midi channels and modular
Page 1 of 1 [6 Posts]
thoffir
PostPosted: Mon Nov 16, 2009 11:05 am    Post subject: midi channels and modular Reply with quote  Mark this post and the followings unread
let's say there's a external midi controler with limited number of knobs. can modulars be configured in a way, that controller's knobs CCs on one midi channel are assigned to some parameteres in patch (ADSR on osc1) and the same knobs on another midi channel control other parameteres (for example ADSR on osc2).?
Audio files: 297
PostPosted: Mon Nov 16, 2009 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Wit the G2 you could, using MIDI modules .. not with the NM Classic though ... unless using some external MIDI remapping / processing tool.
oisin
PostPosted: Mon Nov 30, 2009 8:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
i suppose if you really wanted to do this you could manually change the midi channel on the micro modular (i think its the 2nd knob + shift) while changing the channel on the controller. maybe a bit too awkward..
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Dec 01, 2009 1:34 am    Post subject: Reply with quote  Mark this post and the followings unread
You mean something like MidiMod on a computer?
Wout
iPassenger
G2 patch files: 78
PostPosted: Tue Dec 01, 2009 7:34 am    Post subject: Re: midi channels and modular Reply with quote  Mark this post and the followings unread
Can your controller not be set to send different dials on different midi channels, many can. My Ozonic for example is set-up with the one dial set to controller 70 on midi channel 14 (for switching variations on my nord g2) regardless to what the rest of the Ozonic is midi channel assigned to.
iP (Ross)
Roland Kuit
G2 patch files: 127
PostPosted: Tue Dec 01, 2009 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
for pc is a program called MIDI-OX(freeware). like Jan say's, remapping is an option.
