JingleJoe
Joined: Nov 10, 2011 Posts: 878 Location: Lancashire, England
Posted: Fri Nov 25, 2011 3:52 pm Post subject:
Problems making an LFO with a 7414 schmitt trigger Subject description: SOLUTION DISCOVERED! |
The propblem:
Earlier this night I attempted to make a low frequency oscillator with a 7414 inverting schmitt trigger/buffer. I used the standard circuit for a CMOS schmitt trigger oscillator with one resistor between input and output and one cap from input to ground.
It didn't work.
Any resistance greater than about 2k didn't work and/or resulted in a distored square wave or triangle wave at the output.
The question:
Why?
I found out that this chip (the 7414) uses transistor logic (TTL) which requires more current than CMOS which is probably why the larger resistances didnt work. I've done that much of my own research but I want to know what you chaps say too and whether I am on the right track. Last edited by JingleJoe on Mon Nov 28, 2011 3:17 pm; edited 1 time in total |
Joined: Dec 11, 2010 Posts: 1026 Location: Toronto, Ontario - Canada
Posted: Fri Nov 25, 2011 5:12 pm Post subject:
When i made my first synth circuit over a year ago i used a 7414 because that is what the person in the video tutorial used. It didnt work, but luckily he also mentioned 40106 in the video so I had bought some of those too. I switched the chip and never went back to any 7xxx ic's. I thought it was me being a newb, but it looks like maybe that wasnt the case.
The triangle wave doesnt sound like a bad thing though. What sort of frequency range do you get with the triangle? Can you take a shot of the waveform on your scope? |
JingleJoe
Kabzoer
Posted: Sat Nov 26, 2011 8:05 am Post subject:
You can put it trough a divider to get an exactly square wave with 50-50 symmetry, found that trick in the CMOS cookbook _________________ http://soundcloud.com/contraspect |
JingleJoe
Posted: Sat Nov 26, 2011 9:09 am Post subject:
| Kabzoer wrote: | | You can put it trough a divider to get an exactly square wave with 50-50 symmetry, found that trick in the CMOS cookbook |
Thats the good ol' multivibrator/flip flop circuit, correct? |
Kabzoer
Posted: Sat Nov 26, 2011 10:38 am Post subject:
Yup, 'cause a 4040 divider is 12 cascaded T-flip-flops!
I heard, that in the 74xx series, the middle letters really make the difference, so for example, your circuit might work with a 74C14, but not with a 74HC14 or 74HCT14... But I don't really know what difference that makes.... _________________ http://soundcloud.com/contraspect |
JingleJoe
Posted: Sat Nov 26, 2011 11:04 am Post subject:
| Kabzoer wrote: | Yup, 'cause a 4040 divider is 12 cascaded T-flip-flops!
I heard, that in the 74xx series, the middle letters really make the difference, so for example, your circuit might work with a 74C14, but not with a 74HC14 or 74HCT14... But I don't really know what difference that makes.... |
It's my understanding that the HC or HCT means it is compatible with CMOS logic levels, but would still probably require the greater current of non-lettered TTL varieties.
4040: Good to know thanks! I may get one of those for other projects but for this one I really wanted the triangle wave from the cap.
Speaking of that, I have another thread to make ... |
Kabzoer
JingleJoe
Posted: Mon Nov 28, 2011 2:11 pm Post subject:
Accuracy is unimportant, having a semblance of stability and acctually working is all that really matters
I was experimenting with an oscillator very similar to that one just last night, but I still prefer these nice simple CMOS schmitt oscillators. |
JingleJoe
JingleJoe
Posted: Mon Nov 28, 2011 3:22 pm Post subject:
experiment results are in:
The above diagram only sort of works, the wave from the top of R2 is really nice and odd
However simply using resistor values below about 3k and the original circuit configuration works okay! It has a nice big frequency range but the triangle wave is very lop-sided and the square wave is a pulse, at high frequencies it's a very sloppy pulse, but it works!
Additionally putting the control pot of about 5k in parallel with a 1 or 2 k resistor gives a perculiar frequency response and allows enough current for the chip's input when the pot is turned all the way up to highest resistance (too little current would make the oscillator work improperly, outputting a very high frequency and wonky wave as mentioned above). |
richardc64
Audio files: 26
JingleJoe
Posted: Wed Nov 30, 2011 1:31 pm Post subject:
| richardc64 wrote: | Symmetry is elusive, even with CMOS.
The attached recordings were made from an actual 40106 with actual resistors and capacitors. I will never completely trust simulations.
Me neither, but they are handy to get an idea of what is happening and graphs!
| richardc64 wrote: |
Although I have a nostalgic fondness for TTL, I wouldn't give myself headaches trying get a predicable or consistent squarewave from a 7414 as an oscillator. |
I'll get the ibuprofen ready because I broke my 4093 CMOS chips and all I have in the schmitt trigger area are these 7414's.
Those comparisons are great to see, very intriguing, I managed to get pretty jolly symetrical triangle waves/square waves from a 4093 based oscillator. |
