The DoubleDeka Ultrasonic VCO
Page 5 of 6 [145 Posts]
sduck
PostPosted: Mon Jul 06, 2009 7:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another question -
Switch polarity. I'm using the bridechamber panel, with the 2 switches. I realize that if I get the polarity wrong, I can just spin them 180 degrees, but I tend to wire things pretty tight and getting things right the first time is nice.
S1 - I connect S1a to the middle lug, and S1b to which lug to make it work correctly with the panel?
The Lin cv ac/dc switch - which way should I wire this? One direction the signals being routed through a cap, the other way it's straight - which one's ac, which is dc?
frijitz
Audio files: 54
PostPosted: Mon Jul 06, 2009 8:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
The bottom one, I believe, although I don't actually have the bridechamber unit.
Thru the cap is ac.
Ian
sduck
PostPosted: Tue Jul 07, 2009 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
johans121
PostPosted: Thu Jul 09, 2009 12:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I just built #1 out of 2. This is one amazing module! The different timbres you can get out of it as a VCO are awesome, but I found that using it as a mod-source more than doubles its value. Audio rate modulation is amazing with this thing. Hooking one of its two VCO's outputs up to the V/O input on a filter and then tweaking the sliders creates some wicked sounds!
Great job Ian! Can't wait to get my second one built! Let the Audio Maelstrom begin!
(someone is going to have to put me away after I get these and my teezers going!)
ALSO several things of note regarding the PCB and the copy of the documentation that I received in 09/2008 (don't know if it has been updated):
1) The outputs on the PCB are labeled incorrectly. The pad marked OutA is really OutB & vice versa
2) The BOM lists a TL074 for U9 when it really calls for a TL072
3) On the BOM R30 is listed TWICE, the first value as 10kOhm & the second 1MOhm. R30 is supposed to be (according to the schematic 10KOhm)
4) R31 is not listed on the BOM, it is supposed to be 1MOhm (once again, according to the schematic)
-Jim
Don't feed me Indian, you WILL regret it!
-Jim
frijitz
Audio files: 54
PostPosted: Thu Jul 09, 2009 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Glad you like it! I'll have to try using it as a mod source.
Thanks for pointing those out. Some of those have been corrected; I'll recheck them all when I get a chance.
Ian
frijitz
Audio files: 54
PostPosted: Thu Jul 09, 2009 7:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can't find any error in labeling. Perhaps check you didn't switch the J4/J4a wiring?
This has been corrected.
This is a single typo and has been corrected. In the line "1 MOhm R30, R35", R30 should be replaced by R31.
Ian
sduck
PostPosted: Thu Jul 09, 2009 7:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just finished mine! Very cool sounding vco - haven't had a chance to do more than scratch the surface yet.
I didn't have any of the problems Johan had with the parts and docs I got from The Bridechamber. I was a bit worried about the out A and out B, but mine are labeled correctly. The way I had mine wired, if it needed fixing, it was going to be a big problem, and of course I did that bit of wiring the night before Johan posted about his problem.
The one thing I had to go back and fix is something that could be clarified a bit in the comments section - the wiring for the octave switches. For some dumb reason I assumed the letters on the pcb would correspond to the numbers on the switch - a=1, b=2, etc. But that's not how they work - it's backwards. Oh well, it didn't take long to fix.
Ian Fritz DoubleDeka VCO front
Ian Fritz DoubleDeka VCO back2
fluxmonkey
PostPosted: Mon Aug 31, 2009 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
almost done... anybody have a mouser part number for the 2 rotary switches?
b
www.fluxmonkey.com
sduck
PostPosted: Mon Aug 31, 2009 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I used 105-SR2612F-18-21RN from mouser for the ones in the pictures above.
Scott Stites
Audio files: 96
PostPosted: Sat Sep 05, 2009 9:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Ian,
What is the frequency range of the undivided core HF output?
Tnx,
Scott
My Site
frijitz
Audio files: 54
PostPosted: Sat Sep 05, 2009 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Officially, 120 kHz. This gives you fundamental frequencies up to 12 kHz. If you need more range, you can get another octave by dividing the output into two identical 5-step sequences.
Unofficially, I believe you can run it up to ~200 kHz, but I can't vouch for repeatability or reliability at the extreme end.
The circuit is very similar to Fig. 4 in the data sheet.
Cooking something up?
