today> Twyndyllyngs Chez Mosc
Softpot Ribbon Controller
Page 15 of 28 [684 Posts]
Goto page: Previous 1, 2, 3, ..., 13, 14, 15, 16, 17, ..., 26, 27, 28 Next
Scott Stites
Audio files: 96
PostPosted: Wed Nov 26, 2008 10:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
(paraphrasing my kid): "That's like my ribbon controller, only that one makes music".
Wow, Tim - I'm pretty knocked out here! Bravo indeed!!!! I've been banging on this thing for three months, and haven't even come close to making it do that....
Scott
My Site
Danno Gee Ray
PostPosted: Thu Nov 27, 2008 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Is there plans or info for that MIDI clock divider / Utility box anywhere? I'd love to get my hands on one of those as well.
PostPosted: Thu Nov 27, 2008 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I think this is the real beauty of this controller. One can get totally experimental OR totally musical. It's nice to see videos that exploit both aspects. All performances are to be commended. Wink
One more comment about Theff's video is that I really like the fact that he explained his setup in detail. The "GM Voice" drum parts worked well in the composition to. This is a very nice example of DIY electronics making cool music.
To those here in the states, have a wonderful Thanksgiving !!!
Bill
StephenGiles
PostPosted: Thu Nov 27, 2008 2:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
How about 4 ribbons side by side for a pedal steel ribbon controller Wink Could it be possible to create that kind of effect do you think?
wetterberg
PostPosted: Thu Nov 27, 2008 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
sure - although you'd have to assemble four massive pcbs to get there Wink
Scott Stites
Audio files: 96
PostPosted: Fri Nov 28, 2008 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Or stand by for reduced feature set Appendage, which would allow that kind of stuff (initial, slide and bend). I've never compared, but I wonder how the ribbons themselves match for linearity?
Anyway, the document is done. Here it is in all its fruity goodness....
Edit: Changed line on page 29 from "Bend, Slide and TFS" to "Initial, Slide and TFS"
Appendage_Exposed.pdf
The Appendage Exposed: Getting In Touch With Your Appendage
 Filename:  Appendage_Exposed.pdf
 Filesize:  398.71 KB
 Downloaded:  602 Time(s)
My Site
Danno Gee Ray
PostPosted: Fri Nov 28, 2008 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Scott,
Thng lines of that document have confirmed for me that you are a very warped and twisted individual indeed. That can mean ony one thing. You are my kind of people. Well furggin done!
...and thank you.
THeff
Audio files: 33
PostPosted: Fri Nov 28, 2008 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi All,
Well, back from Turkey Day! Thanks for the nice comments on the video. It's fun to do show-n-tell once in a while Laughing, but the credit really goes to Scott Stites and Thomas Henry for their designing, documenting, and sharing.
I built that box about 7-8 years ago and it is a combination of several circuits from the web.
The clock extractor circuit is from here (I think):
http://www.colinfraser.com/m2d/m2d.htm
The divider part is from John Blacet's web sight. http://www.blacet.com/MSdata.html John sells a PIC "MIDI-Sync IC", but I used the Collin circuit instead. If I recall I added an octal buffer to the divider outputs so that the clocks would stop with the MIDI Start/Stop commands.
The MIDI monitor is an older version of the MIDImon from here: http://www.ucapps.de/ I built it when it used a PIC 16F877 and I think it now uses an 18F452. Pretty much all you need is what Thorsten calls "The Core" PCB and an LCD display.
When I get a chance I will crack open the box and confirm what I have mentioned above. Hopefully I documented the changes that I made somewhere. Rolling Eyes Ohhhh, to have Scott's writing and documenting skills (and initiative)! Smile
Regards,
Tim
frijitz
Audio files: 54
PostPosted: Fri Nov 28, 2008 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
THeff wrote:
Here is a YouTube video that I put together today using lot's of DIY modules combined.
Nice!
How do you hit the pitches so accurately out of the air? They must be marked somehow?
