What is Inv x2, Inv x3 in ShpStatic
Page 1 of 1 [6 Posts]
ik
G2 patch files: 25
PostPosted: Sun Feb 20, 2005 1:08 pm    Post subject: What is Inv x2, Inv x3 in ShpStatic Reply with quote  Mark this post and the followings unread
I have been trying to find out what is 'Inv x2' and 'Inv x3' in ShpStatic.
See attached.
While I can "recreate" x^2 and x^3, I am having trouble to generate the formula for 'Inv x2'
1) it is not 1-x^2, (see attached).
2) it is not x^1/2, since multiplying by itself did not return x.
3) it is not 1/x^2, since multiplying by x^2 did not return 1(64).
- or is it a bug? -
Any help on this?
Thanks,
ik.
shapes.pch2
What does 'Inv x2' (and 'Inv x3') stands for?
 Filename:  shapes.pch2
 Filesize:  1.58 KB
 Downloaded:  967 Time(s)
jksuperstar
G2 patch files: 18
PostPosted: Sun Feb 20, 2005 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think they are more similar to tangent/exponential (e^x, x^e, or ln(x)) functions.
Audio files: 297
PostPosted: Sun Feb 20, 2005 5:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think the only person outside Clavia who might know is Rob - I know him to have some remarks about 'm
Less intersting but personally I suspect the curves to be 'fantasy' curves, I've been kooking into curves for the NM Classic and could not make ssense out of those (in thas case the exp curves, which were not particulary exp).
I didn't try for the G2, so might someone find an answer, I'd really like to know as well !
Jan.
ik
G2 patch files: 25
PostPosted: Sun Feb 20, 2005 5:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok. I have been able to figure out:
Inv x2 is y=1-(1-x)^2
and
Inv x3 is y=1-(1-x)^3
for positive x signals, and y just pick up the (-) sign for negativ x values.
See attached file.
ik.
shapes solved.pch2
ShpStatic emulation.
 Filename:  shapes solved.pch2
 Filesize:  1.76 KB
 Downloaded:  992 Time(s)
Audio files: 297
PostPosted: Sun Feb 20, 2005 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great ! Thanks.
Jan.
Audio files: 224
PostPosted: Sun Feb 20, 2005 7:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good work... I'm impressed.
