aquanaut
Joined: Jan 31, 2003 Posts: 18247 Location: Durham, NC
Audio files: 225
Posted: Fri Nov 26, 2004 11:48 am Post subject:
To me, the drum track sounds kinda scratchey, but I'm not into this sytle. Maybe that's the effect you want. _________________ --Howard
my music and other stuff |
aquanaut
Posted: Fri Nov 26, 2004 12:06 pm Post subject:
I'm not sure of what i want when i'm working or where i'm going... i kinda go with what the machine spits out. but your right there's some eq to do on the high end and on the mix stage it was more annoying than that. listening to it again i think there just a few sounds that needs to be tamed..and the kik..well that one is garbage. |
paul e.
Joined: Sep 22, 2003 Posts: 1567 Location: toronto, canada
Posted: Sun Dec 05, 2004 10:17 am Post subject:
cool track...enjoyed it as is...like the synth sounds in the background
btw..did you recently change your username... ? _________________ Spiral Recordings |
aquanaut
Posted: Sun Dec 05, 2004 10:43 am Post subject:
ya i just changed it...the previous one was a symbol. |
zynthetix
Audio files: 10
G2 patch files: 13
Posted: Sun Dec 05, 2004 12:12 pm Post subject:
Neat track aqua. This one's in the playlist now. I like the absence of a kick and snare personally, so I wouldn't worry too much about the kick. Some percussive sounds struck me as scratchy, but not in a bad way. These percussive sounds contrast very well to the spacey pads in the background, so I'd not change them (just fix whats bothering you with it). |
Posted: Tue Dec 07, 2004 6:03 pm Post subject:
I like this one. I didn´t find any problems here at all. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
seraph
Editor
Audio files: 33
Posted: Wed Dec 08, 2004 12:38 am Post subject:
Re: Diskenesia |
aquanaut wrote: | ...now comments are more than welcome. |
I find it pleasant  _________________ homepage - blog - forum - youtube
Quote: | Don't die with your music still in you - Wayne Dyer |
aquanaut
Posted: Wed Dec 08, 2004 2:41 am Post subject:
Thanks for listening. It was done with the instruments in Logic 7. The more i play with them the more i find how much they can't do what the XT and the Ultra can do in term of amplitude and pitch modulation.
i recently bought a m-audio usb midi interface..is it me or midi over usb is simply not tight. anyway that case is closed. the G3 with the old serial macman interface is way more precise..that little thing better not break.
thanks again |
seraph
Editor
Audio files: 33
Posted: Wed Dec 08, 2004 3:17 am Post subject:
aquanaut wrote: | The more i play with them the more i find how much they can't do what the XT and the Ultra can do in term of amplitude and pitch modulation. |
when you say XT I guess you mean the Waldorf XT and what about this "Ultra"  _________________ homepage - blog - forum - youtube
aquanaut
Posted: Wed Dec 08, 2004 3:36 am Post subject:
sampler Emu e5000 Ultra. |
Posted: Wed Dec 08, 2004 4:04 am Post subject:
I have that big Steinberg 1 U Midex thingie. It uses USB. I am mainly using that one with the dual 1.2 ghz G4. Midi timing is OK, but not what I would call great. However it is far better than how I remember midi timing from way back in the 80s. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
aquanaut
Posted: Wed Dec 08, 2004 4:58 am Post subject:
i have two drivers in there.
m-audio usb support
emagicusbmididriver
should i put the emagic driver somewhere else or it's essential
Carlo? |
Posted: Wed Dec 08, 2004 5:00 am Post subject:
do not move the drivers.. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
seraph
Editor
Audio files: 33
Posted: Wed Dec 08, 2004 7:43 am Post subject:
aquanaut wrote: | i have two drivers in there.
m-audio usb support
emagicusbmididriver
Carlo? |
well...the emagic driver is needed in case you use their midi interfaces but as Stein says I wouldn't touch it  _________________ homepage - blog - forum - youtube
Posted: Wed Dec 08, 2004 8:24 am Post subject:
The Emagic USB drivers should be left alone. Apple might suddenly decide to update/patch it.. and now they have made a kind of integration of Garageband with the Logic products. Unless you really know what you are doing and why.... leave those files alone  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
aquanaut
Posted: Wed Dec 08, 2004 1:21 pm Post subject:
Thanks. i taught the emagicusb driver was only needed if you had an emagic interface. maybe this driver interfere with the m-audio one...i don't know..timing is not there. the 1/4 note is kind of slightly different all the time. its not so bad but when i used the g3 i saw the difference right away..upgrades waiting for tiger. |
Posted: Wed Dec 08, 2004 2:07 pm Post subject:
Hmm... if the 64s are going Steve Reich in ya.. then I guess you should check the Logic settings. That app is deep. Carlo s probably an excellent diver. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
aquanaut
Posted: Wed Dec 08, 2004 2:15 pm Post subject:
i'm gonna look around again..it's the interface because the timing is fine when using an internal instrument.
Quote: | if the 64s are going Steve Reich on ya |
not sure i'm getting this one..you mean anal precision |
Posted: Wed Dec 08, 2004 2:48 pm Post subject:
I tend to use a hardware MIDI clock with my system (I use a PC though). Software, in my mind, is too un-dependable (kernel interrupts, USB driver, USB physical, etc.) for generating a clock, so I sync software to external clocks, then calibrate for latencies. Audio has timed DMAs & buffers, so it is made to be accurate, but MIDI drivers are entirely software driven...very bad.
I have the Emagic AMT8 on USB...which is *supposed* to get really great timing under Logic (It more or less pre-loads the midi data to the AMT8, then sends it out when a clock arrives). I have never used it with Logic, so I think it reverts to a "standard" mode, which would be like any other interface. Timing doesn't seem bad, but like I said, I tend to have my software sync to my hardware.
So, in short, try using a hardware clock if you've got one, and sync Logic to that. |
Posted: Wed Dec 08, 2004 3:22 pm Post subject:
aquanaut wrote: | not sure i'm getting this one..you mean anal precision |
I said Steve Reich, not anal..
Flickr |
aquanaut
Posted: Wed Dec 08, 2004 3:24 pm Post subject:
good idea. That might do the trick.
Carlo. There's one thing i find very annoying with Logic. Say you input midi note for a bassline with the mouse. If you go back and work on the drum part the lenght and the velocity info of the previous note is remembered. can you desactivate that? |
aquanaut
Posted: Wed Dec 08, 2004 3:31 pm Post subject:
Quote: | if the 64s are going Steve Reich in ya.. |
hey remember i'm french..i'm kinda bad with the english subtelties..even morse when it's mixed with norvegian humor.
phpspell does not seem to work with safari |
Posted: Wed Dec 08, 2004 3:43 pm Post subject:
aquanaut wrote: | Quote: | if the 64s are going Steve Reich on ya.. |
hey remember i'm french..i'm kinda bad with the english subtelties..even morse when it's mixed with norvegian humor. |
Music For 18 musicians
click here
Steve Reich composed the music in order to explore timing issues and phasing etc. Long story.  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr Last edited by elektro80 on Wed Dec 08, 2004 3:50 pm; edited 1 time in total |
seraph
Editor
Audio files: 33
Posted: Wed Dec 08, 2004 4:19 pm Post subject:
aquanaut wrote: | Say you input midi note for a bassline with the mouse. If you go back and work on the drum part the lenght and the velocity info of the previous note is remembered. can you desactivate that? |
I never input notes in step time so I would have to check the manual for that but it seems logical (pun intended) to remember "the lenght and the velocity info of the previous note" but I am sure you can alter that through key commands (maybe ) _________________ homepage - blog - forum - youtube