Ian
Scott Stites
Audio files: 96
PostPosted: Sat Sep 05, 2009 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
120 kHz Shocked
That's plenty!
Oh, someone expressed a wish over at MW for an SH3 type VCO, and I'm pretty sure the DoubleDeka core could easily pull it off using the HF output to drive the (very simple) shaping function of those synths. Even the PWM (Roland calls it chorus), which is just PWM derived from the shaped 8' sawtooth. In this case, one could just put the derived waveforms on sliders with a waveform selector for each slider. It wouldn't look all that different from the DoubleDeka we see today.
Cheerios,
Scott
My Site
frijitz
Audio files: 54
PostPosted: Sat Sep 05, 2009 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, you saw that first! I posted your idea over there, just to see if anyone bites.
Ian
sduck
PostPosted: Mon Oct 05, 2009 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ack! A major problem has occurred. Why, I don't know. I hadn't used my doubledekka for a while, in fact had removed the power cable, as I'm short of power cables and needed it elsewhere. Plugged it back up, and I'm only getting one pitch out of it - the knobs and pitch cv ins aren't doing anything. The sync and ring in jacks do work, and the sliders are affecting the sound, so my guess is a chip has decided to die on me - but which one? Or something else? Any ideas are welcome.
Edit - a quick look at the scematics makes me suspect the OPA2227 is to blame - ? I used the part kit from Bridechamber - are these chips tempermental or anything?
frijitz
Audio files: 54
PostPosted: Mon Oct 05, 2009 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
sduck wrote:
Ack!
Indeed! Very odd. Do you have a DVM you can clip in? It sounds off hand like U1 could be bad, so if you could look at its two outputs as you change the coarse freq control?
Ian
sduck
PostPosted: Mon Oct 05, 2009 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yup, I'm getting a flatline from that chip. I've put one in my basket for my next mouser order. They have several different kinds - a OPA2227P, a OPA2227PA, and several others - any kind that's recommended?
frijitz
Audio files: 54
PostPosted: Mon Oct 05, 2009 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think I just get the least expensive one.
You can put in any standard dual amp in its place temporarily. TL072, etc.
Very odd that it got fried. You might want to check the circuitry around it carefully to make sure there isn't some kind of short somewhere.
Keep me posted, please!
Ian
sduck
PostPosted: Mon Oct 05, 2009 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I put a TL072 in, and it works - at least the knobs and cv's work. I'll wait until I get the OPA2227 to calibrate it - that's what I was hoping to do today, but it can wait.
frijitz
Audio files: 54
PostPosted: Mon Oct 05, 2009 6:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, you nailed it down pretty quick. thumleft
Don't see why that should have burned out -- the converter circuit is totally standard.
Ian
druish
PostPosted: Tue Mar 23, 2010 6:57 pm    Post subject: DoubleDeka
Subject description: WOW
HOLY @#$%! This thing is sooo badass! Just playing with the FM alone, this badboy RIPS!
KUDOS to Fritz! Very Happy
 Filesize:  757.41 KB
 Viewed:  559 Time(s)
 Filesize:  702.17 KB
 Viewed:  568 Time(s)
Abby Normal
PostPosted: Fri Mar 26, 2010 5:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can't help but this that this D-Deka module would look fantastic using those illumintated sliders, like the one in this link:
http://2.bp.blogspot.com/_FMBJEkaC8Lw/R7J5yYEgPCI/AAAAAAAAO_I/i8uoOUPaDs4/s1600-h/f5d0_1.JPG
synchroton
PostPosted: Sat May 01, 2010 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm wondering: would it be an easy mod to add sync to this oscillator? I'm thinking this might have some potential video synthesis application, given the high frequency of the core... But immediately it seems most useful if it could be sync'd to the horizontal or vertical refresh pulse...
frijitz
Audio files: 54
PostPosted: Sat May 01, 2010 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
It has sync -- two varieties, actually.
Ian
synchroton
PostPosted: Sat May 01, 2010 2:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Heh! Guess I didn't look so closely. Just got excited when I saw how fast it was running...
Abby Normal
PostPosted: Sun Jul 25, 2010 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
What size screws are needed for the front panel to slider mounting? I have 2-56 size screws, but they don't seem to fit. It seems like the wrong thread pitch.
I'm also wondering if I'm missing any documentation. All I have is the dd_board_doc.pdf. Is there anything else that I might be missing?
Thanks for any help...
