kb
Posted: Thu Aug 27, 2009 6:58 pm Post subject:
very inspiring! |
I just ebay'ed some ba6110's right now after reading this! can we get someone on the forum to work on a pcb for this?
since my hs-60 is now a lab of sorts (for those acetone-80017a experiments on Youtube), I think I'll try this maybe with the pile of cem3328's I have sitting around from a dead Mirage (might be not as nice sounding, though)
I did something similar (though a different kind of Frankensteining) on a SixTrak:
http://www.flickr.com/photos/37595587@N00/sets/72157616967698662/
It was a lot of work. I should post sound samples sometime soon... |
Mooger5
Posted: Fri Aug 28, 2009 4:36 pm Post subject:
Hey I´ve seen your work before. That was a major achievement. Congrats
Please post some soundfiles. The DW-6000 was my first serious synth and I remember the filters sounding very, very nice. I think they were modelled after the SSM2044!
I haven´t heard the CEM3328, but it´s likely it´ll sound closer to the IR3109 than the SSM2044. And it has a built-in buffer so there will be one opamp less for you to be concerned with.
And a PCB would be great for this project, I definitely agree
Regards.
Edit (3-11-09) - I meant the NJM2069AD was modelled after the SSM2040, not the 2044, sorry for the typo... |
Mooger5
Posted: Thu Sep 03, 2009 2:50 pm Post subject:
To the moderators: I got two Topic Reply Notifications since my last post. But there aren´t obviously new replies No complains here, just letting you know  |
Joined: Apr 03, 2004 Posts: 24563 Location: The Netherlands, Enschede
Audio files: 304
Posted: Fri Sep 04, 2009 8:55 am Post subject:
Such can happen when something was actually posted but deleted later, for instance when someone posted a spam message that got deleted, or someone changing their mind ... not sure what happened here though. _________________ Jan
Mooger5
Posted: Fri Sep 04, 2009 9:43 am Post subject:
I see. Alright, thank you.  |
radek tymecki
Posted: Mon Sep 07, 2009 11:16 am Post subject:
| when I'll make 6 new ssm boards... what should I do after placing em in synth? what calibrations should be made? |
Mooger5
Posted: Sat Sep 12, 2009 5:08 am Post subject:
| Download the 106 Service Manual and follow the instructions. |
kb
Posted: Tue Sep 15, 2009 2:30 pm Post subject:
do you have the CV ranges for the Juno-106? |
hi mooger5,
in your work, I'm guessing you measured the full CV ranges for cutoff, resonance, and VCA that go to the 80017a "slot"
could you possibly post those? I can measure them in my Juno, but if you've got them handy, that'd be great.
thanks! |
Mooger5
Posted: Wed Sep 16, 2009 4:07 am Post subject:
I measured the CVs in the beginning but didn´t save the notes. I remember I got good DC readings for cutoff. At pin 2 of the slot, for resonance, I got very slight variations, in the order of 0.5 volts. The change was probably in current, but then I noticed there is already a transistor inside the 2044, so I removed TR18 from the voiceboard and it worked. I didn´t bother with the amount of voltage going to the filter chip because there are trimmers for that in the voiceboard. You should get good DC readings at the emitter of TR18. For the VCA control at pin 11 it´s the same thing (except the transistor is not to be removed as any OTA will need it).
I´m on vacations until the end of the week but I will redo the readings when I return home. |
Ricoche
Joined: Dec 19, 2009 Posts: 8 Location: Nagano, Japan
Posted: Sat Dec 19, 2009 6:37 pm Post subject:
| Mooger5 wrote: |
It´s also convenient to mount IC sockets like the one in the picture. It´s 11 pins but as there´s a gap in the voiceboard between pin 1 and pin 2, I cut each socket to measure 12 pins and brake the second pin with plyers so the sockets fit perfectly. Then I seal the unused hole with solder to prevent wiring mistakes.
Can anyone recommend a place online to find mount IC sockets like the one pictured above? Much appreciated. Thanks!
Jim |
Sebo
Posted: Sun Jan 24, 2010 11:03 am Post subject:
Hi all:
I finally did the acetone bath to some 80017a.
I took the coat away of 3 chips using acetone and 2 of them worked OK.
The third one, worked too, but not quite right, the VCA worked, but the VCF
behaves strange, the resonance have little effect and the cuttoff have a non
linear response (very weird).
Anyway 2 of 3 is a good number.
