zonkout
Joined: Oct 12, 2006 Posts: 33 Location: ozztin, teggsitz
Posted: Mon Mar 12, 2007 8:46 am Post subject:
How to eliminate LFO bleed? |
I recently completed my modular:
Everything works great, but I have a fair amount of LFO bleed, which is quite audible in the oscillators but likely affecting the filters and VCAs as well.
All my modules are running into two Cynthia combo/distro power distribution boards. I am guessing this is the issue, since the LFO bleeds to the other modules without being connected in any other way.
At first I thought the problem was crosstalk between the VCAs in my Modcan 4VCA, but even running a single oscillator straight into a single VCA, I still get the LFO bleed.
How can I solve this problem? |
Scott Stites
Audio files: 96
Posted: Mon Mar 12, 2007 11:03 am Post subject:
What's the current rating of your power supply? |
Joined: Jan 31, 2003 Posts: 18240 Location: Durham, NC
Audio files: 224
Posted: Mon Mar 12, 2007 11:18 am Post subject:
Try to narrow down the problem. Unplug from the power supply virtually all modules except the one you are listening to (VCA or Filter). Then connect a single LFO. Any feed through?
If not, disconnect that one and try different LFOs.
This kind of trouble shooting takes a lot of time and patience. You will teach yourself as you go along. It's something that is difficult for someone else to identify remotely.
A problem with LFOs is that since the frequencies are so low, filter caps don't do as much as they do for higher frequency noise. _________________ --Howard
my music and other stuff |
zonkout
Posted: Mon Mar 12, 2007 12:01 pm Post subject:
My psu current rating is 3 amps.
I will unplug the LFO's and plug them in one at a time and check that way--but I can hear the bleed from each of my 2 Blacet LFOs and my Blacet Binary Zone (LFO/clock) independently.
I can defeat the LFOs by plugging a loose cable into the clock inputs. This stops the bleed, but I want to be able to use pure oscillator tones alongside modulated and clocked events, so I need a more permanent fix. |
zipzap
Mikmo
Joined: Dec 01, 2005 Posts: 150 Location: Copenhagen - Denmark
zonkout
Posted: Mon Mar 12, 2007 2:31 pm Post subject:
My combo/distro boards are connected in series. Each is feeding 10 modules (4 modcan and 6 blacet modules per distro board). If I connect my ENV, LFO, and clock modules to one board (with VCO, VCF and VCA on the other), should it be the first or last in the series?
My power supply is in a separate case, so I can't connect the combo/distro boards to it independently. |
Scott Stites
Audio files: 96
Posted: Mon Mar 12, 2007 3:02 pm Post subject:
3A would definitely be more than enough for your module complement.
I'd try the noise producers last in the series - the closer the VCO's are to the trough, the better.
If possible, it might not be a bad idea to try the two distros in parallel, though I realize things may be pretty much hardwired at this point.
Good luck,
Scott |
Posted: Mon Mar 12, 2007 6:01 pm Post subject:
Does your power supply have analogue and digital(dirty) ground connections? It doesn't matter so much about individual feeds to each module, as long as dirty grounds supply digital boards only.
You'll know if your PSU has dirty ground connections, because the connectors will have 4 connections each. (+ve, -ve, AGND, DGND)
Some boards won't discriminate between AGND and DGND. If they contain digital chips, and/or noise generators, they will need to be on a separate feed.
If any of this doesn't make sense, just let me know. It took me a while to get my head around the whole AGND/DGND idea. _________________ What makes a space ours, is what we put there, and what we do there. |
zonkout
Posted: Wed Mar 21, 2007 8:44 pm Post subject:
I am not sure if the supply has analog and digital grounds.
I tried putting the LFOs at the end of the chain but still get the bleed.
What is the best way to run my two distro boards in parallel? Can I solder two sets of wires to my power jack and then to the boards?
I believe I am using the combo/distro boards correctly. They are meant to be chained together (as described on Cynthia's site: http://www.cyndustries.com/modules_powerdist.cfm). Wouldn't this be a problem for everyone using these boards? |
zipzap
Posted: Thu Mar 22, 2007 3:51 am Post subject:
ehh - try to place the lfos at the beguinning of the chain, the vcos and filters to the end. with what you tried you get this: lfo makes noise, sits at the end of the chain, noise has to go through all modules on the way to finally get to the psu-cabs.
when i started i made the same mistake. thought that if a module is farther away it can´t do as much harm to the supply. it´s the other way around  _________________ http://www.myspace.com/lorolocoacousticpop
music and transcribed jazz basslines |
doctorvague
Posted: Thu Mar 22, 2007 6:11 am Post subject:
Cool modular! Love those colors!!
I'm no expert, but could this be a bad bypass cap on an LFO board? Or an electrolytic wired backward or something like that?
Phil |
zonkout
Posted: Thu Mar 22, 2007 8:36 am Post subject:
doctorvague wrote: | Cool modular! Love those colors!!
Phil |
That'd have to be the case for two LFOs and the Blacet Binary zone--not impossible, but unlikely.
