today> Twyndyllyngs Chez Mosc
Ultimate Expandotron MFOS + hint of Buchla Photo Build Blog
Page 3 of 7 [168 Posts]
loydb
PostPosted: Sun Apr 17, 2011 6:27 am    Post subject: Reply with quote  Mark this post and the followings unread
This is the first weekend in awhile that I haven't felt like my head was going to explode, so I got almost everything dimensioned down to 3/4" thickness yesterday. For the two internal shelves, I don't want to use $$$ walnut -- the only part that will be visible is the leading edge, so I'm gluing a walnut strip onto a pine board. I'll plane the pine down to final thickness today so the strip matches exactly.
loydb
PostPosted: Mon Apr 18, 2011 4:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Even though I kept a dust mask on the entire time, my sinuses are still displeased with the woodwork & pollen combo. Hopefully it's gone by next weekend. Crying or Very sad
loydb
PostPosted: Wed Jun 15, 2011 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finally did a Mouser order and got the correct-size 24-pin IC sockets for the MFOS sequencer boards, and stuffed the analog board with resistors. Time to get moving on this again.
loydb
PostPosted: Thu Jun 16, 2011 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finished off the analog board for the sequencer. The first two pics show how to do resistor R25 with a parallel capacitor.
iopop3
PostPosted: Thu Jun 16, 2011 10:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Really nice to see that you are working on this again. Looking forward to see how your cabinet will end up like.
Somehow this thread contributed to my decision to get a Ultimate + Expander. Both are stuffed since a few months ago as well as the 16 step sequencer. My current excuse for not wrapping it up is that I'll move next month and a few pcbs needs less space than a complete cab. Will have the Ultimate + Expander as one complete unit, and the sequencer as a 5U module.
loydb
PostPosted: Fri Jun 17, 2011 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Post pics when you've got yours together. I'm trying to wrap my head around how I'm going to mount all this stuff. Smile
sompost
PostPosted: Sat Jun 18, 2011 12:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Isn't the C6 position right next to the R25 resistor where you could have soldered the 470pF capacitor in? I can just about see it on your photo. There's no need to piggyback it on the revision 2 boards. Just askin'....
Cheers, and great photo blog!
PS: I'm about to finish my own SoundLab U+E soon, and am looking forward to posting pictures.
loydb
PostPosted: Sat Jun 18, 2011 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I noticed the pads there, but assumed it was a layout error because the docs indicated to solder parallel. I guess the instructions I printed haven't been updated. Rolling Eyes I'll leave it as-is, assuming everything works ok. If not, easy enough to desolder.
loydb
PostPosted: Sat Jun 18, 2011 9:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finished off the digital board for the sequencer. Nothing left to stuff but the Expander!
loydb
PostPosted: Mon Jun 20, 2011 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Started the Expander, got the diodes and the first few dozen resistors stuffed.
RF
Audio files: 28
PostPosted: Mon Jun 20, 2011 5:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Keep on loydb - watching with interest...
www.sdiy.org/rfeng
loydb
PostPosted: Thu Jun 23, 2011 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Resistors done!
RF
Audio files: 28
PostPosted: Thu Jun 23, 2011 6:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Props! That was the most painful part of the build to me.
www.sdiy.org/rfeng
iopop3
PostPosted: Fri Jun 24, 2011 1:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I usually find stuffing resistors a rather relaxing experience but on both the Ultimate and Expander it felt like too many and became stressful.
ashleym
PostPosted: Sat Jun 25, 2011 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I agree with all above, this is consistently good work. As ever jealous of the wood working kit.
For some of the less regular values Ray chose I ended up using Welwyn resistors. The range I used have plain black bodies and the value printed on them numerically. These make the board look very neat, no endless stripes.
