Joined: Jan 31, 2003 Posts: 18240 Location: Durham, NC
Audio files: 224
Posted: Mon Feb 11, 2008 11:17 am Post subject:
Power supplies |
Most CMOS logic will work well on 5 Volt DC supplies. Before starting to build a Lunetta, it's a good idea to start with a good 5V DC supply.
This topic is for people to post designs for such supplies, or places where they can be obtained, etc.
CMOS logic uses very low power, so it is possible to use batteries. Standard AAA, AA, D, and C cells are about 1.5 V. So 3 or 4 in series makes a usable supply and your Lunetta becomes portable.
Please post power supply designs here, as well as questions and comments. _________________ --Howard
my music and other stuff |
Clack
Joined: Aug 08, 2005 Posts: 438 Location: Walthamstow - london
Posted: Mon Feb 11, 2008 1:44 pm Post subject:
I just based this off the lm317 datasheet and other sources I could find cos its quick to lay out - and i know how to do it! .
Based on the LM317 - PSU2 version is probably better - all resistors in ohms not Kohms
6.5-20v dc needed
Description: |
Filesize: |
6.32 KB |
Viewed: |
517 Time(s) |
Description: |
Filesize: |
8.28 KB |
Viewed: |
506 Time(s) |
_________________ Clacktronics.co.uk |
Joined: Apr 03, 2004 Posts: 24420 Location: The Netherlands, Enschede
Audio files: 297
Posted: Mon Feb 11, 2008 2:05 pm Post subject:
I'd not use the adjustable one ... even bad old TTL is happy from 4.75 to 5.25 V , so it's not too critical. _________________ Jan
Clack
Posted: Mon Feb 11, 2008 2:20 pm Post subject:
oh right ok.. cool. Bit over the top then! to be honest they dont really need schematics there is barely any parts - I guess a little PCB/Stripboard layout is all that is needed _________________ Clacktronics.co.uk |
williamsharkey
Posted: Tue Feb 12, 2008 9:00 am Post subject:
<- newbie
Why regulate voltage when one can combine household batteries in series and parallel to obtain ~5 volts.
Is this for people who: don't want to use batteries and have a dc power supply in the range of 6.5 to 20 volts? |
Clack
Posted: Tue Feb 12, 2008 9:10 am Post subject:
Yeah, it works with most dc wall warts ( you find them everywhere theese days - it will work with most ) - its especially usefull if you want some LED's. too many of them an it will not take long to drain battery power. Batteries wont need regulators
Im not a great fan of batteries when you use them in your bedroom - it seems a waste - although im sure you could say using mains is a waste too.
As blue hell said though - using this regulator is probably a bit over the top - i'll leave it up anyway. but a lm7805 is probably better - they are easy to find sometimes in electronic junk too. _________________ Clacktronics.co.uk |
Audio files: 297
Posted: Tue Feb 12, 2008 10:04 am Post subject:
Mr Clack wrote: | As blue hell said though - using this regulator is probably a bit over the top |
Didn't mean to say that .. did mean to say that the adjustable one (the one with the trimmer) would be over the top  _________________ Jan
Clack
Posted: Tue Feb 12, 2008 12:02 pm Post subject:
oh right, heh - I just put that on because 680R is the nearest value I can get _________________ Clacktronics.co.uk |
williamsharkey
Posted: Tue Feb 19, 2008 11:18 am Post subject:
Why is C2 drawn differently than C1, do they represent different types of capacitors?
Perhaps the order of connection of the leads matters in C1? |
23isgood
Joined: Nov 18, 2006 Posts: 236 Location: San Francisco, CA bay area
danielwarner
Posted: Tue Feb 19, 2008 4:48 pm Post subject:
williamsharkey wrote: | Why is C2 drawn differently than C1, do they represent different types of capacitors?
C1 is a polarized capacitor, e.g. an electrolytic or tantalum, which will most likely have a stripe with a "-" symbol indicating the negative lead. It must be oriented correctly, or at best will not work and at worst will explode. I've seen capacitors explode, it's amusing but dangerous! The funny thing is it was in a class at school where we were accidentally given electrolytics rated at a lower voltage than the power supply for the circuit. When the first cap popped, we all assumed they'd oriented their cap incorrectly. Then mine blew up and somebody checked the voltage rating and it was not up to par. Blame the lab tech . Anyway for the rest of the semester we always checked the voltage ratings on the caps!
Any capacitor rated at a higher voltage than the wall wart you're using should be fine. For instance with a 12VDC wall wart, a 16V capacitor will be fine. |
williamsharkey
Posted: Tue Feb 19, 2008 7:38 pm Post subject:
Quote: | Any capacitor rated at a higher voltage than the wall wart you're using should be fine. For instance with a 12VDC wall wart, a 16V capacitor will be fine. |
What if you have two 10V capacitors. If you place them in parallel, I wonder if they can handle more than their individual ratings?
(I know not to do any sort of experimenting with power supplies, so you can answer the following question unhindered by safety concerns ) |
danielwarner
Posted: Tue Feb 19, 2008 9:06 pm Post subject:
In this instance, the cap comes after the voltage regulator, after the voltage has been regulated down to +5V. You'll be fine with a 10V cap. |
danielwarner
Posted: Fri Feb 22, 2008 3:04 am Post subject:
For future reference:
If you have two 10V caps, you can put them in series and they will behave like one 20V cap at HALF the farad rating
Two 10V 20uF caps in series would give you a 20V 10uF cap |