Ian
Scott Stites
Audio files: 96
PostPosted: Fri Nov 28, 2008 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks DGR and thanks again for the Video, Tim. I forgot to mention that I think that Klee sequence is bitchin', too.
Ian, I don't know for sure, but I think I can see that Tim has an extra strip there that marks points of reference, which is a pretty good idea, actually. I sometimes do the same thing on my metal plate with a highlighter, though I've not really done anything nearly as musical as Tim does in his video.
Speaking of videos, here's one that just goes through what the voltages act like when the ribbon is prodded in different ways.
My Site
frijitz
Audio files: 54
PostPosted: Fri Nov 28, 2008 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I noticed that. Still, he is nailing those pitches very accurately! Maybe it would be an idea to be able to somehow mount various strips for different ranges, etc?
Ian
THeff
Audio files: 33
PostPosted: Fri Nov 28, 2008 1:08 pm    Post subject: Appendage index scale. Reply with quote  Mark this post and the followings unread
Hey Ian,
Scott is right, I did place a simple piece of white card stock above the ribbon with pencil reference marks.
I started playing it using Initial with some Bend mixed in and then switched to only Slide. Reason for that is, if you use Initial with some Bend mixed in the reference pitch points move. I mean, when you start playing a note and then slide up or down and try to come back to the original pitch, it's in a different spot. This is because of the added Bend voltage that wasn't there when you started.
I haven't figured out a good way around that yet. I guess one thing that might help is to spread some LEDs across the top of the ribbon that would monitor the mix output voltage and light up in 83mV intervals. That would give solid pitch reference points regardless of the scale and mix settings. I don't think you would need every note, but a few in each octave would help.
Regards,
Tim
Danno Gee Ray
PostPosted: Fri Nov 28, 2008 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for the info Tim. Wouldn't it be great if the EM team came up with a project similar to this for those of us who are circuit board challenged...Hint...Hint?
johans121
PostPosted: Fri Nov 28, 2008 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
State Machine wrote:
I shall taunt Johans yet again with pictures and he shall be driven crazy with anticipation ......... Wink
You mean bastard! I'm not going to buy any boards just because of that!
JUST KIDDING! HAHA! Seriously, I was just kidding. For real. I'm sorry. Really, I am......
Don't feed me Indian, you WILL regret it!
-Jim
PostPosted: Fri Nov 28, 2008 7:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
I gotta say Scott,
that is one amazing piece of ingenuity you have conceived and changed the nappies on there! Very Happy
And an instructional diatribe which even surpasses the instructional diatribunal dissertation of the Klee! Very Happy
No wonder you've been so quiet lately! Laughing
Great work.
When you sent me the copy of the schematics and PCB artwork I thought, "It's just a bloody voltage divider for Christ's sake! What's all this other shit for?!?!" Laughing
But now,..... I have seen the error of my ways. My eyes have been opened ( Shocked ) to the subtle beauty and deep seated smartness of the Scott Stites Ribbon Controller.
Scott Stites
Audio files: 96
PostPosted: Fri Nov 28, 2008 11:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, it's just a pot with some extra junk added. Laughing
Yeah, Ian, I think some way to mark positions is the way to go. An LED at 0.083V spacing might be a nice guide, but it doesn't take far to go from 0.083V to get off pitch, but it still might be a spiffy system.
I think a standard set of positional markers works out pretty well - like on a guitar so you know which fret is which at a glance. Like I mentioned, I'd marked my metal plate with a highlighter some time back, and I tried playing pitched music just using those for reference, and it actually worked out pretty well. Setting a wide initial voltage with a low-medium bend voltage makes it pretty easy to slide up and down to pitches by ear or by marker. Then you can remove pressure and go to a known value pretty easy using a mark as a reference if you want to start a new note. You still have a wide range, but the wide range doesn't make pitch bends "tricky" if you can picture what I mean.
