 Forum index » Instruments and Equipment » MAX/MSP - Pd
I have a simple question about MaxMsp.
Page 1 of 1 [15 Posts]
keldhansen123
PostPosted: Fri Nov 26, 2004 2:54 am    Post subject: I have a simple question about MaxMsp. Reply with quote  Mark this post and the followings unread
Hi ...
Can some one help me with maxmasp in here? I hope so
Keld Hansen
Audio files: 226
PostPosted: Fri Nov 26, 2004 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome keldhansen123, glad to have you here.
I don't use MAX/MSP myself, but there are a few people here that do. Hopefully someone will chime in.
play
PostPosted: Fri Nov 26, 2004 7:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey. Haven't been very active on the board lately ("bad moderator, sit!") but, well, here I am. What seems to be the problem?
keldhansen123
PostPosted: Sat Nov 27, 2004 2:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi ... Thank you for helping ...
I just need some one to explain this patch Smile Is should be a pretty simple patch. But i dont get the math in it.
Here are my questions for the patch:
*What does the "signal multiply operator" ?
*Why do they use 127 in this patch?
*And why du'o they divide by 127?
*Do they divide by 127 because MaxMsp only can handle 1 and 0 ?
I hope you understand my questions Wink
Keld
keldhansen123
PostPosted: Sat Nov 27, 2004 2:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is the patch ...
patch1.zip
No comment
 Filename:  patch1.zip
 Filesize:  708 Bytes
 Downloaded:  423 Time(s)
diskonext
PostPosted: Sat Nov 27, 2004 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Well,
Max can represent any number, but when working with signals the 0..1 range is most commonly used.
The real reason the / 127's are there is because the hslider-object (the horizontal slider) has a minimum increment of 1 and defaults to 0..127 (which conveniently resembles the normal MIDI values), which needs to be mapped back to the 0..1 range.
Max/MSP comes with excellent documentation, if you downloaded the demo without the documentation check out: http://www.cycling74.com/products/dldoc.html
The tutorials are really helpful and to the point, as well.
-diskonext
:wq
play
PostPosted: Sat Nov 27, 2004 5:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree, grab the manuals. A lot of the stuff in there is helpful in a general way. For instance, I didn't really get FFT/convolution stuff until I read the explanation in the MSP manual. Very helpful and straight forward.
keldhansen123
PostPosted: Sun Nov 28, 2004 4:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot ... this really help Smile
But i have a last question ... what about the "expr 127-$1" ... I dont get that ...
Keld
play
PostPosted: Sun Nov 28, 2004 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
'expr' is used to evaluate mathematical expressions and whenever you see a '$' symbol in max it means a variable. The number after the '$' is the number of the inlet counted from left to right so 'expr 127 - $1' can be read as 127 minus whatever is coming into the first inlet. This is to make the values inverted as compared to the values of the left-hand operations to make the panning work. If one of the values being multiplied by an audio signal was not inverted then this patch would just be a very complicated volume control.
keldhansen123
PostPosted: Mon Nov 29, 2004 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi ... Thanks a lot Smile
Now I have another problem Smile
I have attached the patch.
I dont think that it is the patch which is the problem, but i think it's a problem with our soundcard settings in MaxMsp. The soundcard is a Soundblaster Live Value (4 channels).
The problem is that the patch links the front and rear speakers rather than distinguish them from each other.
Can some one help me?
Keld Hansen
patch2.zip
 Filename:  patch2.zip
 Filesize:  1.11 KB
Audio files: 226
PostPosted: Mon Nov 29, 2004 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not running MAX so I can't help with the problem, but would it help if I enabled another type of file extension for MAX patches?
diskonext
PostPosted: Mon Nov 29, 2004 6:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Most common MAX filetypes:
.mxb
.mxt
.pat
-diskonext
:wq
diskonext
PostPosted: Mon Nov 29, 2004 6:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
The patch seems to work fine.
Check to see if outputs 1, 2, 3, 4 (see dac~) are correctly routed to their respective channels, maybe?
There are both logical channels (which you use with dac~ and adc~ objects), and physical channels. The mapping between them is in Options->DSP Status->I/O Mappings.
-diskonext
:wq
Audio files: 226
PostPosted: Mon Nov 29, 2004 8:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
.mxb
.mxt
.pat
Thanks, I've enabled these filetypes... .
play
PostPosted: Thu Dec 02, 2004 8:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks mosc.
Patch looks fine to me. I have a SBextigy running on this laptop and Max doesn't seem to want to recognize the rear channels. Perhaps this is a problem with creative cards in general. I know that ableton live has problems with this as well. The NI software seems to handle SB's pretty wel though. I would suggest going out and buying a M-Audio audiophile 24/96 card for $100. Problem solved.
