Rare Bird Productions
Joined: Feb 26, 2005 Posts: 38 Location: Rijswijk - The Netherlands
G2 patch files: 6
Posted: Mon Feb 28, 2005 12:43 pm Post subject:
How to make banks and performances on the G2 Engine |
I just bought the G2 Engine and started experimenting. I have to say I love the sounds, but one disadventage of the Engine is though, the manual isn't really written with the Engine in mind.
It's hard to find out how to work with banks, patches and performances. I have several multi-timbral synthesizers and I don't have troubles with any of them. The whole terminology of the G2 leaves me in ridles. With most synthesizers performance is the same as multi, meaning selecting midi-channels in use and each channel functions as a seperate instrument, all loading patches from the same memory-bank. I want to do something simular with the Engine. Don't get this to work properly.
How can I make a bank with only the sounds I use in a certain song? And how do I combine this with performances?
With my other synthesizers I have one dedicated performance-setup which basicly says which midi-channels are used. |
Joined: Apr 03, 2004 Posts: 24626 Location: The Netherlands, Enschede
Audio files: 317
Posted: Mon Feb 28, 2005 1:13 pm Post subject:
Welcome zeldzame vogel.
Probably best that a keyboard player explains this to you, not that I don't know my way around but I'd probably use the wrong words and lead you into utter confusion.
Just wanted to say welcome and advise you be sure to have the 1.2 manual (not that it will help much for your problem, indeed it has a lot of attention for the keys-version - almost everything that is possible on the keys version can be done through the editor as well)
Jan. |
Axiom
G2 patch files: 28
Posted: Mon Feb 28, 2005 2:16 pm Post subject:
hmmm a stupid question... did you used the Editor?
Luca _________________
G2 patch files: 6
Posted: Mon Feb 28, 2005 2:42 pm Post subject:
| Axiom wrote: | hmmm a stupid question... did you used the Editor?
Luca |
Well, without the editor I couldn't do much with it, wouldn't I?
Yes, I use the editor and the manual, but allthough it tells me a lot about making sounds, something I can do myself, having worked with a semi-modular synthesizer, it doesn't tell me much about making your own banks with selected sounds.
To be honest I'm not much of a keyboardplayer. I use the computer to play everything. |
Rix
Joined: Aug 08, 2004 Posts: 83 Location: Breda, the Netherlands
G2 patch files: 25
Posted: Mon Feb 28, 2005 2:53 pm Post subject:
Well... the closest thing to a bank on the G2 IS the performance.
In a perfomance you can have 4 different sounds on 4 different midi channels. Not much, but then the G2 is not to be compared with a GM module or other midi synths.
If 4 channels is not enough in a sing you could probably switch to another bank (performance) via midi, but this still leaves you with a maximum of 4 different sounds.
Richard |
Unfed
Joined: May 11, 2004 Posts: 200 Location: Rochester, NY
G2 patch files: 11
Posted: Mon Feb 28, 2005 7:53 pm Post subject:
welcome, glad to see you followed my suggestion from the Yahoo group. there are a good handful of Engine users here that should be able to help you out. owning the G2 keys myself, i'd feel as lost as you if i were using the Engine. i think G2 keys owners take the UI for granted a bit (?). performance (multi-timbral) mode does seem a bit confusing compared to other hardware synths. to start out, open a 'new' performance in the editor. this gives you four blank slots for your multi setup. now you can use the 'open to >' function to call up whichever patch you want into each slot. i think you have to use the 'window' function to switch between the four slots while editing. midi channels for each slot in a performance can be set in the global settings for the synth. key splits, etc can be done in the 'performance/settings' window. once you're done, save the performance as a .prf file on your computer and on the synth itself. there's got to be a list of bank/program changes for using the Engine away from the Editor, not sure what they are. must be a way to switch between patch/performance modes as well. hope this helps some... _________________ SoundCloud |
Joined: Jan 31, 2003 Posts: 18288 Location: Durham, NC
Audio files: 235
Posted: Mon Feb 28, 2005 8:41 pm Post subject:
| Axiom wrote: | | hmmm a stupid question... did you used the Editor? |
Please, let's avoid words like stupid on this site. There are no stupid questions. The term seems disrespectful to me and its use is inappropriate here.