Thanks for the complement! My cables are all crazy colors too. |
Scott Stites
Audio files: 96
Posted: Thu Mar 22, 2007 10:26 am Post subject:
If it's any help at all......a Synth DIY list posting from the inestimable Harry Bissell:
Quote: | Grounding 101:
I like to think of all electrical currents as water flow in pipes. Easier to visualize.
If you have a sink... and a tub and they both drain into the Atlantic (ok you California boys...) ... PACIFIC ocean, there is little chance that they will interact
The tub cannot back into the sink, nor the sink into the tub.
If you join them with a 1/4" pipe... it is a sure thing they will interact.
If you run two separate pipes, all the way to the ocean... they may drain slow but will NOT interact.
If you consider TOILET and DRINKING WATER together, you can see how important the planning is.
QUESTION : If you drop a jigger of Vermouth into Gin to fill the North Atlantic Ocean...what do you get ?
ANSWER : A VERY dry martini :^P
If you add one ounce of water to the ocean... the level rises. Probably you will say "who the fvck cares" and you're probably right. The question becomes... do I notice the change in water level, and do I care ???
NOW Grounding... There are several techniques.
1) Make ONE ground, really BIG and hope that all the current you can dump into it does not cause circuits to interact.
2) Make several grounds and run them separately all the way to the ocean (power supply)
Plan two is MUCH harder to pull off... you need to design that right from the beginning or it is nearly impossible. So most people use plan one. Plan one is CHEAPER, and might be all you need.
Harry's theorem of circuit equivalents.
Low level audio is like the "Drinking Water"
Most CVs are like the "Tub"
Circuits that drive obnoxious loads like LED displays and Relays are the "Toilet" :^P
You need to take special precautions for the drinking water. That could be things like separate power traces ALL the way back to the power supply, or extra decoupling caps etc.
The same is true for the obnoxious loads... you don't want to pollute the power system.
PARASITIC inductance and capacitance... friend or foe ???
Every circuit has parasitic elements... they are there without your intentional design. The power supply traces have some inductance in series with them and capacitance between them. Inductance
will cause the current to rise slowly when there is a power demand... so there will be a voltage drop at the load. Capacitance can cause fast rising signals on one wire to be coupled into another.
In general, for a power supply bus the parasitic capacitance is not a problem and could even help you. Likely you don't notice... its a few pF in parallel with many uF(s) of filter capacitors. Inductance DOES
hurt you. You minimize inductance by running the power feed and return very close together. Often, twisted pairs work well for this (in wires) and double sided or multilayer boards work for PCBs.
The idea is to minimize the area of the loop made as the current flows in the circuit. The smaller the loop, the lower the parasitic inductance.
HOW to achieve all this is a system design nightmare. If the maker of the modules did not plan ahead there is little you can do to improve on their design. The best route would be BIG power supply traces with lots of decoupling caps to provide local power storage... this will feed the circuit until the current can reach from the main supply.
You could make a distribution board and run all the wires back to it, using twisted pairs. That would be good as well.
It is good to have a single point ground (the 'ocean' would be ideal :^). This is often not possible.
Some chips like A/D converters have both Digital and Analog signals (like DIRTY and CLEAN...) and the best technique in that case is to run things so that the digital currents have an easier path back to digital ground, and the analog currents have an easier path to analog ground. Usually it is nice to tie the analog and digital grounds together RIGHT AT that chip, so that they are at the same voltage and no errors are introduced...
But what if there are TWO A/D converters, or a bunch of sensitive preamps etc... then you are back to the drawing board.
Grounding is as much art as science. How you do it drastically effects the performance, but there is no one technique that is perfect for all situations. I usually (by design) try and run power to my dirty loads separate from the clean ones... make the grounds BIG and low inductance... use a lot of decoupling caps (right Mr. Patchell ???)...
...and pray often
H^) harry |
Now, it's probably a bit late to start sorting out 'dirty' and 'clean' grounds.
This goes back to the trough (Harry's ocean). If you were to put in a second distribution board, parallel with the one you have now, the rails and the grounds will be going into the ocean, which is your power supply, through different pipes. Designate one distribution board for the modules that are giving your VCOs grief and connect them to that one, and put your quiet one's on the other.
You could test if first by rigging up something with a breadboard and alligator clips before going to all the trouble to find out this is bad advice (which I don't think it is).
I've lived with a breadboard archipelago for several years now, and it changes constantly over time. Grounding becomes like breathing after a year or two of that.  |
zonkout
Posted: Thu Mar 22, 2007 11:30 am Post subject:
Is it a bad idea to run two sets of leads (one for each board) from the jack that brings the power into the case? Or do I need to split off power on a strip board? Sorry, I'm new at this.
Is zipzap's suggestion an alternate solution? It seems to illustrate Harry's point (The idea is to minimize the area of the loop made as the current flows in the circuit. The smaller the loop, the lower the parasitic inductance. ) because I'd be making a smaller loop for the noisy modules. Right?
