Wave Folders Question...
Page 1 of 1 [6 Posts]
phdinfunk
PostPosted: Wed Oct 08, 2008 6:58 am    Post subject: Wave Folders Question... Reply with quote  Mark this post and the followings unread
I've read through the text on the wavefolder page several times and am having trouble figuring out which part of the wave folder is similar to that "middle section" of the Serge waveshaper. Is it the Lockhardt wavefolder / Grinder or the other one or what?
Also, does the PCB with the real ringmod and the wavefolder at www.bridechamber.com have the one that is similar to the Serge Middle Section?
Sorry to be all stereotypical synth nerd but I really want one of those famous Serge-Esque thingies to play with in my modular.
Thanks,
Jonathan
andrewF
PostPosted: Wed Oct 08, 2008 7:58 am    Post subject: Re: Wave Folders Question... Reply with quote  Mark this post and the followings unread
the other one!
have a look at the schematic
the grinder is at the top and is completely separate from the folder cct.
The grinder is as the name implies Twisted Evil
and the Lockart wavefolder is another bonus altogether. I quite like the Lockhart and have built them as output waveshapers on VCOs.
Nothing wrong with wanting Serge-esque thingies in your synth, if anything kudos for your good taste and sophisticated judgement Very Happy
neandrewthal
PostPosted: Wed Oct 08, 2008 8:31 pm    Post subject: Re: Wave Folders Question... Reply with quote  Mark this post and the followings unread
Is it supposed to just make a sort of PWM effect? I don't find much use for mine since my VCO's already have PWM. The grinder, however is an absolute marvel for it's parts count(just wish it had voltage control) and the "other one" blows my mind continually Very Happy
phdinfunk
PostPosted: Thu Oct 09, 2008 12:32 am    Post subject: Thanks! Reply with quote  Mark this post and the followings unread
Thanks much gentlemen!
--JP
"Nothing wrong with wanting Serge-esque thingies in your synth, if anything kudos for your good taste and sophisticated judgement"
Hmmm, I don't think it's all that... maybe it's just that I'm tired of Moog filters Smile.
andrewF
PostPosted: Fri Oct 10, 2008 4:57 pm    Post subject: Re: Wave Folders Question... Reply with quote  Mark this post and the followings unread
Yes the pulse out does but the tri out is something else - from Ken's description (more accurate and succinct than anything I can write about it) -
"The effect it produces is not like unlike that of the Serge middle wave multiplier - harmonically rich waveforms that can be swept for filter-like effects. It MUST be fed a triangle or sine wave to function properly"
I used one of these for the output circuitry of the EN thru-0-VCO, if you have seen the schematic, half of page 2 was just for the output section. at the time I had no CA3080 chips, so it seemed easier just to drop in a Lockhart wavefolder. funnily enough the pulse output is the most interesting and most often used, probably wasted on a thru-0....but if it sounds good - Do it!! Very Happy
Luka
PostPosted: Sun Nov 23, 2008 6:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
i thinking of adding another 2 diode stages in wave mult
has anyone else done this?
problemchild
melbourne australia