Resistors are one thing but what gets me is the board to pot and socket wiring. I ended up wiring and cable tying rather than other peoples twisted groups that look a lot better. That is my only issue with the 2 PCBs, I would have preferred a design that allowed PCB plugs to be used. I am sure this would mean a larger more expensive board but I feel we would gain a lot in trouble shooting and keeping our Ultimates/Expanders looking good and working.
loydb
PostPosted: Mon Jun 27, 2011 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Worked on capacitors last night. I'm basically done except for the .1 uF. I need 43, I had 42 on hand. Mad
Mouser should deliver tomorrow.
loydb
PostPosted: Sun Jul 03, 2011 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sigh. I am one capacitor short Sad I apparently mis-read my master spreadsheet, I only have 1 uF nonpolarized Aluminum caps, and I need a single 10 uF one instead.
Of course, I just made my "final parts needed" Mouser order last week...
FML.
loydb
PostPosted: Sun Jul 03, 2011 4:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I ended up needing a CD4066 as well, so at least it won't be a one-item order Smile
This essentially finishes the last of the PCBs for the project. I'll work on the panel next, and finish the case! Then the wiring fun begins...
loydb
PostPosted: Mon Jul 04, 2011 6:16 am    Post subject: Reply with quote  Mark this post and the followings unread
A note to anyone building an Expander -- the Mouser BOM on MFOS has an incorrect part. The 10 uF non-polarized aluminum capacitor for C38 is a normal polarized cap in the Mouser cart. I emailed Ray, he's changing it, but if you get to the end and wonder why you're missing a piece when you thought you ordered everything, that's why Smile
loydb
PostPosted: Thu Jul 07, 2011 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
The last parts showed up, here's a family shot of all the completed PCBs! Now on to the case...
loydb
PostPosted: Thu Jul 28, 2011 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Back to the woodworking portion of things. It's 112 degrees in my shop today. Evil or Very Mad
First up are the Walnut boards for the case exterior. I won't cut them to final size until I finish the face frame (the rest of the pics). Like I did on my mini-controller (see signature), I'm going to use Ebony as the accent wood. The biggest part will be a face frame that will surround the synth front panels. You can see the before and after from resawing the board in half on the bandsaw. This gave me a pair of matching pieces that I cut into 3/4" strips. I cut them slightly oversize so that I could use a jointer on the edges.
I then used a small thickness sander (made for model shipbuilders to dimension planking lumber) to remove the bandsaw marks on the final strips (you can see the marks the bandsaw left on the opened bookmatch).
diablojoy
PostPosted: Thu Jul 28, 2011 4:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
damn thats not nice to work in thankfully we dont get those temps here very often, only a few days each year
very nice plank of macassar ebony i can see no obvious faults in that piece
last price i got on that stuff was ridiculous and what was on offer was no good for fret boards, too many shakes Crying or Very sad
swapped to using cocobolo for fret boards for a while but that too has become unobtainium now Crying or Very sad .I only have a small quantity left
don't know what i will use once its gone.
more than a little jealous of that mini thickness sander you have there
I have to do that sort of thing by hand Smile .
good idea with the dust extraction too , sanding ebony is really bad
really like seeing this progress, nice thread Smile
loydb
PostPosted: Fri Jul 29, 2011 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you make archtops?
That's a piece from a longer ebony board that has been providing me with accent pieces for years. I'm going to be sad when I have to buy some more, it's so damn expensive these days.
Cocobolo used to be my favorite wood until I developed a skin allergy to it. Now I use it very sparingly, wearing long pants, socks and long-sleeve shirt, and immediately shower when I'm done surfacing/dimensioning it. Below is a jewelry box/table I made for my mom. The legs are cocobolo, the boxes zebrawood.
Audio files: 160
PostPosted: Sat Jul 30, 2011 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Great work with the populating , and nice carpentry skills as well Smile
I look forward to see how the synth Seq develops.
diablojoy
PostPosted: Sun Jul 31, 2011 2:11 am    Post subject: Reply with quote  Mark this post and the followings unread
any true hollow body archtops = nightmare challenge
alas i fear my skill level would be inadequate to do them
any justice , maybe one day i might try.
there was a local guy who ran courses Carson Crickmore. his archtops would have to be some of the best i have ever seen don't know if he's still going now though. really wish i could have done those courses but at the time I had other priorities .
thats a real bummer , surprising you are ok with ebony then it started to give me nose bleeds now i have to use a full mask for sanding.
dust extraction isn't enough