The mixed output voltages are continuously variable, but having played the thing a while, I find it easy to set a range. I think if someone wanted to (and Tim has mentioned this to me privately) fixed ranges could be set up on a rotary switch. The fixed voltages would be a good source if someone wanted to do that. I believe the optional connector on the PCB provides an extra feed for those voltages.
Cheerios,
Scott
My Site
StephenGiles
PostPosted: Sat Nov 29, 2008 1:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah ha - it's turning into a guitar Laughing I can see myself with a guitar like object around my neck sporting the ribbon controller. Perhaps I might give my old Bo Diddley special a new lease of life!!
PostPosted: Sat Nov 29, 2008 1:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Well it could just as easily condition the output of a string against fretted resistor chain as it does a softpot. I s'pose it just depends on whether you want a fret to equal a semitone or not. With the TFS concept, you could even get your teeth into it, ala Jimi Jarre style! Laughing
THeff
Audio files: 33
PostPosted: Sat Nov 29, 2008 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey DGR,
Putting a EM PCB together to give you all of those functions would not be hard, but you would need to get permission from Thorsten and Colin if you used their PIC solutions.
Scott,
The more I think about the LED markers for the Appendage, I'm not sure it would really help, if it monitors the output CV. It would really only show you where you are (and your ears do that Rolling Eyes), not the next note you want to hit...Doh!
Maybe some simple printed indexes for for several different scales would make the most sense. A little clear plastic holder like the shelf tags at the store would be easy, if you could find them 500mm long.
Regards,
Tim
Danno Gee Ray
PostPosted: Sat Nov 29, 2008 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
THeff wrote:
Hey DGR,
Tim, I know,
I was only trying to goad the collective geniuses into maybe developing their own EM brand of that box from scratch. I just think that having something like that would be way too cool.
Dan
Scott Stites
Audio files: 96
PostPosted: Sat Nov 29, 2008 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Of course, there is the option of quantization as well. Bill and I have discussed this, and is a reason why the optional port has been added to the board - MIDIfication, OSC, Quantization, Voltage Permutation and the bit about using the ribbon in a sort of touch sequencer app are all along those lines.
However, regarding quantization, an existing external quantizer will work just fine, and will work quite well for sliding if you consider the interaction of the Initial and Bend voltages. You would quantize the Initial voltage and mix in the bend voltage. The quantizer would precisely fix the initial note and the bend voltage would slide above and below that point in smooth, unquantized increments.
My Site
frijitz
Audio files: 54
PostPosted: Sat Nov 29, 2008 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, right. Just a minor variation on the Paia design. Sure. Laughing
Ian
frijitz
Audio files: 54
PostPosted: Sat Nov 29, 2008 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Just as an aside, the non-fretted string players use the varying width of the neck as part of their sensory feedback loop. I don't know if something tactile along those lines would be useful. But you may not always want to be looking at your... umm ... you know.
Ian
Scott Stites
Audio files: 96
PostPosted: Sat Nov 29, 2008 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Huh! I did not know that!
My Site
PostPosted: Sat Nov 29, 2008 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Really all this talk about using reference markers along the length of the ribbon to hit notes with some musicality really makes one appreciate the folks who are virtuosos at playing a Theremin by which there are no references. For example Kevin Kissinger. He is amazing to watch and have seen him play live. Theremin players judge the distance from each antenna to play a piece of music. It's a matter of training and practice like anything else and suppose it will be the same with the Ribbon Controller. I have seen some guys playing these ribbon controllers in some videos with incredible accuracy with no visible references at all. Cool
For me personally, In more musical applications, external quantization of say 12 notes, or one full octave, across a 500 mm ribbon will leave less room for error. One could just put "note" references along the length of the ribbon. The ribbon can be transposed an octave at a time with simple offsetting by the standard 1V/Oct. Artificial vibrato (not using your finger and wiggling it back and forth) can be impressed on the quantized voltage I would suppose? A MODULATION wheel, feed by an LFO, could be quantized, along with the ribbon controller, and then used to add or subtract the amount of vibrato you require.
Bill
