Nord Modular Editor Crashing
Page 1 of 1 [14 Posts]
amrz
PostPosted: Sun Jan 22, 2006 3:43 am    Post subject: Nord Modular Editor Crashing
Subject description: midi problems w/ NM Editor + Win XP
Hi
Few weeks ago i bought this great red box. However, i've had big problems w/ midi + editor. When i started to check out some patches from harddrive editor crashes and i mean really bad way Rolling Eyes . My DAW wont even shutdown after that!
I tryed to solve this by removing NM PC MIDI I/O from sequencer, but this didnt help much, still crashing. I have sequencer and editor open sametime. I dont have any clues what should i do..
NM works great w/ sequencer, no hassle, but when i go Editor side thing s get ugly Rolling Eyes , i missing the biggest fun.
any help is welcome.
_amrz
ps. midi-interface = Emagic Unitor 8, OS = Win XP.
Tusker
PostPosted: Mon Jan 23, 2006 3:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Is the editor hanging (freezing) or is it giving you some error messages prior to crashing?
I once had a problem of losing the MIDI connection. This would crash the editor sometimes. A new MIDI interface improved my MIDI bandwidth and solved the problem for me. Dunno if this helps,
Jerry
amrz
PostPosted: Mon Jan 23, 2006 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, editor is freezing totally.. i cant even close editor from task manager Evil or Very Mad .
amrz
PostPosted: Wed Jan 25, 2006 12:13 am    Post subject: Reply with quote  Mark this post and the followings unread
I think i solved it. Seems that my midi-interface - Emagic Unitor 8 dosent like NM. I connected NM PC Midi I/O(s) to my EMU 1820-M and had no freezing/crashes Cool
"You don't have to go through all this trouble, it's easy, just give me four diodes and i'll build you a ring modulator."-Don Buchla
cappy2112
PostPosted: Wed Jan 25, 2006 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like you got a midi loop going somewhere.
Unusual behaviour like this is a classic sign.
I had bought a brand new sampler, connected it to my midi patch bay, a program change got sent which caused the patch in the patch bay to change, and started a midi loop back to the sampler.
All the buttons stopped working, the display went crazy, nearly had a heart attck myself Smile
amrz
PostPosted: Wed Jan 25, 2006 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah .. Actually i'm not sure if i solved problem but atleast NM's editor didnt crash on last session, since this freezing is random - i need to test little bit more Very Happy. NM is on 'Local Off' -mode, which should be also right, when using w/ external sequencer.
cappy2112
PostPosted: Wed Jan 25, 2006 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can also try running the editor in Compatibility mode. I had to do this for the NM editor, but not for the G2 editor.
amrz
PostPosted: Fri Jan 27, 2006 1:32 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah, first thing i did when problems started i red Clavias FAQ and runned editor in compatibility mode.
amrz
PostPosted: Wed Mar 05, 2008 4:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm back! Very Happy . Back to the topic. I'm still getting those _freezes_, any ideas how i can address whats happening in my system and whats causing the crashes ?.
sonictransportsystem
PostPosted: Wed Mar 19, 2008 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Try this! On nord editor properties, change the operating system for windows 98!
i hope it helps
amrz
PostPosted: Sat Apr 26, 2008 1:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I cant find "combatibility" -tab ?.
PostPosted: Sat Apr 26, 2008 1:18 am    Post subject: Reply with quote  Mark this post and the followings unread
right-click the executable.
amrz
PostPosted: Sat Apr 26, 2008 1:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, there's only: General, Version, Security, Summary -tabs. And i doubt this makes problems go away since Java editor also crashes.
Audio files: 297
PostPosted: Sat Apr 26, 2008 4:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Does http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/appcompat.mspx help?
