Inventor
Audio files: 267
Posted: Fri May 21, 2010 12:58 pm Post subject:
Deanna,
In that situation, I'd probably listen to your own music as you send it out with your voice and go with that. You can listen to the outgoing stream as well, on lower volume if you can rig that up on your system (I can). Something like that should work for you.
Joined: Feb 04, 2005 Posts: 2864 Location: Nottingham, UK
Audio files: 278
Posted: Fri May 21, 2010 1:21 pm Post subject:
is the idea for this to be:
a. multi-person jams
b. solo performance
c. anything goes
d. all of the above _________________ Jez
music | adventures in sound | gear for sale |
rainshadow
Joined: Nov 05, 2009 Posts: 14 Location: the rainshadowed desert
Posted: Fri May 21, 2010 1:24 pm Post subject:
Inventor wrote: | Deanna,
Les |
i was thinking that if the background music that i rigged for myself isnt wanted that i could just send my voice only and it could be mixed however you all wish...but i'd be singing to something that couldnt be heard is all...
or i could just go with the stream and be late... |
jfox
Radio operator
Audio files: 26
Posted: Fri May 21, 2010 2:10 pm Post subject:
em247 |
Jez wrote: | is the idea for this to be:
b. solo performance
c. anything goes
d. all of the above |
this looks like a [cool] plan to me...
> Rainshadow, I'm sure there will quiet times when we could run some glitchy stuff or textures for you to sing over [timing won't matter with this].
john. |
Joined: Apr 03, 2004 Posts: 24409 Location: The Netherlands, Enschede
Audio files: 297
Posted: Fri May 21, 2010 2:23 pm Post subject:
I agree with John again
7 * 24 = 168 :: here is some room for things to try
 _________________ Jan
Audio files: 297
Posted: Fri May 21, 2010 2:33 pm Post subject:
I've made some open ports, those are up and running, and you all can use these to test stream .. stream test ... and when the event is there it'll be easy for the mixers to pick up those streams.
The page has :
username : public
password : public
and it is here - please bookmark ;-)
The connection details for the public ports are on that page.
I'm still working on it, so from time to time it may not be available, please try again then after a little while.
The open ports are user ports, these have a maximum of four listeners. The public port is meant for the people who do the stream mixing and maybe it's the one to listen to - this one has a maximum of 32 listeners (but that could be changed of course when it's not enough).
It seems best to stream the event on the public port, such that it won't interfere with the regular shows on the main port. _________________ Jan
Alexander
G2 patch files: 4
Posted: Sat May 22, 2010 7:55 am Post subject:
I'm in, maybe beat poetry with my friend playing clarinet... I'll marinade on the idea and shape it! Great!! _________________ http://husc-sound.com |
Patchmouse
Posted: Sat May 22, 2010 11:59 pm Post subject:
Technicalities ? |
Hi, thanks for directing me to this, yes, I would like to take part, but I'm not sure how to go about the technicalities of streaming audio ? or even if I'm set-up for doing this ? Maybe someone could put me right here ? on what I need. I'm a computer based musician that plays minimalistic live improvisations.
Patchmouse. |
Posted: Sun May 23, 2010 3:03 am Post subject:
Didn't we have a thread about how you set up EdCast etc? I can't seem to find it...
Anyway, patchmouse, if you log into the chat room (by clicking "Chat room" at the top right on the forum), there's usually someone there who can help you set things up and check that you've got everything running ok.
Joined: Aug 08, 2009 Posts: 1082 Location: Out scouting . . .
Posted: Sun May 23, 2010 5:02 am Post subject:
Re: em247 |
jfox wrote: | A few thoughts...
The idea of the extra open public ports [Channel 1, Channel 2, Channel 3, Channel 4 [like channels on a mixer]] is that there is always a Mixer[person] that sits between them and Public Port [8056]. Performers can just logon to an empty Channel Port [all ports can have the same p/w]. This makes life a lot easier for the Mixer only having 4 fixed ports to mix [no fiddling around with port address and having multiple winamp/VLC crashes].john |
Multiple public ports is a great idea to make this 24/7 event happen as smoothly as possible. I am wondering if it would also be good to have people with specific ports who are planning algorithmic or free-running sonic streams use their own ports. These could then be ongoing and available. Any performer might want to use these in a mix as a bed for their set going to the public port--mixed with their own sonic stuff.
Just a thought.
