Micro A/D and D/A?
Page 1 of 1 [8 Posts]
Gothboy
PostPosted: Wed Jul 16, 2008 11:17 am    Post subject: Micro A/D and D/A?
Subject description: Micro A/D and D/A?
Does anyone know what the Micromodulars' bit rate is? I'd like to use it as an effects device and process other instruments through and possibly even vocals using a vocoder patch but I'm a little concerned about the bit rate and sound quality coming out of Pro Tools at 24-bit. I'd like to use it as an insert effect.
Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.11.6/El Capitan
Novation SL49, Behringer 2600, Crave, Edge
Mophox4, Nord Lead 2,Modal electronics Argon 8m, Roland System 1, Novation Nova, Nord Micro modular, Korg Radias, Roland d-05, Yamaha A3000 sampler, Novation SL MK2 and Remote Zero controllers, Arturia Beatstep and SparkLE, Korg ER-1, Unosynth
Dymaxion Vehicle Music at www.dymaxionvehicle.com/
Alexander
G2 patch files: 4
PostPosted: Wed Jul 16, 2008 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
"16-bit Sigma-Delta ADCs, 48 kHz sampling frequency...
18-bit linear DACs, 96 kHz sampling frequency"
I hope that helps. Please try and use it as an insert, it's a monster effect unit, you will love it. Smile
http://husc-sound.com
Gothboy
PostPosted: Wed Jul 16, 2008 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
....so it goes in at 16bit and goes out as 18-bit? I've used the Micro as a synth and it is fantastic! I've yet to use it as an effect but I'm looking forward to doing so. Very Happy
16 GB Ram
10.11.6/El Capitan
PostPosted: Wed Jul 16, 2008 4:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
...and I think it works at 24 bit internally, could be 20 though.
Of course the only real judge of it's value as a effect has to be your ear.
Gothboy
PostPosted: Thu Jul 17, 2008 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
....I think the Nord Lead 2 works at 20-bit internally so I think it's the same for the micro since they came from the same Nord era. I don't think VAs were up to 24-bit at that time? Confused
16 GB Ram
10.11.6/El Capitan
Fozzie
G2 patch files: 49
PostPosted: Thu Jul 17, 2008 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Nope, both NM classic and NM G2 are 24/96 internally, the micromodular as well.
Gothboy
PostPosted: Fri Jul 18, 2008 6:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Really! Shocked You' think that if this were true they'd put it in the manual!?
16 GB Ram
10.11.6/El Capitan
Audio files: 297
PostPosted: Fri Jul 18, 2008 9:35 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.clavia.se/products/discontinued/nordmodular/technical.htm