Now I have 5 coated working voices in my Juno, and 2 uncoated working
voice for a total of 7, this left me with a spare voice. I will start to decoat
the working voices one by one to prevent them from failing in the future, and if
something goes wrong I will stop decoating and still having 6 working voices. _________________ Sebo
My Music:
https://www.facebook.com/cosaquitos/ |
Sebo
Posted: Mon Jan 25, 2010 10:39 am Post subject:
Just to be clear, the 3 voices I peeled off, were non working before the process. _________________ Sebo
My Music:
radek tymecki
Posted: Tue Jan 15, 2013 10:58 am Post subject:
can somebody check if it's ok?
valvusmusicus
Joined: Nov 06, 2009 Posts: 56 Location: Bournemouth. UK
Posted: Sat Feb 02, 2013 5:21 pm Post subject:
Just wondered if anyone has produced an 80017A replacement board using the 3080/SSM2044/roland chip replcement
Willing to board up aload as have facilities at work-and get involved in test/design-my MKS30 and Juno 106 both need replacement-and dont want to drop 40 plus Euros per chip-rather design something new, using readily available components! |
Mooger5
Posted: Mon Feb 18, 2013 3:01 am Post subject:
[quote="radek tymecki"]can somebody check if it's ok?
Looks very neat! I´ll check the circuit later.
Before making the PCBs, try to arrange the components on a perf board with the same dimensions just to check for clearance in the voiceboard. Some electrolytics sit very close to where the 80017As were.
I was a bit concerned about heat dissipation, as the SSM chips get a little warm. But then so did the 80017As. |
Mooger5
Posted: Mon Feb 18, 2013 4:37 am Post subject:
Radeck, there are some errors in your layouts.
SSM pin 2 should go to voiceboard pin 2.
Output of opamp should go to voiceboard pin 3.
I´ll check the rest later.
Edit - OK, sorry. I now see what´s going. The blank space in the voiceboard is counted as pin 2. I´ll check later in the evening. |
radek tymecki
Posted: Mon Feb 18, 2013 5:43 am Post subject:
| yes you must be careful with pins coz empty one has also a number [2] |
Mooger5
Posted: Mon Feb 18, 2013 6:33 am Post subject:
| Absolutely. Well I just checked your layout and everything seems ok! |
radek tymecki
Posted: Mon Feb 18, 2013 10:32 am Post subject:
great!
i'll make proto run and then with your help i'll calibrate ju106!
if anyone will be interested i'll provide pcb projects  |
Mooger5
Posted: Tue Feb 19, 2013 8:26 am Post subject:
| radek tymecki wrote: | great!
Although I have not much time for DIY tronics anymore, I´m definitely interested!
I´d even buy six PCBs to populate in a hopefully non distant future, home-made or manufactured.
On about calibration, finding the optimal high resonance amount is the trickiest part. Excessive self-oscillation will make the filter go wild and won´t track the kbd. For the rest of the procedure it´s just like with the 80017A, if not easier. The BA6110 is the best. |
snapper
Posted: Fri Aug 18, 2017 5:27 am Post subject:
Roland JUNO-106 80017A Replacement Subject description: SMD Version with new SSI2144 |
338.03 KB |
| Viewed: |
565 Time(s) |
286.08 KB |
| Viewed: |
523 Time(s) |
26.24 KB |
| Viewed: |
514 Time(s) |
Mooger5
Posted: Mon Aug 21, 2017 3:39 pm Post subject:
Uli, is that you?
Seriously, very nice
You know, I would ditch the BA6110. It sounds great but THT kind of defeats the purpose. I´d consider replacing it with LM13700 or CA3080 in SOIC format.
http://www.retroamplis.com/CA3080-SM
Plus, unless the Ba is to be soldered directly, without a socket, and its pins bent so that it will sit in parallel to the board, there might not be enough clearance due to the external components sitting very close to the voice chips.
Or at least place it on top, or vertically like I did in my prototype.
A more serious drawback with this design that prevents it from being used plug and play style is the pesky PNP transistor connected to pin 2. The SSM2044 already has one on-chip, so the PNP in the voiceboard must be bypassed, otherwise the resonance won´t work.
Unless there´s a way to revert the control voltage signal back to the value at R107, this 80017a replacement is deemed permanent. |
aluedt
Posted: Tue Mar 06, 2018 8:24 am Post subject:
| Mooger5 wrote: | Uli, is that you?
Hey Mooger5,
regarding the above transistor TR18 I have a question for clarification. Is it sufficient to bridge the collector emitter or is it better to unsolder the transistor?
We're testing currently testing to build replacement chips for our Juno 106 here (see attached photos). If anyone is interested, feel free to get in touch.
--Andree
237.09 KB |
| Viewed: |
466 Time(s) |
259.92 KB |
| Viewed: |
481 Time(s) |
102.48 KB |
| Viewed: |
489 Time(s) |
96.59 KB |
| Viewed: |
459 Time(s) |
Mooger5
Posted: Tue Mar 20, 2018 1:34 am Post subject:
| aluedt wrote: |
--Andree |
Very neat.
I´d say it´s better to remove the transistor (and bridge the E and C solder pads).
Cheers! |
radek tymecki
Posted: Mon Oct 18, 2021 6:15 am Post subject:
| I am quite interested in Your layouts. Did u test them>? |
