Recording knob movement
Page 1 of 1 [10 Posts]
sebber
G2 patch files: 33
PostPosted: Sun Aug 12, 2007 4:22 pm    Post subject: Recording knob movement Reply with quote  Mark this post and the followings unread
This patch records knob movement "on the fly", which in this case means the knob movement is recorded when the knob is turned. If the knob is not used, it replays what was recorded.
Main idea can be found here: http://www.electro-music.com/forum/post-37709.html#37709
RecordKnobMovement.pch2
Records the movement of a knob
 Filename:  RecordKnobMovement.pch2
 Filesize:  1.81 KB
 Downloaded:  2186 Time(s)
Fish don't swim. They dive.
sebber
G2 patch files: 33
PostPosted: Sun Aug 12, 2007 4:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
A bit of the same: here you can "preload" a sequence and change the running sequence at once with the push of a button.
SequenceReadyGo.pch2
Prepare a new sequence while another one runs
 Filename:  SequenceReadyGo.pch2
 Filesize:  1.96 KB
 Downloaded:  2168 Time(s)
Audio files: 309
PostPosted: Sun Aug 12, 2007 4:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice ways to do sequencer mods !
sebber
G2 patch files: 33
PostPosted: Mon Aug 13, 2007 3:36 am    Post subject: Reply with quote  Mark this post and the followings unread
You can see it as sequencer modulation, but I rather look at it like a knob movement recorder. Laughing
Can be of good use e.g. recording the movement of the pitch stick and repeat the same movement with an on/off-pedal, so both hands are free.
Or, like in the above (bad sounding for educational purposes) example, as a tone source shaper vector synthesis style.
RecordKnobMovement-Vector.pch2
 Filename:  RecordKnobMovement-Vector.pch2
 Filesize:  2.73 KB
 Downloaded:  2087 Time(s)
grimley
G2 patch files: 9
PostPosted: Tue Oct 30, 2007 12:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Are these patches no longer available?
grimley
seraph
Editor
Editor
Audio files: 33
PostPosted: Tue Oct 30, 2007 12:41 am    Post subject: Reply with quote  Mark this post and the followings unread
grimley
Unfortunately, the recent server catastrophe resulted in the loss of virtually all attachments posted between Oct 25, 2006 and today, Aug 20, 2007. Fortunately, it is possible to reload attachments. The process is pretty simple.
arrow http://electro-music.com/forum/topic-20016.html
sebber
G2 patch files: 33
PostPosted: Fri Nov 09, 2007 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Took me some time, but here they go again.
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Nov 09, 2007 3:58 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Sebastian Very Happy
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Thu May 22, 2008 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
this truly is something im looking for.. it will take some time before my beauty gets back with the expansion... but i do notice some glitches on the demo version with your patch (ye my g2 is beeing replaced) does that knob record tweaking has influence on voice polyfony? im testing it on the demo, and if i turn the rotary it will response only on tight turns with the knob, it doesnt react with smooth movements. "recordknobmoveme.pch2"
Electromagnetic Wave
G2 patch files: 38
PostPosted: Wed Dec 16, 2015 10:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Old topic but I just realised that I made the same kind of patch ...8 years after this one ! Here is mine but your patch take less memory :
http://www.electro-music.com/forum/topic-61953.html
I don't think...
Adjust the 'Time' knob on the Glide1 module to fix that