--Steve |
jfox
Radio operator
Audio files: 26
Posted: Sun May 23, 2010 5:14 am Post subject:
Its a cool thought Steve..
john. |
Posted: Sun May 23, 2010 5:22 am Post subject:
Re: Technicalities ? |
Patchmouse wrote: | Hi, thanks for directing me to this, yes, I would like to take part, but I'm not sure how to go about the technicalities of streaming audio ? or even if I'm set-up for doing this ? Maybe someone could put me right here ? on what I need. I'm a computer based musician that plays minimalistic live improvisations. Patchmouse. |
Antimon wrote: | Didn't we have a thread about how you set up EdCast etc? I can't seem to find it.../Stefan |
Here's the website to get edcast: http://www.oddsock.org/tools/edcast/
Here's the info I used to download and set up edcast: http://electro-music.com/forum/viewtopic.php?highlight=oddcast&t=13780
Here's the thread about open port streaming: http://electro-music.com/forum/topic-41570.html
See also the links in Blue_Hell's post a few messages back (posted Fri May 21, 2010 5:33 pm)
You also need a way to get your music into the PC--usually a sound card.
Be sure to get the lame mp3 dll and put it in the edcast folder.
Come into chat for help setting up and testing.
Its great to see the 24/7 event attracting musicians to radio.electro-music.com!!! I am looking forward to listening as much as I can.
BTW, in edcast, there is a checkbox you can set to record what you send to the stream (mp3/wav). You are responsible for recording your own stream--just make sure you have enough diskspace to capture it!
--Steve
PS: In the oddcast instructions from mosc, he says to snd him a PM for a port and password. Don't do that step. You should be using the new open port (aka public port) channels as explained in Blue_Hell's info. |
shanemorris
Audio files: 92
Posted: Mon May 24, 2010 4:08 am Post subject:
I found out this weekend that my teaching license program has been moved back a week earlier to begin on June 7th. This means I will be absent from the music throughout the day. I will additionally have a butt-ton of homework each night... so it looks like I will be a spectator for the majority of this event.
However, it seems we have a number of people interested... especially some new comers... so there will be tons of music and I look forward to hearing what comes out of this.  _________________ ElectroCasa |
nobody
Posted: Mon May 24, 2010 6:39 am Post subject:
I'm sorry to hear that you won't be playing, Shane. What are you training to teach? |
shanemorris
Audio files: 92
Posted: Mon May 24, 2010 6:57 am Post subject:
audiodef wrote: | I'm sorry to hear that you won't be playing, Shane. What are you training to teach? |
middle school science, social studies, l.a., or math. Ntl program. It's nice cause I can teach while I get my license _________________ ElectroCasa |
Audio files: 297
Posted: Mon May 24, 2010 7:01 am Post subject:
Too bad Shane ... hope we'll be able to enjoy you a bit from time to time then. _________________ Jan
Inventor
Audio files: 267
Posted: Mon May 24, 2010 7:44 am Post subject:
Mr. Morris, I want to go smoke a ciggie in the bathroom, may I be excused?
shanemorris
Audio files: 92
Posted: Mon May 24, 2010 8:16 am Post subject:
Inventor wrote: | Mr. Morris, I want to go smoke a ciggie in the bathroom, may I be excused?
LES HALL!!!
It's illegal for adults or students to have tobacco or tobacco products on a school campus... You MAY be excused to go to the Office and tell the Principal what you were doing!  _________________ ElectroCasa |
Inventor
Audio files: 267
Posted: Mon May 24, 2010 9:12 am Post subject:
Dang, this is the SECOND time I got busted for that! The first time was in 12th grade... _________________ "Let's make noise for peace." - Kijjaz |
shanemorris
Audio files: 92
Posted: Mon May 24, 2010 9:17 am Post subject:
Inventor wrote: | Dang, this is the SECOND time I got busted for that! The first time was in 12th grade... |
LOLES
......... so you like to learn the hard way! heheheh _________________ ElectroCasa |
Joined: Jan 31, 2003 Posts: 18240 Location: Durham, NC
Audio files: 224
Posted: Mon May 24, 2010 10:45 am Post subject:
I'm up for this, of course. This will be really fun. _________________ --Howard
my music and other stuff |
nobody
Posted: Mon May 24, 2010 12:34 pm Post subject:
A little tip, Les. You don't ask. You just do it. And then you run.  |
Inventor
Audio files: 267
Posted: Mon May 24, 2010 1:01 pm Post subject:
audiodef wrote: | A little tip, Les. You don't ask. You just do it. And then you run.  |
Hmmm, is that your general philosophy toward life?  _________________ "Let's make noise for peace." - Kijjaz |
nobody
Posted: Tue May 25, 2010 7:18 am Post subject:
Well, half. I just do it. I don't run.  |
jfox
Radio operator
Audio files: 26
