 Forum index » Artists » Seraph
Dorian Schlesinger
Page 1 of 1 [17 Posts]
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun Aug 26, 2007 6:39 am    Post subject: Dorian Schlesinger Reply with quote  Mark this post and the followings unread
this is an experiment based on a scale I derived from an extended tonality diamond shown on this picture (taken from LMSO) . The tonality diamond is on the right, my scale is on the left. You can see that this eptatonic scale is one of the scales featured in the diamond: look at the bottom tile (1/1), the closest tile on the right is 22/13, follow that diagonal (from right to left) line and you'll see my scale.
This scale is based on the studies, by Kathleen Schlesinger, of the tuning systems used in ancient Greece. She calls this scale: "Dorian".
My experiment does not have anything Greek in it but maybe it sounds Greek to you Exclamation Cool
The song has been created using LMSO and Reason with its internal sequencers (real-time and step-time ones) Exclamation
arrow Listen to Dorian Schlesinger
 Filesize:  136.97 KB
 Viewed:  947 Time(s)
EdisonRex
Audio files: 172
PostPosted: Sun Aug 26, 2007 9:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Cute. It's very Gamelan-esque.
Garret: It's so retro.
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun Aug 26, 2007 12:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks Paul.
It's an experiment with a new feature of LMSO: it's a new approach to retuning sample based (.sxt files) refills of Reason that allows to use Matrix.
Audio files: 326
PostPosted: Sun Aug 26, 2007 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
I found this a very pleasant scale to listen to, at least in this piece. The literature links are interesting as well (but it does get a bit much to read together with "music and the power of sound" , but I'll get there, eventually Smile ).
Hey these are nice small factors, I'm going to try this one on the G2 (that one can not easily go beyond 31 in either numerator or denominator).
If I get it right on can just pick any diagonal line from the diamond figure to obtain another scale to experiment with?
EdisonRex
Audio files: 172
PostPosted: Sun Aug 26, 2007 3:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
I find that a lot of these kinds of scales have to work in a particular mode or else they are really bad. This one seems like it's in its natural spot. I think the Greeks tuned each instrument to whatever it could do or something. It's tough to do experimental archaeology, you know.
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun Aug 26, 2007 3:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan, the answer is yes, every diagonal line is a 7 step scale
Idea
I would love to hear hypophrygian noodles Exclamation
Shocked
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun Aug 26, 2007 11:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think that once you take a scale out of his original melodic, harmonic (if applicable), timbral context you are beyond archeology. The scale becomes a resource for new experimental sonic landscapes maybe reminiscent of old/ancient ones.
Audio files: 235
PostPosted: Mon Aug 27, 2007 7:36 am    Post subject: Reply with quote  Mark this post and the followings unread
I like this very much. After your inspiring talk at Chateau Sonore, I'm really much more open to these alternative tunings.
Low Note
PostPosted: Mon Aug 27, 2007 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
hey,
are there any programs similar to LMSO that run on Windows machines.
Also, I'd be more interested in a user friendly program than an extremely adaptable one.
seraph
Editor
Editor
Audio files: 33
PostPosted: Mon Aug 27, 2007 9:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Low Note wrote:
hey,
check our Links page:
I would suggest Scala. It's freeware too Exclamation
seraph
Editor
Editor
Audio files: 33
PostPosted: Mon Aug 27, 2007 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Howard
Low Note
PostPosted: Mon Aug 27, 2007 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
I was planning on trying to explore the scale as well, but ran into a pretty major roadblock.
seraph
Editor
Editor
Audio files: 33
PostPosted: Mon Aug 27, 2007 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just uploaded a new version of this song that is more structurally balanced, imo Exclamation
EdisonRex
Audio files: 172
PostPosted: Mon Aug 27, 2007 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's got more structure. Are you using some algorithmic components to this as well as the tuning? There are sections that remind me of old Dr T's Tunesmith output. It's cool sounding.
seraph
Editor
Editor
Audio files: 33
PostPosted: Mon Aug 27, 2007 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Paul, I had Tunesmith on my Atari, 20 years ago Wink but no, I am not using any algorithmic component. That effect depends on the use of Reason's step sequencer (the above mentioned "Matrix").
PostPosted: Tue Sep 04, 2007 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Seraph,
I really like this track. You utilized non-ET tuning and created music that has great spirit and holds one's interest.
While the intervals are a bit "jarring" at first, one is quickly drawn in to the musical world you created.
More, more!
seraph
Editor
Editor
Audio files: 33
PostPosted: Tue Sep 04, 2007 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
kkissinger wrote:
Seraph,
More, more!
thank you very much Kevin Very Happy but, as far as "jarring" intervals are concerned you should be an expert Shocked I just listened to your CowboySong Wink and let me tell ya, there is plenty of jarring intervals there Twisted Evil ...but I love it Cool
