 Forum index » Instruments and Equipment » MAX/MSP - Pd
external use of envelopes
Page 1 of 1 [4 Posts]
LAB_
PostPosted: Tue Mar 01, 2005 3:25 pm    Post subject: external use of envelopes Reply with quote  Mark this post and the followings unread
hi.. (just came apon this forum, and checked out this max sub ..cool!)
i have a question:
how do i edit the graphical envelope (audio) from (example) midi input?
or is it possible to emutate this object in a .. coll .. i tried it, but for some reason
i fail to create an endpoint..
if i monitor the output of an envelope (prepend set) and i try to do the same with a list, it doesnt work..
has anyone tried to edit this envelope object through midi.
i did, but the env points came out really off the scale..
(ps i'm not a max n00b.. been working with it for 3,5 years now..
but this is really a stresspoint for me Sad
don't know if there are a lot of max freaks on this forum , but i thought : lets try it...
(the max mailing list is too much of an overdose for me (haha)
greetz.. martijn
snottywong
PostPosted: Sat Mar 05, 2005 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
there are about 49 billion different ways to use envelopes in max. why don't you send over an example patch and we can try to help you use midi to change the envelope using the specific way that you've made envelopes.
Audio files: 226
PostPosted: Sat Mar 05, 2005 5:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome snottywong
LAB_
PostPosted: Wed Mar 09, 2005 9:13 am    Post subject: nevermind Reply with quote  Mark this post and the followings unread
mmh when i tried to make a patch to explain the problem i found the answer..
DUH.
happens all the time.. i have learn to use max by mistake and error.. and stumble over solutions when i least expect them Smile
well, thanx for the replies anyway.
