 Forum index » Clavia Nord Modular » G2 Patches - Completed » Sequencer - interactive
Gierring
Page 1 of 1 [4 Posts]
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Thu Feb 03, 2005 1:54 am    Post subject: Gierring Reply with quote  Mark this post and the followings unread
This is an interpretation of Reaktor 4's Vierring ensemble. It's basically 4 envelope modded filters, with the envelopes triggered by 4 sequencers. The levels in the sequencers correspond to volume. A 5th sequencer controls all 4 filter's cutoff frequencies for more variation, and each filter has it's own delay send. The triggering of envelopes can be changed from retrigger to legato with the switches.
The best part about the Vierring ensemble was using a looped sample as the sound source. I've included an audio in so you can use an external sampler for this type of use (highly reccomended), or there is a simple 2 osc sound source you can use.
I've included 3 variations, all using the internal sound source. The 1st is additive, 2nd is sync and the 3rd is FM. These can be used with an external sound source, but for best results, you should tweak the filters and sequencers to correspond to the material being fed to it.
GierringV1.2.pch2
Translation of the Vierring Reaktor 4 ensemble.
 Filename:  GierringV1.2.pch2
 Filesize:  5.3 KB
 Downloaded:  1830 Time(s)
Audio files: 226
PostPosted: Thu Feb 03, 2005 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool
Roland Kuit
G2 patch files: 127
PostPosted: Thu Feb 03, 2005 9:24 am    Post subject: Gierring Reply with quote  Mark this post and the followings unread
Nice job, Afro, i did this kinda thing with my Teknomerger.
Yours sounds pretty cool too Very Happy
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Thu Feb 03, 2005 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was away from these forums for a while. Looks like I missed some good patches! I'll check it out Roland Smile
