Problems making an LFO with a 7414 schmitt trigger
Page 1 of 1 [13 Posts]
JingleJoe
PostPosted: Fri Nov 25, 2011 3:52 pm    Post subject:  Problems making an LFO with a 7414 schmitt trigger
Subject description: SOLUTION DISCOVERED!
The propblem:
Earlier this night I attempted to make a low frequency oscillator with a 7414 inverting schmitt trigger/buffer. I used the standard circuit for a CMOS schmitt trigger oscillator with one resistor between input and output and one cap from input to ground.
It didn't work.
Any resistance greater than about 2k didn't work and/or resulted in a distored square wave or triangle wave at the output.
The question:
Why?
I found out that this chip (the 7414) uses transistor logic (TTL) which requires more current than CMOS which is probably why the larger resistances didnt work. I've done that much of my own research but I want to know what you chaps say too and whether I am on the right track.
PostPosted: Fri Nov 25, 2011 5:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
When i made my first synth circuit over a year ago i used a 7414 because that is what the person in the video tutorial used. It didnt work, but luckily he also mentioned 40106 in the video so I had bought some of those too. I switched the chip and never went back to any 7xxx ic's. I thought it was me being a newb, but it looks like maybe that wasnt the case.
The triangle wave doesnt sound like a bad thing though. What sort of frequency range do you get with the triangle? Can you take a shot of the waveform on your scope?
JingleJoe
PostPosted: Sat Nov 26, 2011 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
The frequency range is pretty small, at best I got about an octave and even then with alot of "pulse width" change.
The wave itself was tiny though, only about half a volt peak to peak when using 5V supply and it's peak to peak voltage would increase and decrease as it's frequency changed, untill it became a wonky square wave then finally a pulse wave.
I could stick it through one of the other schmitt triggers to get a pulse wave, never got totally square though.
See attachment below for wonky waveform example.
a simetrix simulation of a circuit which produces the same waveform I observed
 Filesize:  192.4 KB
 Viewed:  473 Time(s)
Kabzoer
PostPosted: Sat Nov 26, 2011 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
You can put it trough a divider to get an exactly square wave with 50-50 symmetry, found that trick in the CMOS cookbook
http://soundcloud.com/contraspect
JingleJoe
PostPosted: Sat Nov 26, 2011 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Thats the good ol' multivibrator/flip flop circuit, correct?
Kabzoer
PostPosted: Sat Nov 26, 2011 10:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Yup, 'cause a 4040 divider is 12 cascaded T-flip-flops!
I heard, that in the 74xx series, the middle letters really make the difference, so for example, your circuit might work with a 74C14, but not with a 74HC14 or 74HCT14... But I don't really know what difference that makes....
JingleJoe
PostPosted: Sat Nov 26, 2011 11:04 am    Post subject: Reply with quote  Mark this post and the followings unread
It's my understanding that the HC or HCT means it is compatible with CMOS logic levels, but would still probably require the greater current of non-lettered TTL varieties.
4040: Good to know thanks! I may get one of those for other projects but for this one I really wanted the triangle wave from the cap.
Speaking of that, I have another thread to make ...
Kabzoer
PostPosted: Sun Nov 27, 2011 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you want a 50-50 triangle, then I think the symmetry of a 7414/40106 is just too low (especially at low frequencies) so if you want something better, you can use the one in the atonement, essentially it works the same, but it uses Op-amps, and is optimized for symmetry at these frequencies... You can go with your wonky one too, to keep things simple....
http://bit.ly/uXRemx
 Filesize:  20.05 KB
 Viewed:  507 Time(s)
JingleJoe
PostPosted: Mon Nov 28, 2011 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Accuracy is unimportant, having a semblance of stability and acctually working is all that really matters Laughing
I was experimenting with an oscillator very similar to that one just last night, but I still prefer these nice simple CMOS schmitt oscillators.
JingleJoe
PostPosted: Mon Nov 28, 2011 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just had an idea after posting that reply (see circuit in attachment for my idea) this circuit should still supply the current needed for the TTL schmitt trigger to work while giving the cap adjustable charge/discharge speed. A diode could be connected in parallel with R2 to make the output a pulse or saw wave. R2 should be a pot too to acheive variable frequency.
Values are guessed, my simulator didn't want to run this circuit so it is untested, experimentation time! Very Happy
 Filesize:  2.81 KB
 Viewed:  13833 Time(s)
JingleJoe
PostPosted: Mon Nov 28, 2011 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
experiment results are in:
The above diagram only sort of works, the wave from the top of R2 is really nice and odd Very Happy
However simply using resistor values below about 3k and the original circuit configuration works okay! Very Happy It has a nice big frequency range but the triangle wave is very lop-sided and the square wave is a pulse, at high frequencies it's a very sloppy pulse, but it works! Wink
Additionally putting the control pot of about 5k in parallel with a 1 or 2 k resistor gives a perculiar frequency response and allows enough current for the chip's input when the pot is turned all the way up to highest resistance (too little current would make the oscillator work improperly, outputting a very high frequency and wonky wave as mentioned above).
richardc64
Audio files: 26
PostPosted: Wed Nov 30, 2011 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Symmetry is elusive, even with CMOS.
The attached recordings were made from an actual 40106 with actual resistors and capacitors. I will never completely trust simulations.
With a 1k feedback resistor the waveform looks 50-50. At 100k symmetry is beginning to slip, and gets more and more unequal as R is increased. This pattern held for different value caps. The ramp waveform available at the capacitor would likewise be asymmetric.
Although I have a nostalgic fondness for TTL, I wouldn't give myself headaches trying get a predicable or consistent squarewave from a 7414 as an oscillator.
 Filesize:  11.79 KB
 Viewed:  332 Time(s)
JingleJoe
PostPosted: Wed Nov 30, 2011 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Me neither, but they are handy to get an idea of what is happening and graphs!
I'll get the ibuprofen ready because I broke my 4093 CMOS chips Rolling Eyes and all I have in the schmitt trigger area are these 7414's.
Those comparisons are great to see, very intriguing, I managed to get pretty jolly symetrical triangle waves/square waves from a 4093 based oscillator.
