DIY Drum Synth Progress
Page 3 of 3 [63 Posts]
Goto page: Previous 1, 2, 3
droffset
PostPosted: Fri Jun 04, 2010 4:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Progress on the Cynare. I think all of the wiring is ready to attach to the hardware now.
Still need to sort out transistors. I don't have any of the required 22222s, so will probably have to socket them and just keep trying transistors until it sounds right. I think the only critical one will be the noise generator, but not sure.
Day 3 - Cynare Wiring progress
Edit: Spelling mistakes.
RF
Audio files: 28
PostPosted: Fri Jun 04, 2010 5:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks great, Dr.!
Can't wait to hear it...
bruce
www.sdiy.org/rfeng
richardc64
Audio files: 26
PostPosted: Wed Jun 09, 2010 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Not much progress on the electronics, but mechanical aspects are being dealt with.
Materials include: 2 aluminum "U" channels of different width, so that the diagonal brace fits inside the vertical member; bolts with wingnuts for tool-less set up and disassembly; mousepad under the 1/4" plywood base to prevent wobble, plus another piece to provide thickness and protect the wood from the clamp.
Here's an uninspiring sample triggering the Synsonic's Tom Tom 1 & 2 (both modded for lower pitch), first singly, then both together for a sort of surround sound bass. (Careful with your volume.)
 Filesize:  86.08 KB
 Viewed:  715 Time(s)
t1t2both.mp3
 Filename:  t1t2both.mp3
 Filesize:  286.53 KB
 Downloaded:  1492 Time(s)
Dan Lavin
Audio files: 21
PostPosted: Wed Jun 09, 2010 4:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice work Richard! Glad this worked out for you. It does seem very responsive. And, of course, I love the Synsonics!
Synth DIY since 1977!
droffset
PostPosted: Thu Jun 10, 2010 2:53 am    Post subject: Reply with quote  Mark this post and the followings unread
That looks great Richard!
richardc64
Audio files: 26
PostPosted: Thu Jun 10, 2010 6:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys. There might be a V3 or V4, as I'd like it even more compact, with a smaller footprint, so there'd be no need to disassemble it to conserve space.
Yours too! Cynare has a fun look. But why do you make so many speling mistaks?
droffset
PostPosted: Thu Jun 10, 2010 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sadly I was born without a spellcheck gland.
Dan Lavin
Audio files: 21
PostPosted: Thu Jun 24, 2010 4:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I've just about finished with my modded Synsonics and this seems like the best spot for electronic percusion lately. The sound mods are all by our very own RichardC64. I have added individual trigger ins so my TH Midi to Trigger unit can control it under midi. All I did was add a diode from the hot jack to the analog trig in pins on U3.
I apologize for the crappy sound samples. I do not use my digital recorder (Zoom MRS8) very often and the results are less than stellar. But anyway, it does give you a feel of how much more aggressive the sound is than the stock unit. Perfect for your next NIN ripoff. Wink
I still want to add individual outs for each voice......... because I want to buy a new mixer Very Happy
 Filesize:  1.4 MB
 Viewed:  771 Time(s)
FastSynsonicsSample.mp3
 Filename:  FastSynsonicsSample.mp3
 Filesize:  980.94 KB
 Downloaded:  1297 Time(s)
slowSynsonicsSample.mp3
 Filename:  slowSynsonicsSample.mp3
 Filesize:  488.69 KB
 Downloaded:  1217 Time(s)
droffset
PostPosted: Thu Jun 24, 2010 9:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
That looks really cool Dan. I like how you have your controls on top there. The audio is cool too.
After I get done with some other stuff that's going on I'll be able to start building again. Just need a break.
richardc64
Audio files: 26
PostPosted: Fri Jun 25, 2010 3:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Heh. I guess that explains why the last 30 seconds of the fast sample are silent Laughing Still, I'm impressed.
Take a bow.
PostPosted: Fri Jun 25, 2010 5:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice work guys. (Following the thread with interest) Cool
Bill
droffset
PostPosted: Sun Dec 19, 2010 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just a recap of some progress since the last post here.
16 Step Sequencer complete!
upDwnSeqBuild05 by drOffset, on Flickr
Cynare complete!
cynare panel by drOffset, on Flickr
droffset
PostPosted: Tue May 09, 2017 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello again!
So anyway, I've made some progress on this...
The 3 Coron DS8 modules now live in this very sturdy box and will be a standalone 9v battery device because I felt the sound wasn't as punchy as I was hoping for. Fully functional. It needs knobs and maybe a little single supply mixer.
Posted Image, might have been reduced in size. Click Image to view fullscreen.Diy synth by S G, on Flickr
I've added a Quad Bass++ to the equation and they currently live in this box, which is only temporary. Populated and all parts are collected, it needs a panel, wiring, and knobs.
This is the case where the final drum synth will live. It used to hold a realistic replica arm for medical training. I got it at a carboot sale so the arm's current whereabouts are unknown.
I will use the 4U CW standard described here, because a nice 1" grid makes sense to my brain.
Rough draft of what's going in.
CGS Synare | Quad Bass++ | 2x Thomas Henry MPS | Gate to Trigger | uZeus power.
Posted Image, might have been reduced in size. Click Image to view fullscreen.drumSynthMay2017 by S G, on Flickr
And then maybe purchase a small external mixer for them to come together. I don't know, should I embed a mixer into one of those small pockets?
So yes, it evolves and progresses.
