droffset
Joined: Feb 02, 2009 Posts: 515 Location: London area
Posted: Fri Jun 04, 2010 4:00 am Post subject:
Progress on the Cynare. I think all of the wiring is ready to attach to the hardware now.
Still need to sort out transistors. I don't have any of the required 22222s, so will probably have to socket them and just keep trying transistors until it sounds right. I think the only critical one will be the noise generator, but not sure.
 _________________ ==================
Edit: Spelling mistakes. |
RF
Joined: Mar 23, 2007 Posts: 1502 Location: Northern Minnesota, USA
Audio files: 28
Posted: Fri Jun 04, 2010 5:14 am Post subject:
Looks great, Dr.!
Can't wait to hear it...
bruce _________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) |
richardc64
Audio files: 26
Posted: Wed Jun 09, 2010 9:27 am Post subject:
Not much progress on the electronics, but mechanical aspects are being dealt with.
Materials include: 2 aluminum "U" channels of different width, so that the diagonal brace fits inside the vertical member; bolts with wingnuts for tool-less set up and disassembly; mousepad under the 1/4" plywood base to prevent wobble, plus another piece to provide thickness and protect the wood from the clamp.
Here's an uninspiring sample triggering the Synsonic's Tom Tom 1 & 2 (both modded for lower pitch), first singly, then both together for a sort of surround sound bass. (Careful with your volume.)
Description: |
Filesize: |
86.08 KB |
Viewed: |
706 Time(s) |
Description: |
 Download (listen) |
Filename: |
t1t2both.mp3 |
Filesize: |
286.53 KB |
Downloaded: |
1476 Time(s) |
_________________ Revenge is a dish best served with a fork... to the eye |
Dan Lavin
Audio files: 21
Posted: Wed Jun 09, 2010 4:46 pm Post subject:
Nice work Richard! Glad this worked out for you. It does seem very responsive. And, of course, I love the Synsonics! _________________ Synth DIY since 1977! |
droffset
richardc64
Audio files: 26
Posted: Thu Jun 10, 2010 6:23 am Post subject:
Thanks guys. There might be a V3 or V4, as I'd like it even more compact, with a smaller footprint, so there'd be no need to disassemble it to conserve space.
droffset wrote: | That looks great Richard! |
Yours too! Cynare has a fun look. But why do you make so many speling mistaks? _________________ Revenge is a dish best served with a fork... to the eye |
droffset
Dan Lavin
Audio files: 21
Posted: Thu Jun 24, 2010 4:12 pm Post subject:
Well, I've just about finished with my modded Synsonics and this seems like the best spot for electronic percusion lately. The sound mods are all by our very own RichardC64. I have added individual trigger ins so my TH Midi to Trigger unit can control it under midi. All I did was add a diode from the hot jack to the analog trig in pins on U3.
I apologize for the crappy sound samples. I do not use my digital recorder (Zoom MRS8) very often and the results are less than stellar. But anyway, it does give you a feel of how much more aggressive the sound is than the stock unit. Perfect for your next NIN ripoff.
I still want to add individual outs for each voice......... because I want to buy a new mixer
Description: |
Filesize: |
1.4 MB |
Viewed: |
764 Time(s) |
Description: |
 Download (listen) |
Filename: |
FastSynsonicsSample.mp3 |
Filesize: |
980.94 KB |
Downloaded: |
1268 Time(s) |
Description: |
 Download (listen) |
Filename: |
slowSynsonicsSample.mp3 |
Filesize: |
488.69 KB |
Downloaded: |
1198 Time(s) |
droffset
richardc64
Audio files: 26
Posted: Fri Jun 25, 2010 3:07 am Post subject:
Dan Lavin wrote: | I do not use my digital recorder (Zoom MRS8) very often and the results are less than stellar. |
Heh. I guess that explains why the last 30 seconds of the fast sample are silent Still, I'm impressed.
Take a bow.
Posted: Fri Jun 25, 2010 5:08 am Post subject:
Nice work guys. (Following the thread with interest)
Bill |
droffset
droffset
Posted: Tue May 09, 2017 12:03 pm Post subject:
Hello again!
So anyway, I've made some progress on this...
The 3 Coron DS8 modules now live in this very sturdy box and will be a standalone 9v battery device because I felt the sound wasn't as punchy as I was hoping for. Fully functional. It needs knobs and maybe a little single supply mixer.
Diy synth by S G, on Flickr
I've added a Quad Bass++ to the equation and they currently live in this box, which is only temporary. Populated and all parts are collected, it needs a panel, wiring, and knobs.
This is the case where the final drum synth will live. It used to hold a realistic replica arm for medical training. I got it at a carboot sale so the arm's current whereabouts are unknown.
I will use the 4U CW standard described here, because a nice 1" grid makes sense to my brain.
Rough draft of what's going in.
CGS Synare | Quad Bass++ | 2x Thomas Henry MPS | Gate to Trigger | uZeus power.
drumSynthMay2017 by S G, on Flickr
And then maybe purchase a small external mixer for them to come together. I don't know, should I embed a mixer into one of those small pockets?
So yes, it evolves and progresses. _________________ ==================