Thanks... _________________ --Howard
my music and other stuff |
Unfed
G2 patch files: 11
Posted: Mon Feb 28, 2005 10:09 pm Post subject:
i don't think he was saying that the original question was stupid. another way to say it would be 'hmmm an obvious question i'd ask is... did you used the Editor?'. i don't think he meant to be too disrespectful...  _________________ SoundCloud |
zynthetix
Audio files: 10
G2 patch files: 13
Posted: Mon Feb 28, 2005 11:34 pm Post subject:
as far as saving in banks, check in the editor menu Synth : save in synth
You mentioned that performance mode is like multi mode....this is accurate. Slots A- D are assigned to Midi Channels 1-4 respectively (by default, you could change this). However, when you are in performance mode, any patches in the selected (highlighted) slots are saved as ONE performance "patch". there are entirely different banks for performance mode , not to be confused with patch mode.
when you click "save in synth", it will go to a performance bank that can only be saved or accessed when in performance mode.
hope this helps you with your question. happy patching |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Tue Mar 01, 2005 3:08 am Post subject:
| zynthetix wrote: | | ...However, when you are in performance mode, any patches in the selected (highlighted) slots are saved as ONE performance "patch". |
I believe these highlighted Slots are responding to only one Midi channel?
Wout |
G2 patch files: 6
Posted: Tue Mar 01, 2005 5:59 am Post subject:
| Wout Blommers wrote: | | zynthetix wrote: | | ...However, when you are in performance mode, any patches in the selected (highlighted) slots are saved as ONE performance "patch". |
Wout |
I think each slot has it's own midi-channel, but I think I have a lot of experimenting to do. |
Audio files: 317
Posted: Tue Mar 01, 2005 6:52 am Post subject:
| Rare Bird Productions wrote: |
Yes but there is also the MIDI global channel for performance related control.
Experimenting iis good & fun of course :-)
Jan. |
Audio files: 317
Posted: Tue Mar 01, 2005 6:55 am Post subject:
| zynthetix wrote: | | any patches in the selected (highlighted) slots are saved as ONE performance "patch". |
Actually the unselected patches get saved as well into the performance and the selection status is saved with the performance. Meaning deselected patches will not get lost on save.
Jan. |
G2 patch files: 6
Posted: Tue Mar 01, 2005 7:43 am Post subject:
| Blue Hell wrote: | | zynthetix wrote: | | any patches in the selected (highlighted) slots are saved as ONE performance "patch". |
Jan. |
Yes and those patches can be loaded as well, so you can switch patches, but I have the impression you have to have a seperate bank for each of the 4 slots and channels.
There is also a global midi-channel, which can be turned of. |
Audio files: 317
Posted: Tue Mar 01, 2005 8:33 am Post subject:
but I have the impression you have to have a seperate bank for each of the 4 slots and channels. |
Whenyou mean the word "bank" to refer to "storage bank" your impression is wrong, there is no relation bettween slots or channels and storage banks..
And just to be sure ...
There are two separate indepenent sets of storage banks, one for patches and one for performances. The patches in a performance do not have to be in a patch bank - a performance contains and manages its own unique copies of the patches it contains.
Jan. |
G2 patch files: 6
Posted: Tue Mar 01, 2005 12:42 pm Post subject:
| Blue Hell wrote: | | Rare Bird Productions wrote: |
Jan. |
I discovered so as well, although I got the impression with one of the factory performances each channel had it's own bank of sounds. Should experiment a bit more.
It takes a lot of experimenting. |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Tue Mar 01, 2005 2:53 pm Post subject:
| Rare Bird Productions wrote: | I got the impression with one of the factory performances each channel had it's own bank of sounds.
That would be the variations, each patch can have 8 variations (different knob/switch settings for the same group of modules). These are selected by sending a MIDI CC#70. |
G2 patch files: 6
Posted: Tue Mar 01, 2005 4:02 pm Post subject:
| g2ian wrote: | | Rare Bird Productions wrote: | I got the impression with one of the factory performances each channel had it's own bank of sounds.
