 Forum index » Instruments and Equipment » iOS - iPad/Phone/Pod etc
NanoStudio for iPhone
Post new topic   Reply to topic Moderators: mosc, v-un-v
Page 1 of 1 [17 Posts]
PostPosted: Sat Jun 05, 2010 2:55 am    Post subject: NanoStudio for iPhone
Subject description: This looks like the sh!t!!! 8)
arrow link via Palm Sounds
ACHTUNG!
PostPosted: Sat Jun 05, 2010 9:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Compatible Devices
• iPhone 2G, 3G, 3GS
• iPod Touch 2G, 3G (mic recording possible with external accessory)
• iPod Touch 1G (mic recording not available)
General
• Instruments - 4x Eden synths, TRG-16 trigger pads, 6 track sequencer, 7 input mixer with two sends
• Insert Effects - 2 per synth (wave-shaper, chorus/flanger/delay)
• Send Effects - 2 (reverb, chorus/flanger/delay)
• Total polyphony - 48 stereo voices
• Buffer latency - 10ms
• Stereo 44.1kHz floating-point signal path (only the final output is reduced to 16 bit)
• Individually optimised for new and old iPhone hardware (chooses between VFP and NEON technology)
Eden synth (x4)
• Maximum polyphony - 8 voices per synth
• 2 anti-aliased oscillators per voice, each with 30 basic waveforms including noise
• Oscillators can be mixed or sync/ring modulated
• Resonant filter per voice - low pass, band pass or high pass with 12dB or 24dB slope
• Sampler module enables samples to be used in place of basic waveforms
• Multi mode layers up to 4 different voice presets
• 4 LFO's, optional sync to note start/sequencer tempo
• 3 ADSR Envelope generators (amp, filter and aux)
• 2 X/Y controllers, 1 configurable control knob, pitch bend wheel and accelerometer input for real-time performances
• Virtual patch-bay for connecting controllers, LFO's and envelopes and other synth parameters (12 connections, 40 parameters)
• 2 insert effects per synth (wave-shaper, chorus/flanger/delay)
• Single/Multi mode presets - 64 Factory (read only), 64 User (shared between all projects) and 64 Project specific presets
TRG-16 Trigger Pads and Sampling
• Number of trigger pads - 16
• Maximum polyphony - 16 voices
• Adjust volume, pan, pitch, output bus, attack, release and loop type per sample
• Exclusive groups for use with high hats etc.
• Three output busses, each with its own filter and send effects
• Load/save individual samples or whole kits
• Upload wavs or aiff to your device using NanoSync for PC and Mac
• Record your own samples using the internal mic (iPhone only) or external mic (iPod Touch 2G, 3G)
• Resample NanoStudio's main mix output
• Crop and normalise samples on the device using NanoStudio's built in sample editor with 4 levels of undo/redo
Sequencer
• Realtime record with undo
• Pattern editor and song arranger
• 6 tracks (4 Eden synths and 2 tracks dedicated to the TRG-16)
• Record unique parts or turn them into patterns for repetitive loops (100 patterns supported)
• Draw note and controller events such as XY pad movements, pitch bend, velocity and accelerometer
• Editing functions include delete, merge, copy, move, note length, transpose, clean and quantise
• 4 levels of undo/redo on every editing operation
• All editing operations are possible while your song is playing
Mastering
• Mixer with 7 stereo inputs (4 Eden synths, 3 TRG-16 output busses), 1 stereo output and 2 stereo sends
• 2 Simultaneous global effects sends per input (reverb, chorus/flanger/delay
• Stereo VU displays for all inputs and outputs
Crikey! Shocked Cool
ACHTUNG!
Audio files: 500
PostPosted: Sat Jun 05, 2010 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's a pretty exhaustive list!
I'll follow the developments of this with interest.
GovernorSilver
PostPosted: Mon Jun 07, 2010 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
If it supports odd time signatures (7/4, 5/4, 22/8, etc), I'm DL'ing this baby!
Some old stuff on VIRB
Audio files: 231
PostPosted: Wed Jun 16, 2010 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
This is really impressive looking. Great to see more and more sophisticated apps coming along. I'm probably going to download this one too, but I'm looking for expressive real-time instruments to play in an ensemble. I still think nothing has yet come beyond bebot in this vein.
I think some new ones will be coming along soon though.
Rykhaard
PostPosted: Wed Jun 16, 2010 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
WHOLEY SCHIDT! That is farging INCREDIBLE! I've immediately registered at that forum and will be watching with my eye glued to my monitor! The demo video is WILD!
