gomidas
Joined: Jul 09, 2004 Posts: 365 Location: La Ciotat, France
G2 patch files: 6
Posted: Wed Jul 30, 2008 3:42 pm Post subject:
Custom G1 >> G1 Engine Subject description: Customize NM classic |
Hi NM Lovers
Got a technical Q about the Nord Modular...I want to make an "engine" out of my NM(some keys are broken), but the fact is that the sound doesn't work with the upper knob/LCD panel cable unpluged.
Does anybody knows if the sound engine can work without the front panel?
If not I will try to make a DIY Box/enclosure (metal/plexi).If only I could get my hands on a real Nord Modular Rack enclosure...
A good start for a DIY rack will be a 3U 19" rack http://www.metcase.com/products/metcase/mettec19-fr.htm or http://www.maplin.co.uk/module.aspx?ModuleNo=34159&doy=30m7
Thanks
BTW:anybody knows where I can find a NM "keyboard key" replacement? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Wed Jul 30, 2008 4:01 pm Post subject:
Re: Custom G1 >> G1 Engine Subject description: Customize NM classic |
gomidas wrote: | Does anybody knows if the sound engine can work without the front panel? | The motherboard will always try to find the knobs on the frontpanel, so it will stop booting... Quote: | BTW:anybody knows where I can find a NM "keyboard key" replacement? | Try your local dealer if they can sell you
http://www.fatar.com/Pages/TP_7BA.htm
in 25 keys configuration.
Wout |
Joined: Apr 03, 2004 Posts: 24461 Location: The Netherlands, Enschede
Audio files: 297
Posted: Wed Jul 30, 2008 4:03 pm Post subject:
Probably Clavia could help you with a new keybard, I just had a look at it (I do have defective one here as well (and also a good one)) but it's unlabeled ... IIRC there was some info under the keys.
As to the no sound problem, likely the synth sees the pots as set to zero when not present ... including the main volume pot? So maybe you should trace that one out and connect it. It would be handy to have a main volume anyway I think. _________________ Jan
gomidas
G2 patch files: 6
Posted: Thu Jul 31, 2008 2:21 am Post subject:
I could not expect better answers from anybody else than you two when it comes to NM Classic
You must know that I was about to reduce the metal case of my NM Key to make a NM Rack out of it.... but then decide to keep it as it is and make myself a rack with a DIY box/enclosure in case I want my 'Old' NM key Classic back.
The fact is that I want to gain space..I know it could sound ridiculous when we think about that..
...but the front panel of the G1 is not the G2 key, I mean I do not use it(bcr/bcf2000), that is why I thought about making a G1 Engine.What I can do also is to find a longer internal cable to rack the sound board in a 19" case and the front panel in another one ...
Wout, Jan, Thanks for those wise advices  |
Audio files: 297
Posted: Thu Jul 31, 2008 11:35 am Post subject:
You could be having a space problem indeed that's quite a collection of modules ! _________________ Jan