No, that was not what I ment, but when starting the synthesiser I get a performance, with 2 active slots and each slot seems to have a seperate bank with patches. If my midi-keyboard is sending over midi-channel 1, I get a different bank than when my keyboerd is sending program-change information over channel 2. |
Audio files: 317
Posted: Tue Mar 01, 2005 4:34 pm Post subject:
| Rare Bird Productions wrote: | | If my midi-keyboard is sending over midi-channel 1, I get a different bank than when my keyboerd is sending program-change information over channel 2. |
That's pretty weird ... about time to have a look at the actual midi messages ... I think midi ox can do that.
What is your global channel set to on the G2 ?
EDIT : are you sure you are not sending bank slect messages as well (CC 32) ?
Jan. |
Wan
Joined: Mar 31, 2004 Posts: 259 Location: Netherlands, Ugchelen
G2 patch files: 46
Posted: Wed Mar 02, 2005 12:29 am Post subject:
Can it be that for this performance the different slots has its patches loaded from different patch banks to begin with? On my G2X the slots keep the patch bank from which the last patch is loaded current. So a program change send to such a slot picks its patches from this current bank. This can give the illusion that the slots each have their own banks... _________________ Grtz Wan |
G2 patch files: 6
Posted: Wed Mar 02, 2005 1:56 am Post subject:
| Blue Hell wrote: | | Rare Bird Productions wrote: | | If my midi-keyboard is sending over midi-channel 1, I get a different bank than when my keyboerd is sending program-change information over channel 2. |
Jan. |
I don't think so. I've tried to send bank-messages, but it didn't work.
Global channel was 1, but I put global channel of. Still a lot of experimenting to do. I think I've created a bank with only the sounds I need for a certain song. |
G2 patch files: 6
Posted: Wed Mar 02, 2005 2:01 am Post subject:
| Wan wrote: | | Rare Bird Productions wrote: | I got the impression with one of the factory performances each channel had it's own bank of sounds.
Can it be that for this performance the different slots has its patches loaded from different patch banks to begin with? On my G2X the slots keep the patch bank from which the last patch is loaded current. So a program change send to such a slot picks its patches from this current bank. This can give the illusion that the slots each have their own banks... |
I suppose this is true. |
Audio files: 235
Posted: Wed Mar 02, 2005 8:59 am Post subject:
| Unfed wrote: | i don't think he was saying that the original question was stupid. another way to say it would be 'hmmm an obvious question i'd ask is... did you used the Editor?'. i don't think he meant to be too disrespectful...  |
After reading this over several times, I think you are right. He was talking about his own question, "did you use the editor?". I apologize, Axiom, for misinterpreting your post and for jumping to conclusions. _________________ --Howard
cappy2112
Joined: Dec 24, 2004 Posts: 2503 Location: San Jose, California
Posted: Tue May 03, 2005 2:28 pm Post subject:
| Rare Bird Productions wrote: | | Blue Hell wrote: | | Rare Bird Productions wrote: | | If my midi-keyboard is sending over midi-channel 1, I get a different bank than when my keyboerd is sending program-change information over channel 2. |
Jan. |
From what I remember on the Matrix 1000, sending bank select was a little tricky. You have to send the BS message, while it is still active, you had to send another byte with a value like 127, then yet another byte to Select the bank, then reset the 127 back to 0.
I think This sequence may have been synth-specific, but since I didn't remember this until now, this sequence *may* also apply somewhat to the G2. I wasn't able to get Bank select working on the G2 either, so I want to try this when I get home. |
Nodular
G2 patch files: 7
Posted: Thu May 05, 2005 2:47 am Post subject:
Hi everyone,
my first post, as a brand new G2X owner (1 week ), in this great forum!
About the topic:
I'm using an old sequencing software called Voyetra Midi Orchestrator Plus.
On this sw, you choose banks, setting a param called LSB (Last Significant Byte).
LSB=0 -> Bank=1
I don't know if other sw call this param the same...
bye |
