"Son Of Storm Tide" Flanger
Page 6 of 14 [330 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, ..., 12, 13, 14 Next
interested?
yes
97%
 97%  [ 43 ]
no
2%
 2%  [ 1 ]
Total Votes : 44
oldschool57
PostPosted: Mon Mar 29, 2010 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm about to begin calibration. What are the high & low clock f's you used?
oldschool57
PostPosted: Thu Apr 01, 2010 6:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Never mind. Got it.
jhaible
PostPosted: Thu Apr 01, 2010 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
oldschool57 wrote:
Never mind. Got it.
Ok, you were faster. Smile
I always adjust that kind of stuff by ear.
JH.
dcreatorx
PostPosted: Sat Apr 17, 2010 4:29 am    Post subject: availability Reply with quote  Mark this post and the followings unread
Hi, is this project in development yet ? Is there any board available to buy ?
Thanks !
jhaible
PostPosted: Sat Apr 17, 2010 4:46 am    Post subject: Re: availability Reply with quote  Mark this post and the followings unread
Thanks !
I still have boards left.
Order information is here:
http://electro-music.com/forum/topic-26164.html
JH.
StephenGiles
PostPosted: Sat Apr 17, 2010 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
oldschool57 wrote:
Never mind. Got it.
JH.
Which is what I do too. There are guys wetting their pants over at DIY Stompboxes over clock frequencies!!
numbertalk
PostPosted: Mon Apr 19, 2010 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I'm a bit lost on how to calibrate the many trimmers on this board, even by ear - I'm still a noob with BBD stuff. Do you mind either here or on your site giving some guidance/steps for each of the following (how to set up, what to test/look/listen for, etc...):
Short Resonance
Long Resonance
BBD Bias
Max Clock
Clock Low
Clock Tune
Filter
Also anything special to know about trimming the V/Oct scaling besides cranking the resonance and inputting the output of a CV keyboard? For example, does it matter where manual sweep is set?
Greatly appreciated.
jhaible
PostPosted: Mon Apr 19, 2010 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Short Resonance
Long Resonance
Set it for just getting self oscillation, or just barely getting self oscillation, according to your taste.
BBD Bias
Set for symmetrical clipping in the BBD stage, if there is any clipping at all
Max Clock
Set as high as possible, without the signal getting weak.
Clock Low
Something around 30kHz.
Clock Tune
Start with mid position and adjust to taste.
Filter
Mid position will do. that trimmer slightly alters the step response of the filter, but won't do much on the sound.
JH.
numbertalk
PostPosted: Mon Apr 19, 2010 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, I actually do speak a little German, but not that well - would it be possible in English, please Smile
jhaible
PostPosted: Mon Apr 19, 2010 10:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed I didn't notice I was switching to German. Guess I'm spending too much time with my local friends, lately!
JH.
jhaible
PostPosted: Mon Apr 19, 2010 10:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Should be better now. Wink
JH.
numbertalk
PostPosted: Tue Apr 20, 2010 5:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
BBD Bias
Actually, would you mind detailing this one for me just a bit more? Where is the test point(s) we should set the scope probes to when adjusting BBD Bias? Also, would I feed in a sine wave or something and adjust for maximum size without clipping/distortion?
jhaible
PostPosted: Wed Apr 21, 2010 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
numbertalk wrote:
jhaible wrote:
BBD Bias
Apply sine wave at signal input of the whole device, turn down any feedback/resonance, measure somewhere after the BBD with scope (pin 7 of U17, for example: http://www.jhaible.de/sonofstormtide/sost_sch4.pdf), increase input level until clipping occurs, adjust trimmer for clipping to occur as late as possible.
JH.
numbertalk
PostPosted: Wed Apr 21, 2010 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
So when you say increase the input level, you mean on the setting on the SOST unit itself, right? If so, where should I start with the input level initially? Also, should I be able to get the level all the way up to 10 with a 10Vp-p sine input without clipping - is that realistic?
jhaible wrote:
numbertalk wrote:
jhaible wrote:
BBD Bias
JH.
numbertalk
PostPosted: Mon Apr 26, 2010 6:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi JH, if you missed my last post had a few more quick questions. Thanks.
jhaible wrote:
numbertalk wrote:
jhaible wrote:
BBD Bias
JH.
jhaible
PostPosted: Mon Apr 26, 2010 6:52 am    Post subject: Reply with quote  Mark this post and the followings unread
If you have an input level pot connected. If not, adjust the level of your source.
Zero (no signal) will do.
Using raw modular system levels? That's a bit high. If you want to do that and you get clipping before you even run into the BBDs, decrease R65 (http://www.jhaible.de/sonofstormtide/sost_sch3.pdf) to make a resistor divider R63 and R64.
JH.
numbertalk
PostPosted: Mon Apr 26, 2010 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jorgen!
I'll leave it as-is, since I will be using it a lot with non-modular inputs. Will just have an input attenuator on the SOST and/or a mixer to tame the output of the modular when using it with this.
JH.
jhaible
PostPosted: Mon Apr 26, 2010 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
That's a good solution.
JH.
numbertalk
PostPosted: Sat Jun 05, 2010 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi JH,
I have a question about one of the features - specifically inversion, for both resonance and the 2 signal paths. I know I can play around with them to hear what they do, but am looking for a more informed insight into what desired results you'd be going for to invert any of these 3 in different combination.
Also, the long and short for the 2 outputs - is it that "short" the signal goes through 1 of the BBD lines and for "long" it goes through both BBD lines?
jhaible
PostPosted: Sat Jun 05, 2010 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
numbertalk wrote:
Hi JH,
Yes, long and short refers to 2 vs 1 BBD.
Signal inversion exchanges peaks and notches, simply speaking. And it creates a tremendous stereo effect when you do it either way in either channel. And it changes the coulur of resonance - quite drastically, too.
But you *will* find this out by playing with it, much more than a verbal description can say.
JH.
numbertalk
PostPosted: Sat Jun 05, 2010 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
this is very helpful - thanks!
jhaible wrote:
numbertalk wrote:
Hi JH,
JH.
sduck
PostPosted: Wed Jun 16, 2010 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Just got some boards for this. Also managed to find the TDA1022's at UTSource - 5$US each (I ordered 8 ).
numbertalk
PostPosted: Sun Jun 20, 2010 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi JH, a couple more questions.
1) For the 5mm caps on the bom, some of the lower value ones - 100pf, 330pf) that are more commonly ceramic - can these be ceramic here or are you suggesting they need to be film? Also for the 33pf cap you specify is for the clock oscillator, is this C7? Does it need to be polystyrene? Doesn't look like an integrator cap to me but wanted to make sure. Do any of these need to be polystyrene/polypropylene?
2) I notice on the CV connection hand-drawn diagram you show an optional B1K "tracking" pot connected to the V/Oct input - what is this control for exactly, since there is already a V/Oct trimmer on the board?
jhaible
PostPosted: Sun Jun 20, 2010 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whatever cap fits on the board, will work.
There is teh usual difference in temerature stability etc., which won't make much difference in a flanger, but might be a tad more important for PM.
You might want to have a V/Oct fine adjustment on the front panel, or you might just want to have a trimmer on the PCB.
JH.
numbertalk
PostPosted: Sun Jun 20, 2010 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