The ONLY things that would keep me from buying it are:
1) if you are NOT able to create your own synth sounds (which I doubt - seeing the listing of synth parameters)
2) if it's too expensive. ($75 or higher, as I'm just about to purchase new gear, outside of this as well as the next paragraph ... )
I am JUST at the very beginning of dumping my cheap RIM Blackberry 'clone' to move TO an actual RIM Blackberry. In this process I WAS going to be dumping my current phone (FORmerly Virgin - who's phone company is now owned completely by Hell. (Ooops Bell.) as well as my iPlod Touch, which I've not been impressed with at all.
But - seeing this software, would give me a VERY good reason, TO keep the iPlod! Surprised
Thank you greatly for posting this!
PostPosted: Thu Jun 17, 2010 1:50 am    Post subject: Reply with quote  Mark this post and the followings unread
First poor old Oban, now the iP(L)od Touch. Shocked
Why do you dislike the iPod Touch?
PS, I got further info from Andy that he got Oban mixed up with something else, and actually Oban is good! So there! Razz Laughing
Hopefully Andy will confirm this Smile We both met up recently and had a mammoth ale session. Little talking (from me anyway Wink ), just drinking! I was seeing double when I walked out of the pub! I wanted to take a load of pictures, but only came away with one- of ...erm... pints of beer! Shocked
ACHTUNG!
electri-fire
G2 patch files: 4
PostPosted: Wed Aug 25, 2010 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
The synth is nicely usable. The modulation matrix very versatile. The two XY pads are awsome.
The A07 (Filters) preset is my favorite, it plays a sampled vocal phrase. Sample start and loop lenghts are modulatable. The preset has Start and Lenght on LFOs. LFO depths are assigned to the left XY pad, Start and Lenght on the right XY pad.
You can load in your own samples. While each patch uses one sample, Once transferred into your iPad/pod/phone, new samples can be loaded into the patch very fast.
Four synths and a set of drumpads can be prepared into a "project" and rapidly recalled for use.
It's an absolutely awesome little noisemaker for jamming. I love nanostudio.
PostPosted: Wed Aug 25, 2010 7:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
...and actually Oban is good! So there! Razz Laughing
Sure, Oban is a briliiant single malt. Very Happy beer
 Filesize:  11.19 KB
 Viewed:  20012 Time(s)
Flickr
PostPosted: Thu Aug 26, 2010 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Should be meeting up with Andy again this weekend, but we're probably on the coffee this time (I'm driving!)
Nice to have that extra vote for Oban, Stein. Cool A damn fine malt I should add! Smile
And so is, I must confess, ALDI's own Glen Moray, which I have now got through 4 bottles Shocked because it's so cheap!!! Shocked Confused
ACHTUNG!
Audio files: 231
PostPosted: Thu Aug 26, 2010 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I just bought Nanostudio. It works great. Very powerful, even as just a performance instrument. I find it great that you can play tracks from your library as backing tracks. The synths are new for me, but I like them. I'm not experienced with sample players. This one has really good real-time adjustments, it seems to me. I plan on spending lots of time with this baby.
It has no BPM function. Very refreshing! Smile
PostPosted: Tue Oct 26, 2010 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just felt like saying that this thing rocks! It's been a long time since I felt I could do so much with a piece of music software with so little effort. The piano roll works great, even though I sometimes forget to zoom in so I keep missing with the finger. This app saves my life on those dreary train rides to and from work each day.
Well worth its comparatively high price (which obviously is nothing compared to what other music stuff costs).
EdisonRex
Audio files: 172
PostPosted: Wed Oct 27, 2010 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree. This thing is fun!
Garret: It's so retro.
ewblank
PostPosted: Fri Dec 03, 2010 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey folks,
I've had Nanostudio for a couple of weeks now, and this is hands down my favorite synth app for the iPhone. It's very intuitive and the best part is that it works seamlessly with the Akai Synthstation25. Believe it or not - it works better with it than Akai's own Synthstation app!
IMHO - Nanostudio offers huge value for the money.
cheers, ew
Reality is Subjective
Audio files: 231
PostPosted: Mon Dec 06, 2010 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, and the latest release supports the new 4.2 iOS MIDI standards. I wish all of the synths would keep up as promptly.
PostPosted: Mon Dec 06, 2010 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think the problem here lies in the sheer amount of downloads of Nanostudio, Blipinteractive are getting, ie they can't afford to slack really. I feel sorry for many other developers who are probably feeling what it's like to get pushed aside, to make way for the big boys.
(and of course the utter nightmare that is Apple's developer connect portal Shocked Rolling Eyes Shocked Exclamation )
Be patient Great Uncle Mosc! Cool
ACHTUNG!
Volterock
PostPosted: Thu Jan 20, 2011 12:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I think this is the best sequencer on the iphone/ipod thus far. It also seems to be the easiest to use.
These are so cheap... I remember when Logic was over $1000