I appreciate your help in this guys--you really know your stuff. |
Scott Stites
Audio files: 96
Posted: Thu Mar 22, 2007 11:41 am Post subject:
I'd try ZipZap's idea before doing anything else; if that doesn't work, then pull out the guns
Scott |
Scott Stites
Audio files: 96
Posted: Thu Mar 22, 2007 5:17 pm Post subject:
FWIW, here's the method I use.
I've uploaded a pic of my homemade distribution board. It's driving the KS01 plus a couple of VCOs (which explains the alligator clip connection). That's four LFOs,two four channel mixers, two MS-20 filters, a 2040 filter clone, four VCAs, a Blacet Dark Star 2000, three envelope generators, a CGS wave multiplier, two VCOs, a ring modulator and a heavily armored modified CGS Analogic circuit acting as a peak/trough function plus various submixers and powered buffers added to these modules all powered from an 800 mA per rail Midwest Audio power supply. On the far lower right is the connection from the power supply. Closest to the power supply are the VCOs, MS20 filters and VCA. Further down the line is the DSC2000 (read major current player), the LFOs (four LEDs) and the EGs. This arrangement is merely by chance. I've never had to juggle modules - this system has never displayed any interaction from one module to the next. This includes the two VCOs currently patched into it - they're Rene Schmitz VCO's, which require a bit of attention to how they're grounded (an awesome VCO, BTW).
The idea is you don't want rails and ground passing 'through' , but to get as close as possible to a common connection through a star arrangement. A serially connected system is asking for trouble, that's why there are distribution boards.
With a distribution board, the 'through' applies to the power and ground starting at one end and branching off to the various modules til it gets to the other end. For big 'pipes' I used a fairly heavy gauge bus wire and crossconnected the rails and grounds so that any point is no longer than three or four inches from the power supply spigot - each rail and ground is more or less a web that more closely resembles a single point than just starting at one end and moving to the other. You'll see that nothing relies solely on serial connection. Compared to the length of the wires running parallel, or 'starring out' from this point, this length is insignificant. You'll notice no capacitors on this board - I rely on the decoupling electrolytics of each module for that, and, in addition, each IC gets a 0.1 uF decoupling cap whether it needs it or not (the Bissell Patchell mode of circuit design). As many caps as I use, the power supply has enough of a capacitive load as it is.
Scott
Description: |
Filesize: |
71.66 KB |
Viewed: |
7113 Time(s) |
zonkout
Posted: Thu Mar 22, 2007 7:25 pm Post subject:
Looks like I'll be pulling out the big guns.  |
Scott Stites
Audio files: 96
Posted: Thu Mar 22, 2007 8:52 pm Post subject:
Well, like Mosc says, these things are hard to troubleshoot from a distance. Wish I lived closer to TX. Anyway, curious - how long is the power connection between your distribution board and the power supply? |
Scott Stites
Audio files: 96
Posted: Thu Mar 22, 2007 8:53 pm Post subject:
Forgot to ask - did you try putting the VCO's closer to the power in of the distribution board also?
Edit: whoops, guess you did. |
zonkout
Posted: Fri Mar 23, 2007 11:42 am Post subject:
Scott Stites wrote: | Well, like Mosc says, these things are hard to troubleshoot from a distance. Wish I lived closer to TX. Anyway, curious - how long is the power connection between your distribution board and the power supply? |
Right now it is about 6 feet. I am using a standard XLR mic cable. |
Scott Stites
Audio files: 96
Posted: Fri Mar 23, 2007 12:56 pm Post subject:
Is there any way to hook a shorter connection between the PS and the synth (short of major surgery anyway)? It'd be interesting to see if that alleviated the symptom any at all. |
Audio files: 224
Posted: Fri Mar 23, 2007 4:36 pm Post subject:
XLR mic cables can be a little bit thin. There are XLR speaker cables that might be a better choice. _________________ --Howard
Joined: Apr 03, 2004 Posts: 24419 Location: The Netherlands, Enschede
Audio files: 297
Posted: Fri Mar 23, 2007 5:24 pm Post subject:
Still 6 feet is sort of asking for trouble. _________________ Jan
Scott Stites
Audio files: 96
Posted: Fri Mar 23, 2007 7:36 pm Post subject:
That's kinda what I'm thinking, too.
For a couple of years I've had this superfluous module tacked on the end of my synth - don't know if anybody's noticed it, no one's ever commented on it, but it's a module with two pots on the top and then two columns of banana jacks. It's from a panel for a module I was going to build for a guy, but things didn't work out, and I've scratched my head as to what to do with it (I have a limited amount of blank panels before I have to start searching again). This week it finally dawned on me that I could use it for a utilities panel. It could supply power and ground from the modular to my keyboard and a couple of other controllers I have in the works (joystick and touch sensitive thing).
Anyway, banana jacks would be a great way to go in this situation - get three banana jacks, one for each rail and ground, and build some *short* (I wouldn't want to go much over a foot or two) thick power supply cables with them. Extra banana grounds could be installed on the power supply to ground equipment you're connecting to.
Always the surgeon after the patient's closed, eh?
Scott |
