 Forum index » Clavia Nord Modular » G2 Patches - Completed » Synth
Roland Supersaw
Page 1 of 1 [15 Posts]
hoshigoshi
G2 patch files: 4
PostPosted: Wed Feb 21, 2007 6:19 pm    Post subject: Roland Supersaw Reply with quote  Mark this post and the followings unread
Hello,
here`s a patch that i recently used in some recordings for clients...it`s just a structure for emulating the infamous Roland "Supersaw"-oscillator, as seen in JP-8000 and up. Nice for creating those typical commercial rave- and tranceleads, also phat pads. very "plastic" sounding...
[Note Blue Hell: the original patch got lost in the great crash, Jim was kind enough to beam us a copy he had - I put it in here]
supersaw_v11.pch2
supersaw in some variations. wave your hands in the air! ;-)
 Filename:  supersaw_v11.pch2
 Filesize:  3.46 KB
 Downloaded:  2969 Time(s)
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Feb 21, 2007 6:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Excellent!
iPassenger
G2 patch files: 78
PostPosted: Thu Feb 22, 2007 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
i second that comment. Smile
R.
iP (Ross)
darwen
G2 patch files: 5
PostPosted: Thu Feb 22, 2007 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I love the variations 2 and 5 by i don't understand how you make this sound , we don't see the tuning and i don't understand the module "dirt osc" , "dirt mod" and the modules under oscillators section , can i have explication ,please. Smile
hoshigoshi
G2 patch files: 4
PostPosted: Thu Feb 22, 2007 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
darwen wrote:
I love the variations 2 and 5 by i don't understand how you make this sound , we don't see the tuning and i don't understand the module "dirt osc" , "dirt mod" and the modules under oscillators section ,can i have explication ,please. Smile
Hello Darwen, thanks for the comment.
well, the original roland supersaw is made of 7 saw-waveforms, which are getting detuned/spreaded over the tuning range. every saw at another detuning amount...to imitate that, i did the following:
the detuning of the 6 SAW-Oscillators is done with the second Morph Group. When you click on the morphgroup in the editor, you can see the morph destinations and it get`s clearer what happens.
the modules under the OSC Section are for wider detuning of two out of six oscillators. the default finetune range of the G2 oszillators is -50 to +50 cents, which is not enough if you want to imitate the supersaw. so these modules are a workaround to detune the sound even more. there is a converter module, which i`ve used to invert the modulation of the second oscillator (OScD4) in this section and so it`s detuned with negative amount. the other oscillator (OscD7) get`s the same detuning amount, but not inverted...this way you can detune or spread the tuning of the oscs with just one turn of the morph-knop (detune).
the Dirt Osc Section is for taking away a too clean sound, especially for leadsounds. i`ve renamed the modules, this section is made up from a saw osc (Dirt Osc) and an lfo (dirt mod), that modulates this saw. if you mix the OSC Dirt to the Signal, it gives a slightly distorted and Lo-Fi character.
best,
hoshi
darwen
G2 patch files: 5
PostPosted: Thu Feb 22, 2007 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your explications and take time to answered.
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Thu Feb 22, 2007 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is a very decent recreation of that supersaw lead sound, even retaining the Roland style glossy programming of the delay and reverb.
oxylog2000
G2 patch files: 8
PostPosted: Tue May 08, 2007 3:48 am    Post subject: Reply with quote  Mark this post and the followings unread
hey man.
thanx for this excellent patch !!
i like it !
bye
dirk
BlisargonDemogorgon
PostPosted: Fri Sep 07, 2007 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
anyone can upload it again?
thanks
W.T.
G2 patch files: 11
PostPosted: Thu Oct 18, 2007 4:02 am    Post subject: Reply with quote  Mark this post and the followings unread
the supersaw is gone Sad i can not seem download it.
W.T.
G2 patch files: 11
PostPosted: Thu Oct 18, 2007 4:16 am    Post subject: Reply with quote  Mark this post and the followings unread
well, never mind....
jima
PostPosted: Thu Oct 18, 2007 5:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I can't replace the original (only the OP can do that) but here it is from my archive.
Jim
supersaw_v11_140.pch2
 Filename:  supersaw_v11_140.pch2
 Filesize:  3.46 KB
 Downloaded:  2171 Time(s)
Audio files: 297
PostPosted: Fri Oct 19, 2007 11:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for posting it Jim, I've updated the original post with it.
DNME
PostPosted: Thu Nov 08, 2007 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked really love this patch!!
Only wish there was a pitch env so you could make those nasty pitching Twisted Evil sounds! Want to add one, but don't know how (yet) Embarassed
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Mon May 19, 2008 9:22 am    Post subject: Reply with quote  Mark this post and the followings unread
this patch is pretty nice and full sounding, with pretty much voices to play. Still discovering the limits a bit since i bought it a couple days ago. I have no problems with the modules so far.
Only wish there was a pitch env so you could make those nasty pitching sounds! Want to add one, but don't know how (yet)
Its nice to mix event signals in a mixer. its not only for audio! That way you can easily mix an envelope with an lfo signal. Cable em up and send to the osc pitch..
