first time sys dump
Page 1 of 1 [12 Posts]
amnesia
PostPosted: Sat Sep 15, 2007 8:32 pm    Post subject: first time sys dump Reply with quote  Mark this post and the followings unread
Hi
I am trying to do a sys dump, never done it before in Cubase SX...I did midi out from A6 into Midi in on my Presonus Firepod , hit Midi channel and record but when I have done all the STORE BANK SEND and it all looks to be going out of the A6, I cant see any midi info in cubase....any help please
TIA
amnesia
PostPosted: Mon Sep 17, 2007 2:35 am    Post subject: Reply with quote  Mark this post and the followings unread
update
I have looked a the recorded midi track in cubase and inside the one track there appears to be different notes and different lengths, I ASSUME this is the sys ex info?
Then how do I save this as .sys or how ever it is saved like?
amnesia
PostPosted: Tue Sep 18, 2007 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
wow I am really suprised at the lack of advice on this subject...have non of you done sys dumps? PLEASE GIVE ME THE ADVICE I NEED
jonkull
PostPosted: Tue Sep 18, 2007 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe there aren't many Cubase users here to answer your question. I use Sysex Librarian on a Mac. I hear PC people talk about MIDI-OX all the time. Maybe give one of those a try.
cappy2112
PostPosted: Tue Sep 18, 2007 10:04 am    Post subject: Re: first time sys dump Reply with quote  Mark this post and the followings unread
amnesia wrote:
Hi
TIA
Which OS, Windows or MAC?
rh2y
PostPosted: Tue Sep 18, 2007 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Amnesia,
The advice you need is: Use a separate Sysex utility for doing sysex dumps. I use Cubase, but I don't use Cubase to handle sysex data. On my mac, I use Sysex Librarian http://www.snoize.com/SysExLibrarian/. For PC, there are similar utilities.
If you're determined to use Cubase as your sysex tool, check in with the Cubase forums at www.cubase.net.
Good luck,
Russ
Shameless plug: http://www.soundcloud.com/rh2y
Shameless-er plug: http://www.evatontechnologies.com/
Music: https://atomstomolecules.bandcamp.com/releases
amnesia
PostPosted: Tue Sep 18, 2007 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am PC ..what free program should I use?
rh2y
PostPosted: Tue Sep 18, 2007 2:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've not done any sysex on PC, but I believe you are looking for this:
http://www.midiox.com/
Good luck with it.
cappy2112
PostPosted: Tue Sep 18, 2007 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good luck with it.
Yep- you can't beat this program.
It's free, does sysex transfers, and lots of cool mapping features.
Peake
PostPosted: Tue Sep 18, 2007 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
With MIDIOX, you need to go to Preferences and set the rate to 80% or you'll get overload.
Dang, it's been too long, anyone else know this program?
cappy2112
PostPosted: Tue Sep 18, 2007 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I do. I haven't had the overload problem before.
I do usually allocate the largest buffers possible, and as many as it will allow, just to ward off buffer overflows.
I've never had Midiox crash.
I've done sysex dumps that are around 500-600kb, without a hitch.
Peake
PostPosted: Tue Sep 18, 2007 11:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks cappy. I remember having had to set the Mac as I'd stated, and then it worked quite well.
