ( space also )
( sorry, i was never into building filterbanks, and since i used my G2 no more for a long time i hope you got maybe allready one patched. )
Is it possible to patch something with sonic qualitis near to the one in the spectralis ? |
Joined: Apr 03, 2004 Posts: 24587 Location: The Netherlands, Enschede
Audio files: 309
Posted: Thu Jan 25, 2007 5:33 am Post subject:
| Funky40 wrote: | | Has anyone of the Experts tryed to build a Filterbank with 16 bands and steep angles ? |
You can just expand Ian's one and then make the filters steeper and change the frequency settings to you likings. _________________ Jan
Funky40
G2 patch files: 5
Posted: Thu Jan 25, 2007 5:41 am Post subject:
oh thanks,
and how should i make the Volume of each Band CV controllable, with the AM module ? |
Audio files: 309
Posted: Thu Jan 25, 2007 6:02 am Post subject:
| Funky40 wrote: | | and how should i make the Volume of each Band CV controllable, with the AM module ? |
When you want to use control signals to dynamically alter the volumes you could do that yes, or use the Level/LevMult instead which probably is a bit cheaper.
When you just want static volumes you could chain another MixFader to the one already in the patch. _________________ Jan
Fozzie
G2 patch files: 49
Posted: Thu Jan 25, 2007 6:11 am Post subject:
| Funky40 wrote: | Has anyone of the Experts tryed to build a Filterbank with 16 bands and steep angles ?
Me no expert, but this is just a simple extension of Ians patch. No idea about the sonic qualities of the spectralis either. Let us know how it compares according to you.
edit: ah, I see Blue Hell proposed already what I patched up, well, at least you don't have to do it yourself then . It's no rocket science anyway, but nice to play with. Also nice to use a couple of morphs on several overlapping sets of bands, for nice effects with a few knob turns. Trying out on a laptop/with the demo now, so I am curious how this sounds on the real thing with some audio going trough...
| fixed filterbank with 16 bands (frequencies set approx to doepfer a128 specs) and 36db cutoff slopes. Use keyboard or keyb tool to transpose sequence for auditioning. |
 Download (listen) |
| Filename: |
fixfilbank16B36dB.pch2 |
4.05 KB |
| Downloaded: |
1843 Time(s) |
Funky40
G2 patch files: 5
Posted: Thu Jan 25, 2007 11:29 am Post subject:
| Blue Hell wrote: | | or use the Level/LevMult instead which probably is a bit cheaper. |
Yes, i gonna try,................................................... will get my first notebook this DAys, so its Time to reactivate my engine.
and thanks
( yes, when i have something to tell, i'll do ) |
