Sending program change to Electro from Lead 3 performance
Page 1 of 1 [9 Posts]
slug
PostPosted: Fri Jan 25, 2008 7:46 pm    Post subject: Sending program change to Electro from Lead 3 performance Reply with quote  Mark this post and the followings unread
Hi.
Can this be done? To elaborate i am setting up performances to match song names so that i can use the first 3 slots as Lead 3 sounds, and then the 4th slot has a silent lead 3 patch but plays the Electro via MIDI. All this is working ok, but i would like to be able to set the program change as part of the slot selection within the performance?
Any help or confirmation either way would be great. Thanks :)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Jan 26, 2008 2:14 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome slug
I assume you use a split keyboard, in which one part is send by Midi channel 4 to the Electro, which is set to channel 4 too?
No, the NordLead3 send his Program change when changing the Performance, not just a single Slot. This is only possible in Program mode, but then the other three Slots can't be changed as a 'Performance' in one go.
The only Clavia synth which is able to do this is the G2...
In the picture you see a simple set up of 8 changes of two extern synths without using Program Change of the G2 itself by just pressing one button on the G2 panel.
Wout
 Filesize:  92.95 KB
 Viewed:  4996 Time(s)
brick_in_the_wall
PostPosted: Sat Jan 26, 2008 6:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello there,
Well,if I understand correctly (and please don't hate me if I don't - english is not my mother language Rolling Eyes ) you want to make preset on your nord lead which sends program change to your electro.For example,you want that performance A2 (I don't know how performance are organized on lead 3,I have lead 2) changes your electro to patch number 45 (or whatever else).
Well,I don't know how this is organized on nord lead 3,but I tried and make same thing on Korg Triton LE some days ago.On Korg,you have something called MSB and LSB as far as I remember , and this defines bank and patch number for midi device you are sending midi to.
So,try and find those parameters,I think that would help.
Best regards
slug
PostPosted: Tue Jan 29, 2008 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your replies.
Wout Blommers: No im not using split keyboard, i have one of the slots set up as a mute sound, and this is the only one that is sending out the MIDI channel for electro, so in this system when you select any of the other 3 slots you are playing lead, and the 4th the Electro.
Sending the program change to the Electro when selecting the Performance is exactly what i am after but you didnt elaborate on how it is done as I think you had me wrong in what i was trying to achieve. My apologies but are you able to explain how the program change is associated with the Performance change? This would be exactly what i have been trying to figure out. Thanks!
brick_in_the_wall: Your english is fine my friend Smile I have already been trying to find the program control message in the Lead 3, and have failed thus this thread to try and have the more experienced give me a hand.
Thanks again Smile
D
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Jan 29, 2008 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll have to take a look at this set up. On [Manual Page 139] you can read the Performance Change on the Lead is transmitted on the Global Channel. I'm afraid the Electro doesn't have a Global Midi Channel. Unfortunate I'm very busy tomorrow, wednesday, so I can start on thursday at the earliest...
Wout
slug
PostPosted: Sun Feb 03, 2008 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks.
I can see that information on page 139, but where i am stuck is here:
"When you select a performance, a program change message is transmitted..."
The "a" isnt very helpful, i want to send a specific message that is related to the bank select on the Electro, and this doesnt seem to be explained in the manual - thus why i am asking here. Thanks again for your help in this matter. Smile
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Feb 03, 2008 4:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
What message would it be other then Program/Bank Change?
I think you can do it this way...
Don't use NL3 Performance mode if you don't want to change Slot A to C. Then create a special Bank containing silent Programs and load this bank into Slot D. You are able to name these Programs with the memory locations of the Electro or name of the song with memory location of the Electro. Set Slot D and the Electro to the same Midi Channel. When Slot D is activate and is changed to another Program, the Electro will follow. If you need to make a jump, use the Rotary Dial of the NL3.
BTW the Electro only has 64 memory locations, so you're are only using half the bank.
In this set-up it is impossible to save the value of the Program Change in the Program of the NL3. (It can in the G2, which has a flexible Midi Out set up)
Wout
slug
PostPosted: Sun Feb 03, 2008 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks dude this is so helpful.
Can i just confirm from what you have said:
1 - There is no way to store the value of the program change message within the Lead 3, so it is not possible to have the Electro change to a pre designated program number (for example B4) when a performance is selected.
2 - The program change message sent to the Electro is just a +1/-1 message, and is not related to the program number currently set on the Lead 3, and that this in fact is the only way to influence the program currently selected on an external synth.
3 - The ultimate workaround might be to have all your performances set as the first 64 of the Lead 3 banks (ie from 1:1 to 1:64) and have your Electro programs setup accordingly, including multiple copies of sounds on the Electro that you use on several songs (ie a favourite organ sound might be stored on A2, A6, B5, D7...)
Thanks again this has made me feel less useless in not finding how to achieve this Smile
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Feb 03, 2008 10:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
As I wrote above, the only Clavia synth which is able to preform such things is the G2. It has a miracle Midi module to preform this task, the Midi Automate, which is able to 'read and save' settings of another synth.
The G2 (or Engine) is a real synth tool!
I use the Midi section to make the Organ Draw bars Velocity sensitive, like on the Stage.
Wout
 Filesize:  9.84 KB
 Viewed:  4882 Time(s)
