My first patch
Page 1 of 1 [4 Posts]
DanielW
PostPosted: Fri Oct 09, 2009 12:56 pm    Post subject: My first patch
Subject description: Oscs as slaves to LFO = dark noise
OK, after a couple of weeks with the Wizoo guide, tutorials and this forum, this is the first patch I've made that I consider useful.
Useful to make noise, that is. The sound created will be further f***ed up with all effects required in Pro Tools.
Try the higher octaves!
LFOstyrOSC01.pch
A simple patch using an LFO as master to three oscillators creating dark noise.
 Filename:  LFOstyrOSC01.pch
 Filesize:  1.71 KB
 Downloaded:  332 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Oct 09, 2009 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, my Modular isn't hooked to the computer, but I 'cleaned up' the Patch a bit... Actually a little more than a bit Smile
It's always handy to follow the red lines...
Wout
LFOstyrOsc01.pch
Reshuffled it...
 Filename:  LFOstyrOsc01.pch
 Filesize:  1.71 KB
 Downloaded:  330 Time(s)
DanielW
PostPosted: Sat Oct 10, 2009 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot for the input, Wout!
One thing though, why de-assign detune of oscs B and A from the knobs? I guess the freed-up knobs could be used for clip and pan, but was there any special reason you did that?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Oct 10, 2009 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
What I did was changing the the two Osc modules in 'cheaper' ones. I didn't check the Knobs though...
Using lesser DSP load makes it easier to build further without loosing Voices. So I wonder why there is a 3% nothing in the Global window... (that Filter...)
If you don't use it and there is a module without it, it's always better.
Visual it is much easier to study what is going on in the Patch. Main rule: follow the Audio set up.
Wout
