<on air> Twyndyllyngs - not canceled Chez Mosc
PIC based Arpeggiator (Boards available)
Page 3 of 4 [87 Posts]
LektroiD
PostPosted: Sat May 21, 2011 4:19 am    Post subject: Reply with quote  Mark this post and the followings unread
what are the Schottky diodes (no part number listed in the BOM)? I have a pile of rectifier diodes here; BYD11D, 200V. Would they work?
LektroiD
Audio files: 299
PostPosted: Sat May 21, 2011 4:31 am    Post subject: Reply with quote  Mark this post and the followings unread
from the BOM:
Schottky Diode (SD101C was used in prototypes, but it's not critical)
BYD11D is not a Schottky diode; BAT85 used to be a commonly used schottky.
LektroiD
PostPosted: Sat May 21, 2011 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool, I'll replace those with the BAT85's then..
Also, can I use 22pf in place of the 18pf (and save myself a trip to the dreaded Maplin)?
LektroiD
Boogdish
PostPosted: Sat May 21, 2011 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
22pf should be fine.
The datasheet for your crystal oscillator will indicate the ideal load capacitor, but being a few picofarads off shouldn't make a noticeable difference.
Audio files: 160
PostPosted: Mon May 23, 2011 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Got mine today !!!
Thanks again.
Maplin....he he he he , esp. the saturday till kids ...(...ferrite beads please, no , it's not a s£x toy , it's an electronic choke).... ha ha ha Smile
LektroiD
PostPosted: Mon May 23, 2011 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Last time I was in for a 50k potentiometer, the Saturday guy looked at me like I was from another planet, then proceeded to be rude and offensive, shoving the catalogue in my face telling me he needs the maplin codes (like I'm supposed to know this). If I wasn't such a placid guy, I'd have probably punched him out there and then. Instead, I called the shop and made the manager aware of this guy's obnoxious behaviour.
Anyway, I got some 18pf caps in the end from Farnell.
LektroiD
Audio files: 160
PostPosted: Mon May 30, 2011 12:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm busy doodling with pencil & paper Smile , a Panel layout for the Arpeg. before i start building, i wondered about having rotary switches to select movement & range , would i just make a daughter board to mount voltage divider resistors for each switch pole ?.
Boogdish
PostPosted: Mon May 30, 2011 7:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would mount resistors directly on the switch. Connect ground to the lug for the furthest clockwise position and resistor going from that lug to the next, then on the next lug attach another resistor going to the next lug and so forth until you get to the most clockwise position which would be tied to +5V.
I'd only use a daughterboard for this if I was using a PC mounted pot. Otherwise you're not only soldering all those resistors but also jumpers from the board to the switch and you're making more work for yourself.
JoeMorris
PostPosted: Tue May 31, 2011 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got mine, thanks looks great! Smile
JoeMorris
PostPosted: Tue May 31, 2011 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Quick Q that might be slightly off topic, but would be interested to now if this is possible - if I set up my MPC 3000 to output a sample of a loud, short transient pulse on one of its individual outputs, could I use this as a clock signal to control the speed of my arpeggiator's modular arpeggio, swinging wth its quantised groove? That would be really cool.
Peake
PostPosted: Tue May 31, 2011 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
If the MPC's outputs are DC-coupled (not filtered by a cap to remove DC).
There are other important aspects but that would be the single most important thing to discover. If you cannot remove any DC-blocking capacitors, you can use an envelope follower/Schmitt trigger to turn the audio pulse into a DC pulse suitable for triggering/advancing clocks.
JoeMorris
PostPosted: Tue May 31, 2011 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes, good point, i have an oakley EFG and that also has a gate output anyway, so there's always that option... just wondering in my uninformed way whether a sample of a short trigger pulse could work as a trigger generally in modulars, i.e. using individual outs of my mpc to trigger diy drum modules etc.. I realise a gate signal will probably be filtered out but a short transient should get through as AC shouldnt it? Will the arpeggiator clock not be moved on a tick by a trigger signal like this then, it requires a pulse that's longer than that? Excuse the rookie questions.
rosch
PostPosted: Tue May 31, 2011 2:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
you can try it. i've been triggering all drum modules with e.g. a snare from the S1000 and it always worked fine with the ones i had.
they probably had the necessary circuitry. it even worked with velocities.
the drums were for example sonor mini mammut, pearl syncussion, boss drp, formanta, simmons, dynacord, actually everything that had a trigger in (for pads/microphones)
Boogdish
PostPosted: Tue May 31, 2011 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
This needs a a +5V DC pulse to trigger it. I pulled out my SR-16 just to make sure and I couldn't get any response from plugging it's output to either of the trigger inputs.
