Prblms with G2 (PC reboots / performances not loaded corr) !
Page 1 of 1 [8 Posts]
Sander_k
G2 patch files: 16
PostPosted: Sun Feb 06, 2005 6:37 pm    Post subject: Prblms with G2 (PC reboots / performances not loaded corr) ! Reply with quote  Mark this post and the followings unread
Sad some strange things are happening.
I'm working in my sequencer (cubase sx2.0) and have both midi in/out connected to a midex8 and a channel assigned to the G2x by adding a channel and selecting it and midi-local off < a quite normal situation right?
I dail-up a performance, 1: early autumn for instance. What happens is that all patches in the perf. are loaded incorrectly; the G2X messes up by giving me all kinds of weird patch combinations.
Only when i disconnect the G2X's midi in from the PC and then re-dail the performance it's loaded correcty. When doing this all slots are assigned to midi-channel 1 in the system-settings< that could be it
Another thing, while finding out what the above could be i powered off the G2X and when doing that my PC rebooted instantly!
Pc problem or G2X problem?
PostPosted: Sun Feb 06, 2005 7:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Two problems I think.
The rebooting thing makes no sense to me, what OS are you running ? Maybe a bad USB driver.
The weird loading behaviour looks like a MIDI loop, the G2 sending patch changes that get sent back through the PC to the G2, probably a settings issue in cubase.
Jan.
ikk
PostPosted: Mon Feb 07, 2005 7:13 am    Post subject: Re: Prblms with G2 (PC reboots / performances not loaded cor Reply with quote  Mark this post and the followings unread
This happens consistently on my PC too, when I switch my G2 off while the editor is not running. I run Windows XP on an Asus A7N8X-E DeLuxe motherboard.
(Now I am also a happy owner of an Apple iBook that I use for the G2 editor, so I haven't tried debugging the problem further.)
-Heikki
Sander_k
G2 patch files: 16
PostPosted: Sat Feb 12, 2005 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
No one else has this problem? It's indeed consistent.. whenever the editor is running and the G2(x) is shut off, my PC shut's off too..
I'm running Win XP and this is definitely something that needs fixing!
Audio files: 227
PostPosted: Sat Feb 12, 2005 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I just tried the power-off thing and my XP machine didn't blink. I am running the latest beta G2 software so my test may not do much to comfort you. Maybe if you gently rub the side of your G2 and chant ancient Viking odes you'll get a new software release with USB enhancements soon. Hey, you never know...
PostPosted: Sat Feb 12, 2005 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Alhough my g2 never brought my xp down out of solidarity I'll start rigth away; "Viking odes" it was, right here I go ... it would help if all us did so I think - this can be automated BTW, see attached.
Jan.
05-003-001-a.pch2
Automated viking ode to help make stop in the future maybe xp shutdowns when g2 is turned off, if not for you, then for others maybe.
 Filename:  05-003-001-a.pch2
 Filesize:  2.3 KB
 Downloaded:  2578 Time(s)
General Elektrick
PostPosted: Sat Feb 12, 2005 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Funny,
I hope it will help!
Best,
General Elektrick
"If something is boring after two minutes, try it for four. If still boring, then eight. Then sixteen. Then thirty-two. Eventually one discovers that it is not boring at all." --John Cage.
