amrz
Posted: Sun Jan 22, 2006 3:43 am Post subject:
Nord Modular Editor Crashing Subject description: midi problems w/ NM Editor + Win XP |
Hi
Few weeks ago i bought this great red box. However, i've had big problems w/ midi + editor. When i started to check out some patches from harddrive editor crashes and i mean really bad way . My DAW wont even shutdown after that!
I tryed to solve this by removing NM PC MIDI I/O from sequencer, but this didnt help much, still crashing. I have sequencer and editor open sametime. I dont have any clues what should i do..
NM works great w/ sequencer, no hassle, but when i go Editor side thing s get ugly , i missing the biggest fun.
any help is welcome.
_amrz
ps. midi-interface = Emagic Unitor 8, OS = Win XP. |
Tusker
Posted: Mon Jan 23, 2006 3:24 am Post subject:
Is the editor hanging (freezing) or is it giving you some error messages prior to crashing?
I once had a problem of losing the MIDI connection. This would crash the editor sometimes. A new MIDI interface improved my MIDI bandwidth and solved the problem for me. Dunno if this helps,
Jerry |
amrz
Posted: Mon Jan 23, 2006 9:50 am Post subject:
Yeah, editor is freezing totally.. i cant even close editor from task manager . |
amrz
Posted: Wed Jan 25, 2006 12:13 am Post subject:
I think i solved it. Seems that my midi-interface - Emagic Unitor 8 dosent like NM. I connected NM PC Midi I/O(s) to my EMU 1820-M and had no freezing/crashes  _________________ "You don't have to go through all this trouble, it's easy, just give me four diodes and i'll build you a ring modulator."-Don Buchla |
cappy2112
Joined: Dec 24, 2004 Posts: 2495 Location: San Jose, California
Posted: Wed Jan 25, 2006 12:39 am Post subject:
amrz wrote: | I think i solved it. Seems that my midi-interface - Emagic Unitor 8 dosent like NM. I connected NM PC Midi I/O(s) to my EMU 1820-M and had no freezing/crashes  |
Sounds like you got a midi loop going somewhere.
Unusual behaviour like this is a classic sign.
I had bought a brand new sampler, connected it to my midi patch bay, a program change got sent which caused the patch in the patch bay to change, and started a midi loop back to the sampler.
All the buttons stopped working, the display went crazy, nearly had a heart attck myself  |
amrz
Posted: Wed Jan 25, 2006 7:25 am Post subject:
Quote: | Sounds like you got a midi loop going somewhere. |
Yeah .. Actually i'm not sure if i solved problem but atleast NM's editor didnt crash on last session, since this freezing is random - i need to test little bit more . NM is on 'Local Off' -mode, which should be also right, when using w/ external sequencer. _________________ "You don't have to go through all this trouble, it's easy, just give me four diodes and i'll build you a ring modulator."-Don Buchla |
cappy2112
Posted: Wed Jan 25, 2006 12:11 pm Post subject:
amrz wrote: | Quote: | Sounds like you got a midi loop going somewhere. |
Yeah .. Actually i'm not sure if i solved problem but atleast NM's editor didnt crash on last session, since this freezing is random - i need to test little bit more . NM is on 'Local Off' -mode, which should be also right, when using w/ external sequencer. |
You can also try running the editor in Compatibility mode. I had to do this for the NM editor, but not for the G2 editor. |
amrz
Posted: Fri Jan 27, 2006 1:32 am Post subject:
Quote: | You can also try running the editor in Compatibility mode |
yeah, first thing i did when problems started i red Clavias FAQ and runned editor in compatibility mode. _________________ "You don't have to go through all this trouble, it's easy, just give me four diodes and i'll build you a ring modulator."-Don Buchla |
amrz
Posted: Wed Mar 05, 2008 4:57 am Post subject:
Quote: | I had bought a brand new sampler, connected it to my midi patch bay, a program change got sent which caused the patch in the patch bay to change, and started a midi loop back to the sampler. |
I'm back! . Back to the topic. I'm still getting those _freezes_, any ideas how i can address whats happening in my system and whats causing the crashes ?. _________________ "You don't have to go through all this trouble, it's easy, just give me four diodes and i'll build you a ring modulator."-Don Buchla |
sonictransportsystem
Posted: Wed Mar 19, 2008 11:49 am Post subject:
Try this! On nord editor properties, change the operating system for windows 98!
i hope it helps |
amrz
Posted: Sat Apr 26, 2008 1:14 am Post subject:
I cant find "combatibility" -tab ?. _________________ "You don't have to go through all this trouble, it's easy, just give me four diodes and i'll build you a ring modulator."-Don Buchla |
Posted: Sat Apr 26, 2008 1:18 am Post subject:
right-click the executable. _________________ Kassen |
amrz
Posted: Sat Apr 26, 2008 1:32 am Post subject:
Yeah, there's only: General, Version, Security, Summary -tabs. And i doubt this makes problems go away since Java editor also crashes. _________________ "You don't have to go through all this trouble, it's easy, just give me four diodes and i'll build you a ring modulator."-Don Buchla |
Joined: Apr 03, 2004 Posts: 24455 Location: The Netherlands, Enschede
Audio files: 297