You'd need to run the audio into an envelope follower like Peake said.
JoeMorris
PostPosted: Wed Jun 01, 2011 1:08 am    Post subject: Reply with quote  Mark this post and the followings unread
cool, thanks for the test/clarification, I guess i can still get down the envelope following route then for tight as you like mpc arpeggiator swing!
wmonk
Audio files: 15
PostPosted: Wed Jun 01, 2011 6:46 am    Post subject: Reply with quote  Mark this post and the followings unread
This little thing is nice for triggering analog drum modules and sequencers:
http://www.engineersatwork.nl/catalog/product_info.php/cPath/58/products_id/536
Weblog!
JoeMorris
PostPosted: Wed Jun 01, 2011 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
hmm looks good, would the 10ms pulse width be enough to trigger the pic arpeggiator clock i wonder?
Boogdish
PostPosted: Sat Jun 04, 2011 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
10ms is plenty.
JoeMorris
PostPosted: Sun Jun 05, 2011 3:10 am    Post subject: Reply with quote  Mark this post and the followings unread
great thanks, looking forward to this big time.
Boogdish
PostPosted: Sat Jun 11, 2011 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
New boards are in for this, with a pad for an MOTM style power connecter and ferrite beads.
Audio files: 160
PostPosted: Sun Jun 19, 2011 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi , just finished a design for my front panel Smile
Im using rotary switches for some parameters & building a little stripboard circuit with an extra 2 cv mixers , i've worked out the resistors needed between the rotary positions which i'll post up once ive tested after populating.
I included a rotary switch for the external clock divider control as i usually clock all my sequencers from a midi source.
 Filesize:  153.28 KB
 Viewed:  228 Time(s)
Last edited by Skrog Productions on Tue Jul 19, 2011 11:41 am; edited 1 time in total
ericcoleridge
PostPosted: Mon Jun 20, 2011 10:51 am    Post subject: Reply with quote  Mark this post and the followings unread
So, I'm still trying to understand how this works---the root note of the arpeggio is determined by the Note CV input, right? Does it generate different voltages based on the voltage it "reads" at the CV Note input?
Or does it just play the same selected preset arpeggio sequence, and simply by mixing in the voltage at the Note CV input, achieves the intended note sequence.
How does one order these now?
Boogdish
PostPosted: Mon Jun 20, 2011 5:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
This way. With controls for what that preset arpeggio sequence is. The input voltage doesn't play into the chip's software in any way.
e-mail me at Michael@Bartonmusicalcircuits.com to order.
Audio files: 160
PostPosted: Tue Jul 19, 2011 11:32 am    Post subject: Reply with quote  Mark this post and the followings unread
been busy over the last couple of weeks....
Finished the panel , fitted the hardware , wired up & powered up , just got the trimmer to set and also adjust a couple of resistor values on my rotary switches , i found that once the volt divider voltage went through the cv mixer / inverter stage the output dropped 0.2 of a volt , i re-calculated the resistors needed again and the rotary switches are selecting functions correctly now , Very Happy great , i will post up what values i used for the rotarys , i'am running this on 12v.
I realised i forgot the reset for the internal clock , so i drilled a push switch on the panel & also realised that the tempo / rate pot doubles up as the external clock divider control so i put a 2 way switch to select pot for rate control and rotary for division control , all good now, heh Smile .
Sounds to come later in the week .
Fantastic module , im having great fun with this & i got some ideas for a new track Very Happy.
 Filesize:  98.21 KB
 Viewed:  3952 Time(s)
 Filesize:  104.93 KB
 Viewed:  3970 Time(s)
 Filesize:  203.66 KB
 Viewed:  3999 Time(s)
brother303
PostPosted: Tue Jul 19, 2011 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
very nice build,as all of your "blueish"-stuff. Hats off!
If you could post the values for the resistors on the switches,would be nice!
Wink
Best regards
Greg
