alkopop79
Posted: Sat Apr 13, 2013 6:27 am Post subject:
Have you checked to see if the chip is bad, by putting in another one?
TL072 does not operate single supply. LM324 does, but it's a quad chip. I believe LM321 would be the single amp version, but I've not used them. |
Joined: Apr 03, 2004 Posts: 24584 Location: The Netherlands, Enschede
Audio files: 309
Posted: Sat Apr 13, 2013 6:33 am Post subject:
alkopop79
The speaker ... I'd not directly drive a speaker from an opamp .. if you want a speaker in the box make a separate power amp for it. _________________ Jan
JovianPyx
Audio files: 224
Posted: Sat Apr 13, 2013 8:15 am Post subject:
As Blue Hell said - the speaker - it's a very low impedance load and could easily cause the problem. As Blue suggests, better to run the speaker from a separate amplifier. _________________ FPGA, dsPIC and Fatman Synth Stuff
richardc64
Audio files: 26
Posted: Sat Apr 13, 2013 8:56 am Post subject:
It still wouldn't work.
For single supply, almost any op amp would work in this circuit IF the (+) input is biased to 1/2V+. (Which some mistakenly call a virtual ground.) Triggers should then be capacitor-coupled in. _________________ Revenge is a dish best served with a fork... to the eye |
JovianPyx
Audio files: 224
Posted: Sat Apr 13, 2013 9:21 am Post subject:
It's possible that the signal generator symbol might be intended to account for the required bias. I can't really tell for the symbol in the circle.
However, the signal generator also indicates 500 mHz which is .5 Hz. I suppose that this filter is intended to operate at very low frequencies? _________________ FPGA, dsPIC and Fatman Synth Stuff
Scott Stites
Audio files: 96
Posted: Sat Apr 13, 2013 9:57 am Post subject:
| JovianPyx wrote: | It's possible that the signal generator symbol might be intended to account for the required bias. I can't really tell for the symbol in the circle.
However, the signal generator also indicates 500 mHz which is .5 Hz. I suppose that this filter is intended to operate at very low frequencies? |
Looks to me that the signal generator is there to provide input pulses at a 0.5 Hz rate (as an illustration, I guess, of what it takes to ring the thing).
Like mentioned before, if it's single supply, it would need an artificial ground (1/2 Vcc) and (again) drive the speaker from a second amplifier. _________________ My Site |
alkopop79
Posted: Sat Apr 13, 2013 12:31 pm Post subject:
Thanks for all the replies! I did further simulation and indeed, without virtual ground it won't work. THe circuit can be found here:
https://www.circuitlab.com/circuit/g52648/twin-t-with-trigger/
You can open it in the editor and play with it. The time domain simulation will even draw a nice kick drum. Eventually I found a sail splitter circuit here:
http://tangentsoft.net/elec/bitmaps/vgrounds/rdiv.png
However, when I build the circuit on the breadboard, it doesn't work. With 9V DC supply instead of getting 4.5V, 0V and -4.5V I get 9V, 4.5V and 0V. It seems as if the caps weren't even in the circuit. I checked the polarity and the value of the caps and even used different ones. Still don't get any virtual ground, the circuit acts as a voltage divider. A photo of the breadboard circuit:
http://www.flickr.com/photos/alkopop79/8646491414/
It's beyond me why doesn't it work. Any ideas? |
Posted: Sat Apr 13, 2013 12:46 pm Post subject:
| Are you using the "virtual ground" (yes I know I'm abusing the term) as your reference to see +/- 4.5V? If you're using "real ground" then what you describe is exactly what you would expect, yes? |
alkopop79
Posted: Sat Apr 13, 2013 1:13 pm Post subject:
| It's working. I was a dumbass: the ground of the multimeter has to go to the junction, the middle ground of the circuit. Indeed, from a 9V supply I get 4.5V, 0V and -4.5V. I changed the 741 to a TL072 and it works! So far I've only checked it with an oscilloscope and it very much looks like an analog drum! |
alkopop79
| elmegil wrote: | | Are you using the "virtual ground" (yes I know I'm abusing the term) as your reference to see +/- 4.5V? If you're using "real ground" then what you describe is exactly what you would expect, yes? |
Erm, yes.  |
Posted: Sat Apr 13, 2013 1:45 pm Post subject:
I've done even more foolish things and even owned up to them here, so don't feel too bad  |
alkopop79
Posted: Sat Apr 13, 2013 2:19 pm Post subject:
| Tried it with the amp but unfortunately it distorts the crap out of the signal. |
alkopop79
Posted: Sat Apr 13, 2013 2:20 pm Post subject:
| alkopop79 wrote: | | Tried it with the amp but unfortunately it distorts the crap out of the signal. |
Failed to mention, it's an LM386. |
alkopop79
Posted: Sat Apr 13, 2013 3:01 pm Post subject:
| Is it possible that the amp distorts because it gets -4.5V to 4.5V signal? It's a single supply amp though. |
Scott Stites
Audio files: 96
Posted: Sat Apr 13, 2013 5:28 pm Post subject:
| alkopop79 wrote: | | Is it possible that the amp distorts because it gets -4.5V to 4.5V signal? It's a single supply amp though. |
Well - I have yet to play with one of those buggers, but, according to the data sheet, it's a bit more than possible. Data sheet says absolute maximum input voltage is +/-0.4V.
Also, if you're powering the op amp from single supply, I think you will want to couple through a capacitor to the LM386 to get rid of any voltage offset. _________________ My Site |
Thomas_Henry
Joined: Jul 24, 2009 Posts: 170 Location: N. Mankato, MN
Posted: Sat Apr 13, 2013 6:36 pm Post subject:
Hi Gang,
My suggestion would be to jettison the op-amp altogether and use a transistor as the gain element for the Twin-Tee. That's exactly what I did for the Sirius Metronome published in Nuts & Volts in January. I too used the 386 for the output stage. It all worked out quite nicely with a very satisfying woodblock sound.
http://www.nutsvolts.com/forums.html?/magazine/article/january2013_Henry
Click the mouse icon to preview the article.
Thomas Henry |
alkopop79
Posted: Sat Apr 13, 2013 8:11 pm Post subject:
| Thanks, neat circuit! I will give it a try! What's the difference between the LM380 and the LM386? |
-minus-
Posted: Sat Apr 13, 2013 9:27 pm Post subject:
| Why is 'virtual ground' abusing the term? Can someone explain this? |
Posted: Sat Apr 13, 2013 10:41 pm Post subject:
| I believe (though Richard can correct me if I misunderstood his comment) that it's because the true "virtual ground" is when you hold one of your op amp inputs at ground and it forces the other one to also be at ground potential even though they're not shorted. |
Scott Stites
Audio files: 96
Posted: Sun Apr 14, 2013 1:16 pm Post subject:
I actually decided to subscribe to N&V because I know TH has actually published a string of articles there. _________________ My Site |
alkopop79
alkopop79
Posted: Fri Apr 26, 2013 11:20 pm Post subject:
Friends,
the circuit works! It's pretty amazing, I get massive kicks on the output. However the circuit audibly 'buzzes' when I touch a pot. Also, the it tends to distort at higher frequencies and it's pretty noisy. Any ideas how to fix that?
https://soundcloud.com/alkopop79/twin-t-percussion-osc |
sonic
Joined: Dec 02, 2010 Posts: 106 Location: Victoria BC
Posted: Thu Aug 22, 2013 9:44 pm Post subject:
| I'm far away from anything to test with right now, but I'd expect the 3.3 to have more impact than the op amp. Do you have any 560k resistors? Put one in series and see if it improves anything, that should get you close to 3.8M.... |
