Bug I think...
Page 1 of 1 [5 Posts]
Wan
G2 patch files: 46
PostPosted: Fri Sep 10, 2004 2:56 pm    Post subject: Bug I think... Reply with quote  Mark this post and the followings unread
I've got a problem with the stick response. The stick output from the device module is slewed too much. Especially on the return of the stick to the center the bend lags behind. With fast bends and note runs it renders the whole tuning off.
See attached performance, there is an identical patch in slot a and slot b. Slot a has normal stick assignment, slot b has the device output. Both slots are assigned to the keyboard. Playing on the keyboard lets hear them together, and using the pitchstick shows the lagging from the patch in slot b.
Is this just my G2 or is this really a bug?
StickProblem2.prf2
 Filename:  StickProblem2.prf2
 Filesize:  12.19 KB
 Downloaded:  1635 Time(s)
Grtz Wan
Audio files: 227
PostPosted: Fri Sep 10, 2004 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
What you describe I hear on my G2 also.
Wan
G2 patch files: 46
PostPosted: Sat Sep 11, 2004 2:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for checking, Howard. I will inform clavia and see what they can/will do about it.
I'm rather picky about the pitchstick, the normal response is just not sensitive enough for me, but this bug makes I can't patch a better response myself.
So i'm not happy with the stick at the moment.
Grtz Wan
Wan
G2 patch files: 46
PostPosted: Mon Sep 13, 2004 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Clavia has answered my message concerning the pitchstick, acknowledging the bug. And giving me hope of a cure Smile
"There is a problem with lag in the device module that we hopefully can
do something about it in the next update.
Best regards,
Tommy."
Pretty quick reply.
Grtz Wan
Audio files: 227
PostPosted: Mon Sep 13, 2004 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Good to hear...
